TCA6424A: About the TCA6424A
Part Number: TCA6424A
Other Parts Discussed in Thread: TCAL6416, TCAL9539, TCA8418E
The questions are as follows.
For example, when used as an input port and a switch circuit is connected to the port terminal to turn it on/off, does the TCA6424A include any chattering prevention (control)?
If so, please tell me specifically about its functions.
  • No, the I/O pins have plain CMOS inputs.
    If you are using the /INT signal to detect changes, and if you read the input port at the wrong time (when the input voltage happens to be back at the old value), then you will get another interrupt when the input voltage goes again to the new value.
  • Hi User6448843,
    TCA6424A does not include switch chattering prevention.
    If the input switches state (therefore causes an interrupt on /INT) and goes back to its original state, the interrupt will de-assert.
    A device like TCAL9539 or TCAL6416 has latchable inputs where the switch state change is remembered until serviced (even if the input state returns back to original state).
    Is it possible to use an external low pass filter for debouncing?
    TCA8418E key pad scanner is also an option. This device has built in debounce circuitry + 10 byte FIFO.
    Tyler
