DP83867E: BMSR Adress
Part Number: DP83867E
Dear, Ethernet PHY Support team.
In the data sheet, Table 7-11, Address 0x0001 bit 6 (MF PREAMBLE SUPPRESSION) says, "0 = Normal management operation.
The device requires a minimum of 500ns gap between two
transactions, followed by one positive edge of MDC and MDIO=1,
before starting the next transaction."
I think this bit can only be used with the value set to "1 (Preamble Suppression enabled)."
(As you can guess from the name, it's a function that allows you to send Ethernet frames without the preamble that should be at the beginning of the frame!?)
I think I have a basic understanding of preambles.
What is the difference with Bit6=0 "Normal management operation"?
I would like to know what state it is in when used with Bit6=0 "Normal management operation".
Hiroaki Yuyama
  • Hi Yuyama-san,
    The preamble mentioned for this bit is for the management transaction. Like ethernet frames, the MDIO/MDC transaction sends preamble used by the PHY to establish synchronization with the MAC before receiving a management frame. This preamble is followed by an opcode and other data to configure the PHY.
    If the preamble suppression is enabled, the PHY will not expect a preamble and immediately expect the MAC to send valid opcode and turnaround.
    In normal operation, the PHY will expect a 32-bit preamble to synchronize with the MAC and then expect valid data to come in to the PHY for configuration.
    Please let me know if you have any other questions.
    J
  • Hello J-san,
    Thank you for your reply.
    We have sent our reply back to the customer.
    Please let us know if you have any further questions.
    Hiroaki Yuyama
  • Hi Yuyama-san,
    Please let me know if the customer has more questions.
    J
