DP83867E: Verify the Schematic and
Part Number: DP83867E
Dear TI team,
I hope you’re doing well.
I kindly request you to verify the attached schematics,
We would like to request your support in reviewing our Ethernet schematic to ensure correctness in the following areas:
  • Switch to PHY Interface: Check signal integrity, termination, and compatibility. (RGMII interface with Autonegotiation 10/100Mbps )
  • Specifically focus on the auto-negotiation circuit.
  • PHY to RJ45 Connection: Ensure proper magnetics, pin mapping, and grounding.  ( PHY to RJ45 interface 2 pair. - 10 /100Mbps)
  • Check the LED connection also.
Check whether the implementation is correct and let me know if any modifications or improvements are needed.
Your feedback will be highly appreciated to ensure the design functions as intended.
Kunal Chaudhari.
