Part Number: AM26LV32E
For the part number listed, the junction to board thermal resistance value shows as N/A. Can I assume junction to board is the same as junction to case (top)?
Hi Isabella,
Thanks for reaching out on E2E!
Junction to case (bottom) values are only applicable for packages with exposed pads (like the VQFN). The other packages do not have exposed pads hence why they are missing. If you still need to provide a value, then you can use the junction to case (top) since it would be the worst case scenario.
Let us know if you have any other questions!
-Ethan
