TUSB8041: TUSB8041IRGCT
Part Number: TUSB8041
I have question regarding to TUSB8041 - 4 port USB 3.0 hub.
I will use two USB3.0 and two USB2.0 for downstream and i don't use it for battery charging application.
Can i floating(leave) below pins without any connection?
- PWRCTLx/BATENx, OVERCURxz
If yes, can i set rest of pins as following,
- AUTOENz/ HS_SUSPEND : disable
Best regards.
  • PWRCTLx/BATENx, OVERCURx  are used to control power switching for downstream port Vbus, if  Vbus is not needed for your downstream port , then you can leave these pin floating.
    if battery charging is not supported , then AUTOENz/ HS_SUSPEND : disable
    Best
    Brian
  • Hello Brian,
    Thanks for your reply.
    One more question, if i will providing external 5V to VBUS for downstream, is it okay to leave these pins floating?
    thanks
    Best regards.
