TPD6S300A: TPD6S300 RPD_G1 resistor value.
Part Number: TPD6S300A
Hi Team
could you help me check the resistor value as below yellow mark?
BRs
Brian
  • Hi Brian,
    I will need to check with the team on this one, and don't know if we have this exact information.
    Why do you need it? it's probably large enough to provide a weak pullup to enable the fet when it is attached to the CC line. It should also be large enough that it is negligible compared to a parallel Rd resistor.
    Thanks and Regards,
    Chris
  • Brian,
    We spoke to Systems and an Analog designer about this, and they both do not have an exact value for this, but mentioned that the exact value is not important.
    "It is large enough to protect the device connected to it"
    Thanks and Regards,
    Chris
