TPD12S521: Pull-ups
Part Number: TPD12S521
I'd like to use TPD12S521 with a RaspberryPi CM5 module, but the module has internal pull-ups:
CEC:27K
SCL/SDA: 1K8
HOTPLUG: 100K PULLDOWN
TPD12S521 reference design shows 1K7 on the connector side, would it be OK to change them to something like 10k?
  • Hi Nate,
    The issue with using a 10k resistor will be that when you connect a long cable to your port, you will not have sufficient resistance to pull the signal high with a large capacitance.
    If you know that you will only use relatively short HDMI cables, you can reduce the pull-up resistor, but if you want maximum support for long cables, then I suggest that you do not change it.
    You can refer to the NXP I2C Spec:  https://www.nxp.com/docs/en/user-guide/UM10204.pdf to calculate the resistor pull-up for the I2C bus.
    I believe that the 1.8k resistor was selected to work with cables between 0.5m and 10m, but that board was designed more than 10 years ago, so I am not certain.
    Chuck
  • I see.
    Having 2 sets of 1k8 in parallel (the ones of the module and the ones after the TPD12S521 part would result in a very very strong pull-up. I guess I'll have to find a different protection solution.
