Part Number: ADS8900BEVM-PDK
Other Parts Discussed in Thread: ADS8900B
Hi, I'm a LabVIEW user and I confirmed that the GUI software for that product is made with LabVIEW.
Can I get this VI, or can you share a simple VI example?
Hi Dohoon,
Thanks for your post. May I ask what the use-case is? Is this for evaluation of ADS8900B?
Samiha
Yes, I want to save the data that is measured by the GUI and test of the high speed ADC that works with ADS8900B. I also need a VI file to make sure that the data is output normally when I send it to UDP communication.
Hi Dohoon,
Thanks for sharing. The GUI is not really made of separate VIs as it is not in a format that is intended to be shared externally. If you are needing to save the measured data, you can right click the plot on the GUI and save the data as an excel file.
Samiha
