Other Parts Discussed in Thread: TFP403
If I can find a DVI source that has less than 25MHz pixel clock, what could happen if I connect this DVI source to TFP403? The datasheet says minimum pixel freuquency is 25MHz. If I change EDID timing setting to lower pixel clock frequency for example 19MHz, will the DVI source (for example video card) will generate a 19MHz pixel clock video signal?
