Part Number: DP83867IS
Hello, on the page 112 of the DP83867IS datasheet is described power sequencing when three power supplies are used.
1. 1V8 should be stable not later than 25 ms from the 2V5 ramp up.
2. When powering down 1V8 must be powered down before 2V5 is powered down.
First demand is fairly easy to implement in my design. Second is a bit tricky. My question is: can both 1V8 and 2V5 be brought down simultaneously?
I plan to use the same EN signal for both power supplies and to use a soft start time for 1V8 greater than for 2V5. This is how I will satisfy demand 1.
I don't know how to make 1V8 be brought down before 2V5.
If you have some app note, please share.
Milos
