DS90LV012A: RE: Thermal Data of DS90LV012ATMF/NOPB
Part Number: DS90LV012A
I am planning to use the Infineon part number DS90LV012ATMF/NOPB in our new hardware design. However, upon reviewing the datasheet, I was unable to find specific thermal characteristics such as junction temperature (Tj), thermal resistance values (θJC, θJB).
To proceed with proper thermal analysis, could you kindly provide the recommended thermal data values for this device at your earliest convenience?
Thank You,
Niranjan Kumar
  • Hi Niranjan,
    I have put a request into our thermal modeling team - these requests typically take up to 2 weeks to complete. I will update you when I receive the model.
    Parker Dodson
  • Hi Niranjan,
    I apologize we went over the two weeks by a couple days and I appreciate your patience - but I have the thermal parameters listed as follows:
    Result- Theta JA-High K (standard datasheet value) 175.2
    Result-Theta JC, top (standard datasheet value) 80.1
    Result-Theta JB (standard datasheet value) 43.5
    Result- Psi JT (standard datasheet value) 15.3
    Result- Psi JB (standard datasheet value) 43.1
    Result-Theta JC, bottom (standard datasheet value)
    n/a
    Parker Dodson
