PCA9536: About the Pd and Tj spec on PCA9536
Part Number: PCA9536
Other Parts Discussed in Thread: TCA9536, TCA6424A
Hi AE,
       We needed more about the Pd and Th information, Could you share the spec for us? Thanks!
Best Regards
  • Hi AE,
           We needed more about the Pd and Tj information, Could you share the spec for us? Thanks!
    Best Regards
  • Hi Bruce,
    The Tj spec is not included in this datasheet. Is it possible to use the upgraded version of this device - TCA9536? Tj(max) = 150C for this device.
    For Pd - which I assume is power dissipation. There is no spec for Pd because it is dependent on the loading configuration on P0 - P3 GPIO pins. Different applications source/sink different amounts of current through the I/O expander which would affect Pd.
    This e2e has a fairly good assessment on calculating pd for the TCA6424A. Let me know if this helps any.
    Tyler
