Part Number: TUSB4041I
Dear Support Team,
I hope this message finds you well.
We are currently planning to use a USB 2.0 Hub IC to convert a single USB 2.0 port into four separate USB 2.0 ports. The four output ports will be connected to the following peripherals:
Touch Panel
Camera
USB to Ethernet
USB Debugging
Please note that we intend to operate only on the USB 2.0 standard, not USB 3.0. Could you kindly confirm if the TUSB4041I IC is suitable for our requirements? If this IC is not appropriate, we would appreciate it if you could recommend an alternative IC that would meet our needs.
Thank you for your assistance. I look forward to your response.
Hafiz Rizwan Waheed
