Part Number: DP83TG720R-Q1
For Enable PHY Output 125MHZ Clock, I write the value of address 0x453 to 0x21 for enable the clock output.
I want to know
1. the clock is need PLL lock or not?
2. If the voltage is unstable, i enable the clock output, it will influence the clock accuracy and stable or not?
3.After I enable the clock output, i need wait a moment in the software then continue the init sequence ,the communication is normal. but if don't wait, will have some data lost.
Can you give me some good suggestion? Thanks
