LSF0102: LSF0102
Part Number: LSF0102
Hi Team,
I'm using the part LSF0102DQER for Bidirectional usage for UART interface.
Here is the schematics for reference.
I want to know the PU resistors are mandatory for this circuit.
Kindly provide your inputs.
Manikandan R
  • Hello Manikandan,
    UART is a push-pull protocol, meaning you need pull-up resistors on the outputs otherwise the LSF0102 will act as open-drain translator.
    Since UART has Tx and Rx signals, I would recommend using something like the TXU0202. No need to use pull-ups with this level translator.
    Josh
