Part Number: TLIN1024A-Q1
Hello team,
During tests with the TLIN1024A device, we are giving the Vsup as 12 V. From the data sheet it is mentioned as 3.3V - 5V for EN pin.
We are giving the the 5V from the power supply to the EN pin but still EN pin voltage as higher than the 5V. Enable pin from the transceiver not set as high.
Could you please provide clarification on this behavior and specify the scenarios in which the EN pin may be set?
Thank you for your assistance.
