Part Number: DP83867IR
Hi Team,
I have several questions regarding the revisions of the DP83867 IC as described in the datasheet Rev.I:
From Rev.H, gain control registers at device addresses 0xA0 to 0xA3 have been added (datasheet Rev.I, page 90). Does this mean the gain values have changed compared to previous revisions? Or are these registers newly added while the default gain remains unchanged?
From Rev.F, the Viterbi Module Configuration (VTM_CFG) at address 0x0053 has been introduced (datasheet Rev.I, page 86). If used with default settings, does this result in any behavioral changes compared to previous revisions?
From Rev.F, the pin types of TX_EN and TX_CTRL have changed from Output to Input. Can you confirm that this is a correction of a documentation error and not a specification change?
From Rev.H, the default values of RGMII_TX_CLK_DELAY and RGMII_RX_CLK_DELAY in the RGMII Control Register (RGMIICTL, address 0x0032, datasheet Rev.I, page 83) have changed from 0 to 1. Is this also a documentation correction rather than a specification change?
When enabling RGMII and AMDIX via strap configuration, is it acceptable to leave RX_D6 strap open for both Rh and Rl? I have reviewed the DP83867 Schematic Checklist (www.ti.com/.../slvrbn1), but would appreciate your confirmation.
Thank you for your support.
teritama
