Part Number: DS250DF230EVM
Other Parts Discussed in Thread: DS250DF230,
Hi Team
I have the DS250DF230 EVM and trying to make PRBS pattern
I am having problems with the setup and couldn't generate test pattern at 6.375Gbps
I saw in the E2E forum that i need to provide the required bit rate at the input or subset of it for the CDR to lock
So i provides 6.375G/16=398.43MHz input as sine wave and also tried with square wave but without success
I added the register dump for your investigation
Can you help me to figure out the correct setup and register setting for having PRBS pattern at 6.375Gbps
Can you share the correct register configuration?
Roey
