Part Number: DS160PT801
DS160PT801 This is my first time using it, please help an expert to check if there are any parts of the design that need to be corrected, thank you!
Hi Tony,
Here are a few comments on your design:
Greg
Hi Greg
Thanks for the reply, and a few more questions
1. What are the specific requirements for the power supply ripple and the number of filter capacitors used in each power domain, and how much does the capacitor package need to use?
2. If refclkout is not used, can it be grounded with 33 ohm resistance?
3. What is the specific function meaning of add0, add1, mode, rxdet, and witdh, and what is the difference between pulling up and down resistors and floating in the air?
4. How many positions are there in the IIC configuration pin, and what is the corresponding IIC address?
Hi Tony,
I will look into these questions and answer as soon as possible.
Greg
Hi Tony,
To confirm, have you requested and received access to the full datasheet for the DS160PT801 device in the Secure Resources system? It has extensive information about pin functions.
1. The ripple requirements are detailed in Section 7.2, and there is a recommended power supply schematic in Section 10.
2. The datasheet advises that REFCLK_OUT should be left floating if not used.
4. Table 8-1 of the datasheet details the configuration and number of possible SMBus target addresses
Details about your questions 3, 5, and 6 can be found in Table 6-1 of the datasheet that explains all pin functions.
Greg
Hi Tony,
I am not sure why your access was denied, as another team handles this. You can create a ticket through the Customer Support Center to see why this happened.
Greg
Hi Tony,
There are two methods to configure the DS160PT801 that can be used in conjunction, register control via SMBus and automatic configuration via external EEPROM. The details of these methods can be accessed in the device Configuration Guide, which can be requested on the product page.
Greg
