Part Number: TCAL9539
For the TCAL9539, if the INT function is not used, can the INT pin be left floating or does it require a pullup resistor? The datasheet doesn't explicitly say how to connect the pin when it is unused, it only says "Connect to VCC through a pull-up resistor."
