Part Number: DS280BR810
Other Parts Discussed in Thread: DS250DF810, , DS280DF810
Hi Teams,
Please help review the schematic diagram,thanks~
BR
Hi Teams,
BR
Hi Vayne,
Thanks for sharing. We will review and provide feedback early next week.
Drew
Hi Drew,
My customer has some question as blow:
As you know, the retimer would work in master mode when programming EEPROM, after completion programming, it should work in slave mode to communicate with CPU.
In this case, how to switch the status from master to slave?
Hi Vayne,
1. Address can be set through ADDR0/1 pins.
2. EEPROM .hex file can be generated using SigCon Architect.
The device will automatically switch to slave mode after EEPROM read is complete.
3. Yes, we have a programming guide for DS280BR810 and DS250DF810. Please find these at folders below. You may need to request access.
https://www.ti.com/drr/opn/DS280BR810-DESIGN
https://www.ti.com/drr/opn/DS250DF810-DESIGN
Drew
Hi Vayne,
The only difference between these devices is CDR lock range. These devices are pin to pin compatible.
Drew
