Part Number: MAX3232E
Hello Team,
MAX3232EI line driver is planned to use as line driver device between the Renesas RX series controller SCI pins and the RS232C serial flash programmer .
In the Renesas controller datasheet it is mentioned to use the pull-up resistor for TxD and RxD lines for SCI lines, but the necessity of pull-up circuit with RS232 line driver is not mentioned in the data sheet .
Please clarify if we use the MAX3232E line driver still we need to provide the Pull-up circuit for both RxD and TxD lines.
In previous version of the ECU circuit , with different Renesas controller, pull-up circuit is provided only at the ROUT pins.
