DP83867IS: Configuration for Compliance Testing
Part Number: DP83867IS
Hi team,
The Ethernet compliance test performed on the board using the DP83867IS resulted in a failure.
I believe the following register settings are provided for adjusting the signal waveform.
Could you please explain each register:
- What function it performs
- The maximum and minimum values for the setting
- How the effect changes when the value is increased or decreased
  8.6.44 Configuration for Receiver's Equalizer  :CONFIG_REC_EQ
  8.6.46 Configuration of Receiver's LPF     :CONFIG_REC_LPF
  8.6.47 Enable Control of Receiver's Equalizer  :EN_CTRL_REC_EQ
  8.6.51 Loopback Configuration Register    :LOOP_CFG_VAL
  8.6.52 DSP Configuration           :DSP_CONFIG
  8.6.53 DSP Feedforward Equalizer Configuration:FFE_EQ
Additionally, if there are any registers that allow adjustment of the signal waveform, please advise.
Ryu.
