DP83TC818S-Q1: Is register init sequence required?
Part Number: DP83TC818S-Q1
I found the following register init sequences in the sample code provided (dp83tc818.zip) which are executed during chip init phase.
  • DP83TC817_cs1_1_master_init
  • DP83TC817_cs1_1_slave_init
I'd like to check with you if the sequence is required as well for DP83TC818?
Thank you in advance!
