Part Number: TMDS1204
Hi Team,
I am using TMDS1204RNQR Retimer IC in my project.
And my FPGA supports like when the Cable detect (Rx detect) should go first from the Source (Laptop) to the retimer IC to the SOC using HDMI RX connector.
After Cable detect indication, my SOC should send the HPD signal and EDID value to the HDMI Rx connector, after this SIGDET signal indication will come. The HPD signal condition is Active Low for working board scenerio.
Now Can I able to use without RX detect signal, will any Register option is provided on the Retimer IC or any method to enable the SIGDET signal pin indication??
Vaishnavi
