Part Number: DP83869HM
Other Parts Discussed in Thread: DP83869
The DP83869HM data sheet:
www.ti.com/.../dp83869hm.pdf
Shows different current levels in Section 6.5 on pages 13, 14 & 15.
What is the maximum current that the DP83869HM can safely output?
If one or more of the data lines in the Ethernet cable is shorted to ground (due to a fault) how does the DP83869HM handle that?
Is the data line turned off or does the DP83869HM have a regulated maximum safe current output?
Thank you
