DP83822IF: LVPECL conenect
Part Number: DP83822IF
Hi team,
Is it possible to connect and communicate the DP83822IFRHBR with the optical transceiver LSB2-A3S-PI-N3, which uses an LVPECL interface?
For example, the DP83849IFVS, which is from the same series, includes references to PECL in its datasheet.
However, I could not find any mention of PECL in the datasheet for the DP83822IFRHBR.
Does this mean that such a connection is not supported with the DP83822IFRHBR?
If it is possible, could you please advise on how to connect the devices properly?
Shota
