Hi Daniel,
We will review and get back to you on this.
Matt
Hi Daniel,
For the questions:
It is Functional Safety: Quality-Managed rated – so no specific ASIL letter rating on this device. It can be used in ASIL-B systems but that requires additional components to act as redundancies – what exactly those additional components are will vary with specific application implementation – but basically it is adding additional voltage supervision to the board.
Matt
Hello Mr Smith,
Thank you for the reply. I have some extra questions related point 4 (Functional Safety level). You said that in order to use it for an ASIL B project, we should have in principle an additional voltage supervision to the board. Is enough if the uC is that voltage supervision? If there is an issue with the supply the uC will detect it and react.
Hi Daniel,
I can't say definitively because its very application/system dependent. It will also depend on the uC you are using. Since we have been having parallel/duplicate communications on this via email with our field team you've been working with, I would suggest we take this off the public e2e forum and keep to private emails for further discussions. We will most likely need to have a meeting later on to discuss in more detail.
Matt
