DP83822I: Inquiry Regarding MEDIA DEPENDENT INTERFACE Connection of DP83822
Part Number: DP83822I
Hi team,
My customer is currently considering a configuration in which the MEDIA DEPENDENT INTERFACE of the Ethernet PHY DP83822 is connected via PCB routing to an Ethernet switch device.
I apologize for the broad nature of the question, but if there are any points of caution or recommendations to keep in mind when implementing such a configuration, I would greatly appreciate your guidance.
Kyohei Yabana
  • Yabana-san
    The DP83822 can support either transformer or transformer-less coupling.
    For transformer coupling, please see below implementation block diagram and transformer electrical spec.
    For transformer-less coupling, please see below for the implementation block diagram and this app note.
    David
