DS92LV18: DS92LV18:datasheet PCB LAYOUT AND POWER SYSTEM CONSIDERATIONS
Part Number: DS92LV18
Regarding the following items described in datasheet
(1)A solid ground plane is recommended for both DVDD, PVDD or AVDD. Using a split plane may cause ground loops or a difference in ground potential at various ground pins of the device.
-->Does this mean connecting DGND, PGND, AGND to a common GND?
(2)Rounding up to a standard value, 0.1uF is selected for each DVDD pin.
-->On the DS92LV18, do I need a 0.1uF capacitor on each power pin for PVDD, AVDD, as well as DVDD?
