Part Number: DP83867IR
Hi All,
I have a question DP83867IR Register settings.
We confirmed that the compliance test passed using the following application note.
Please see the following document.(How to Configure DP8386x for Ethernet Compliance Testing)
www.ti.com/.../snla239d.pdf
On page 16 of this application note, we confirmed that if the "0x1D5" register setting is not executed, the compliance test (whether the product complies with the product standards) will fail.
However, the latest datasheet for the DP83867IR (Changes from Revision F (October 2019) to Revision G (August 2022)) states that "Removed Reg 0x01D5 Programmable Gain Register (PROG_GAIN)".
In the latest datasheet, the description of "0x1D5" has been deleted.
www.ti.com/.../dp83867ir.pdf
We are currently setting the "0x1D5" register as described in the application note, but am I correct in understanding that the "0x1D5" setting is not necessary during actual operation?
Also, please kindly tell me why the register setting "0x1D5" is no longer necessary in the latest data sheet.
Hayashi
