Part Number: DS90UB953-Q1
Other Parts Discussed in Thread: TDA4VM, , DS90UB960-Q1
Some boards operate correctly down to –35 °C
Some boards fail to lock at –35 °C
Have implemented code for temperature ramp initialization? If not, please read through the System Initialization section of the 953 datasheet.
Lucas
Behalf of venkateshraja p ,
Thanks for the update.
We have not performed temperature ramp initialisation, Since in our setup we are using driver/media/i2c/ds90ub953.c for serializer and driver/media/i2c/ds90ub960.c deserializer source codes.
From ds90ub953 datasheet we could see 7.3.1.1.1 Code Example for Temperature Ramp Initialisation.
Could you please provide a patch file to include above temp ramp initialisation driver/media/i2c/ds90ub953.c and driver/media/i2c/ds90ub960.c.?
Hi Jeyaprakash,
Can you share these source code files with me? I will review and add temperature ramp initialization code.
Lucas
Hi Lucas,
Kernel version 6.12.17.
// SPDX-License-Identifier: GPL-2.0
* Driver for the Texas Instruments DS90UB953 video serializer
* Based on a driver from Luca Ceresoli <luca@lucaceresoli.net>
* Copyright (c) 2019 Luca Ceresoli <luca@lucaceresoli.net>
* Copyright (c) 2023 Tomi Valkeinen <tomi.valkeinen@ideasonboard.com>
#include <linux/clk-provider.h>
#include <linux/clk.h>
#include <linux/delay.h>
#include <linux/fwnode.h>
#include <linux/gpio/driver.h>
#include <linux/i2c-atr.h>
#include <linux/i2c.h>
#include <linux/kernel.h>
#include <linux/math64.h>
#include <linux/module.h>
#include <linux/property.h>
#include <linux/rational.h>
#include <linux/regmap.h>
#include <media/i2c/ds90ub9xx.h>
#include <media/v4l2-ctrls.h>
#include <media/v4l2-event.h>
#include <media/v4l2-fwnode.h>
#include <media/v4l2-mediabus.h>
#include <media/v4l2-subdev.h>
#define UB953_PAD_SINK 0
#define UB953_PAD_SOURCE 1
#define UB953_NUM_GPIOS 4
#define UB953_DEFAULT_CLKOUT_RATE 25000000UL
#define UB953_REG_RESET_CTL 0x01
#define UB953_REG_RESET_CTL_DIGITAL_RESET_1 BIT(1)
#define UB953_REG_RESET_CTL_DIGITAL_RESET_0 BIT(0)
#define UB953_REG_GENERAL_CFG 0x02
#define UB953_REG_GENERAL_CFG_CONT_CLK BIT(6)
#define UB953_REG_GENERAL_CFG_CSI_LANE_SEL_SHIFT 4
#define UB953_REG_GENERAL_CFG_CSI_LANE_SEL_MASK GENMASK(5, 4)
#define UB953_REG_GENERAL_CFG_CRC_TX_GEN_ENABLE BIT(1)
#define UB953_REG_GENERAL_CFG_I2C_STRAP_MODE BIT(0)
#define UB953_REG_MODE_SEL 0x03
#define UB953_REG_MODE_SEL_MODE_DONE BIT(3)
#define UB953_REG_MODE_SEL_MODE_OVERRIDE BIT(4)
#define UB953_REG_MODE_SEL_MODE_MASK GENMASK(2, 0)
#define UB953_REG_CLKOUT_CTRL0 0x06
#define UB953_REG_CLKOUT_CTRL1 0x07
#define UB953_REG_SCL_HIGH_TIME 0x0b
#define UB953_REG_SCL_LOW_TIME 0x0c
#define UB953_REG_LOCAL_GPIO_DATA 0x0d
#define UB953_REG_LOCAL_GPIO_DATA_GPIO_RMTEN(n) BIT(4 + (n))
#define UB953_REG_LOCAL_GPIO_DATA_GPIO_OUT_SRC(n) BIT(0 + (n))
#define UB953_REG_GPIO_INPUT_CTRL 0x0e
#define UB953_REG_GPIO_INPUT_CTRL_OUT_EN(n) BIT(4 + (n))
#define UB953_REG_GPIO_INPUT_CTRL_INPUT_EN(n) BIT(0 + (n))
#define UB953_REG_REV_MASK_ID 0x50
#define UB953_REG_GENERAL_STATUS 0x52
#define UB953_REG_GPIO_PIN_STS 0x53
#define UB953_REG_GPIO_PIN_STS_GPIO_STS(n) BIT(0 + (n))
#define UB953_REG_BIST_ERR_CNT 0x54
#define UB953_REG_CRC_ERR_CNT1 0x55
#define UB953_REG_CRC_ERR_CNT2 0x56
#define UB953_REG_CSI_ERR_CNT 0x5c
#define UB953_REG_CSI_ERR_STATUS 0x5d
#define UB953_REG_CSI_ERR_DLANE01 0x5e
#define UB953_REG_CSI_ERR_DLANE23 0x5f
#define UB953_REG_CSI_ERR_CLK_LANE 0x60
#define UB953_REG_CSI_PKT_HDR_VC_ID 0x61
#define UB953_REG_PKT_HDR_WC_LSB 0x62
#define UB953_REG_PKT_HDR_WC_MSB 0x63
#define UB953_REG_CSI_ECC 0x64
#define UB953_REG_IND_ACC_CTL 0xb0
#define UB953_REG_IND_ACC_ADDR 0xb1
#define UB953_REG_IND_ACC_DATA 0xb2
#define UB953_REG_FPD3_RX_ID(n) (0xf0 + (n))
#define UB953_REG_FPD3_RX_ID_LEN 6
/* Indirect register blocks */
#define UB953_IND_TARGET_PAT_GEN 0x00
#define UB953_IND_TARGET_FPD3_TX 0x01
#define UB953_IND_TARGET_DIE_ID 0x02
#define UB953_IND_PGEN_CTL 0x01
#define UB953_IND_PGEN_CTL_PGEN_ENABLE BIT(0)
#define UB953_IND_PGEN_CFG 0x02
#define UB953_IND_PGEN_CSI_DI 0x03
#define UB953_IND_PGEN_LINE_SIZE1 0x04
#define UB953_IND_PGEN_LINE_SIZE0 0x05
#define UB953_IND_PGEN_BAR_SIZE1 0x06
#define UB953_IND_PGEN_BAR_SIZE0 0x07
#define UB953_IND_PGEN_ACT_LPF1 0x08
#define UB953_IND_PGEN_ACT_LPF0 0x09
#define UB953_IND_PGEN_TOT_LPF1 0x0a
#define UB953_IND_PGEN_TOT_LPF0 0x0b
#define UB953_IND_PGEN_LINE_PD1 0x0c
#define UB953_IND_PGEN_LINE_PD0 0x0d
#define UB953_IND_PGEN_VBP 0x0e
#define UB953_IND_PGEN_VFP 0x0f
#define UB953_IND_PGEN_COLOR(n) (0x10 + (n)) /* n <= 15 */
/* Note: Only sync mode supported for now */
enum ub953_mode {
/* FPD-Link III CSI-2 synchronous mode */
UB953_MODE_SYNC,
/* FPD-Link III CSI-2 non-synchronous mode, external ref clock */
UB953_MODE_NONSYNC_EXT,
/* FPD-Link III CSI-2 non-synchronous mode, internal ref clock */
UB953_MODE_NONSYNC_INT,
/* FPD-Link III DVP mode */
UB953_MODE_DVP,
struct ub953_hw_data {
const char *model;
bool is_ub971;
struct ub953_clkout_data {
u32 hs_div;
u32 m;
u32 n;
unsigned long rate;
struct ub953_data {
const struct ub953_hw_data *hw_data;
struct i2c_client *client;
struct regmap *regmap;
struct clk *clkin;
u32 num_data_lanes;
bool non_continous_clk;
struct gpio_chip gpio_chip;
struct v4l2_subdev sd;
struct media_pad pads[2];
struct v4l2_async_notifier notifier;
struct v4l2_subdev *source_sd;
u16 source_sd_pad;
u64 enabled_source_streams;
/* lock for register access */
struct mutex reg_lock;
u8 current_indirect_target;
struct clk_hw clkout_clk_hw;
enum ub953_mode mode;
const struct ds90ub9xx_platform_data *plat_data;
static inline struct ub953_data *sd_to_ub953(struct v4l2_subdev *sd)
return container_of(sd, struct ub953_data, sd);
* HW Access
static int ub953_read(struct ub953_data *priv, u8 reg, u8 *val)
unsigned int v;
int ret;
mutex_lock(&priv->reg_lock);
ret = regmap_read(priv->regmap, reg, &v);
if (ret) {
dev_err(&priv->client->dev, "Cannot read register 0x%02x: %d\n",
reg, ret);
goto out_unlock;
*val = v;
out_unlock:
mutex_unlock(&priv->reg_lock);
return ret;
static int ub953_write(struct ub953_data *priv, u8 reg, u8 val)
int ret;
ret = regmap_write(priv->regmap, reg, val);
if (ret)
"Cannot write register 0x%02x: %d\n", reg, ret);
return ret;
static int ub953_select_ind_reg_block(struct ub953_data *priv, u8 block)
struct device *dev = &priv->client->dev;
int ret;
if (priv->current_indirect_target == block)
return 0;
ret = regmap_write(priv->regmap, UB953_REG_IND_ACC_CTL, block << 2);
if (ret) {
dev_err(dev, "%s: cannot select indirect target %u (%d)\n",
__func__, block, ret);
return ret;
priv->current_indirect_target = block;
return 0;
__maybe_unused
static int ub953_read_ind(struct ub953_data *priv, u8 block, u8 reg, u8 *val)
unsigned int v;
int ret;
ret = ub953_select_ind_reg_block(priv, block);
if (ret)
goto out_unlock;
ret = regmap_write(priv->regmap, UB953_REG_IND_ACC_ADDR, reg);
if (ret) {
"Write to IND_ACC_ADDR failed when reading %u:%x02x: %d\n",
block, reg, ret);
goto out_unlock;
ret = regmap_read(priv->regmap, UB953_REG_IND_ACC_DATA, &v);
if (ret) {
"Write to IND_ACC_DATA failed when reading %u:%x02x: %d\n",
block, reg, ret);
goto out_unlock;
*val = v;
out_unlock:
return ret;
__maybe_unused
static int ub953_write_ind(struct ub953_data *priv, u8 block, u8 reg, u8 val)
int ret;
if (ret)
goto out_unlock;
if (ret) {
"Write to IND_ACC_ADDR failed when writing %u:%x02x: %d\n",
block, reg, ret);
goto out_unlock;
ret = regmap_write(priv->regmap, UB953_REG_IND_ACC_DATA, val);
if (ret) {
"Write to IND_ACC_DATA failed when writing %u:%x02x\n: %d\n",
block, reg, ret);
out_unlock:
return ret;
* GPIO chip
static int ub953_gpio_get_direction(struct gpio_chip *gc, unsigned int offset)
struct ub953_data *priv = gpiochip_get_data(gc);
int ret;
u8 v;
ret = ub953_read(priv, UB953_REG_GPIO_INPUT_CTRL, &v);
if (ret)
return ret;
if (v & UB953_REG_GPIO_INPUT_CTRL_INPUT_EN(offset))
return GPIO_LINE_DIRECTION_IN;
else
return GPIO_LINE_DIRECTION_OUT;
static int ub953_gpio_direction_in(struct gpio_chip *gc, unsigned int offset)
return regmap_update_bits(priv->regmap, UB953_REG_GPIO_INPUT_CTRL,
UB953_REG_GPIO_INPUT_CTRL_INPUT_EN(offset) |
UB953_REG_GPIO_INPUT_CTRL_OUT_EN(offset),
UB953_REG_GPIO_INPUT_CTRL_INPUT_EN(offset));
static int ub953_gpio_direction_out(struct gpio_chip *gc, unsigned int offset,
int value)
int ret;
ret = regmap_update_bits(priv->regmap, UB953_REG_LOCAL_GPIO_DATA,
UB953_REG_LOCAL_GPIO_DATA_GPIO_OUT_SRC(offset),
value ? UB953_REG_LOCAL_GPIO_DATA_GPIO_OUT_SRC(offset) :
0);
if (ret)
return ret;
UB953_REG_GPIO_INPUT_CTRL_OUT_EN(offset));
static int ub953_gpio_get(struct gpio_chip *gc, unsigned int offset)
int ret;
u8 v;
ret = ub953_read(priv, UB953_REG_GPIO_PIN_STS, &v);
if (ret)
return ret;
return !!(v & UB953_REG_GPIO_PIN_STS_GPIO_STS(offset));
static void ub953_gpio_set(struct gpio_chip *gc, unsigned int offset, int value)
0);
static int ub953_gpio_of_xlate(struct gpio_chip *gc,
const struct of_phandle_args *gpiospec,
u32 *flags)
if (flags)
*flags = gpiospec->args[1];
return gpiospec->args[0];
static int ub953_gpiochip_probe(struct ub953_data *priv)
struct gpio_chip *gc = &priv->gpio_chip;
int ret;
/* Set all GPIOs to local input mode */
ret = ub953_write(priv, UB953_REG_LOCAL_GPIO_DATA, 0);
if (ret)
return ret;
ret = ub953_write(priv, UB953_REG_GPIO_INPUT_CTRL, 0xf);
if (ret)
return ret;
gc->label = dev_name(dev);
gc->parent = dev;
gc->owner = THIS_MODULE;
gc->base = -1;
gc->can_sleep = true;
gc->ngpio = UB953_NUM_GPIOS;
gc->get_direction = ub953_gpio_get_direction;
gc->direction_input = ub953_gpio_direction_in;
gc->direction_output = ub953_gpio_direction_out;
gc->get = ub953_gpio_get;
gc->set = ub953_gpio_set;
gc->of_xlate = ub953_gpio_of_xlate;
gc->of_gpio_n_cells = 2;
ret = gpiochip_add_data(gc, priv);
if (ret) {
dev_err(dev, "Failed to add GPIOs: %d\n", ret);
return ret;
return 0;
static void ub953_gpiochip_remove(struct ub953_data *priv)
gpiochip_remove(&priv->gpio_chip);
* V4L2
static int _ub953_set_routing(struct v4l2_subdev *sd,
struct v4l2_subdev_state *state,
struct v4l2_subdev_krouting *routing)
static const struct v4l2_mbus_framefmt format = {
.width = 640,
.height = 480,
.code = MEDIA_BUS_FMT_UYVY8_1X16,
.field = V4L2_FIELD_NONE,
.colorspace = V4L2_COLORSPACE_SRGB,
.ycbcr_enc = V4L2_YCBCR_ENC_601,
.quantization = V4L2_QUANTIZATION_LIM_RANGE,
.xfer_func = V4L2_XFER_FUNC_SRGB,
int ret;
* Note: we can only support up to V4L2_FRAME_DESC_ENTRY_MAX, until
* frame desc is made dynamically allocated.
if (routing->num_routes > V4L2_FRAME_DESC_ENTRY_MAX)
return -EINVAL;
ret = v4l2_subdev_routing_validate(sd, routing,
V4L2_SUBDEV_ROUTING_ONLY_1_TO_1);
if (ret)
return ret;
ret = v4l2_subdev_set_routing_with_fmt(sd, state, routing, &format);
if (ret)
return ret;
return 0;
static int ub953_set_routing(struct v4l2_subdev *sd,
enum v4l2_subdev_format_whence which,
struct ub953_data *priv = sd_to_ub953(sd);
if (which == V4L2_SUBDEV_FORMAT_ACTIVE && priv->enabled_source_streams)
return -EBUSY;
return _ub953_set_routing(sd, state, routing);
static int ub953_get_frame_desc(struct v4l2_subdev *sd, unsigned int pad,
struct v4l2_mbus_frame_desc *fd)
struct v4l2_mbus_frame_desc source_fd;
struct v4l2_subdev_route *route;
struct v4l2_subdev_state *state;
int ret;
if (pad != UB953_PAD_SOURCE)
return -EINVAL;
ret = v4l2_subdev_call(priv->source_sd, pad, get_frame_desc,
priv->source_sd_pad, &source_fd);
if (ret)
return ret;
fd->type = V4L2_MBUS_FRAME_DESC_TYPE_CSI2;
state = v4l2_subdev_lock_and_get_active_state(sd);
for_each_active_route(&state->routing, route) {
struct v4l2_mbus_frame_desc_entry *source_entry = NULL;
unsigned int i;
if (route->source_pad != pad)
continue;
for (i = 0; i < source_fd.num_entries; i++) {
if (source_fd.entry[i].stream == route->sink_stream) {
source_entry = &source_fd.entry[i];
break;
if (!source_entry) {
"Failed to find stream from source frame desc\n");
ret = -EPIPE;
goto out_unlock;
fd->entry[fd->num_entries].stream = route->source_stream;
fd->entry[fd->num_entries].flags = source_entry->flags;
fd->entry[fd->num_entries].length = source_entry->length;
fd->entry[fd->num_entries].pixelcode = source_entry->pixelcode;
fd->entry[fd->num_entries].bus.csi2.vc =
source_entry->bus.csi2.vc;
fd->entry[fd->num_entries].bus.csi2.dt =
source_entry->bus.csi2.dt;
fd->num_entries++;
out_unlock:
v4l2_subdev_unlock_state(state);
return ret;
static int ub953_set_fmt(struct v4l2_subdev *sd,
struct v4l2_subdev_format *format)
struct v4l2_mbus_framefmt *fmt;
if (format->which == V4L2_SUBDEV_FORMAT_ACTIVE &&
return -EBUSY;
/* No transcoding, source and sink formats must match. */
if (format->pad == UB953_PAD_SOURCE)
return v4l2_subdev_get_fmt(sd, state, format);
/* Set sink format */
fmt = v4l2_subdev_state_get_format(state, format->pad, format->stream);
if (!fmt)
return -EINVAL;
*fmt = format->format;
/* Propagate to source format */
fmt = v4l2_subdev_state_get_opposite_stream_format(state, format->pad,
format->stream);
if (!fmt)
return -EINVAL;
return 0;
static int ub953_init_state(struct v4l2_subdev *sd,
struct v4l2_subdev_state *state)
struct v4l2_subdev_route routes[] = {
.sink_pad = UB953_PAD_SINK,
.sink_stream = 0,
.source_pad = UB953_PAD_SOURCE,
.source_stream = 0,
.flags = V4L2_SUBDEV_ROUTE_FL_ACTIVE,
struct v4l2_subdev_krouting routing = {
.num_routes = ARRAY_SIZE(routes),
.routes = routes,
return _ub953_set_routing(sd, state, &routing);
static int ub953_log_status(struct v4l2_subdev *sd)
u8 v = 0, v1 = 0, v2 = 0;
unsigned int i;
char id[UB953_REG_FPD3_RX_ID_LEN];
u8 gpio_local_data = 0;
u8 gpio_input_ctrl = 0;
u8 gpio_pin_sts = 0;
for (i = 0; i < sizeof(id); i++)
ub953_read(priv, UB953_REG_FPD3_RX_ID(i), &id[i]);
dev_info(dev, "ID '%.*s'\n", (int)sizeof(id), id);
ub953_read(priv, UB953_REG_GENERAL_STATUS, &v);
dev_info(dev, "GENERAL_STATUS %#02x\n", v);
ub953_read(priv, UB953_REG_CRC_ERR_CNT1, &v1);
ub953_read(priv, UB953_REG_CRC_ERR_CNT2, &v2);
dev_info(dev, "CRC error count %u\n", v1 | (v2 << 8));
ub953_read(priv, UB953_REG_CSI_ERR_CNT, &v);
dev_info(dev, "CSI error count %u\n", v);
ub953_read(priv, UB953_REG_CSI_ERR_STATUS, &v);
dev_info(dev, "CSI_ERR_STATUS %#02x\n", v);
ub953_read(priv, UB953_REG_CSI_ERR_DLANE01, &v);
dev_info(dev, "CSI_ERR_DLANE01 %#02x\n", v);
ub953_read(priv, UB953_REG_CSI_ERR_DLANE23, &v);
dev_info(dev, "CSI_ERR_DLANE23 %#02x\n", v);
ub953_read(priv, UB953_REG_CSI_ERR_CLK_LANE, &v);
dev_info(dev, "CSI_ERR_CLK_LANE %#02x\n", v);
ub953_read(priv, UB953_REG_CSI_PKT_HDR_VC_ID, &v);
dev_info(dev, "CSI packet header VC %u ID %u\n", v >> 6, v & 0x3f);
ub953_read(priv, UB953_REG_PKT_HDR_WC_LSB, &v1);
ub953_read(priv, UB953_REG_PKT_HDR_WC_MSB, &v2);
dev_info(dev, "CSI packet header WC %u\n", (v2 << 8) | v1);
ub953_read(priv, UB953_REG_CSI_ECC, &v);
dev_info(dev, "CSI ECC %#02x\n", v);
ub953_read(priv, UB953_REG_LOCAL_GPIO_DATA, &gpio_local_data);
ub953_read(priv, UB953_REG_GPIO_INPUT_CTRL, &gpio_input_ctrl);
ub953_read(priv, UB953_REG_GPIO_PIN_STS, &gpio_pin_sts);
for (i = 0; i < UB953_NUM_GPIOS; i++) {
dev_info(dev,
"GPIO%u: remote: %u is_input: %u is_output: %u val: %u sts: %u\n",
i,
!!(gpio_local_data & UB953_REG_LOCAL_GPIO_DATA_GPIO_RMTEN(i)),
!!(gpio_input_ctrl & UB953_REG_GPIO_INPUT_CTRL_INPUT_EN(i)),
!!(gpio_input_ctrl & UB953_REG_GPIO_INPUT_CTRL_OUT_EN(i)),
!!(gpio_local_data & UB953_REG_LOCAL_GPIO_DATA_GPIO_OUT_SRC(i)),
!!(gpio_pin_sts & UB953_REG_GPIO_PIN_STS_GPIO_STS(i)));
return 0;
static int ub953_enable_streams(struct v4l2_subdev *sd,
struct v4l2_subdev_state *state, u32 pad,
u64 streams_mask)
u64 sink_streams;
int ret;
sink_streams = v4l2_subdev_state_xlate_streams(state, UB953_PAD_SOURCE,
UB953_PAD_SINK,
&streams_mask);
ret = v4l2_subdev_enable_streams(priv->source_sd, priv->source_sd_pad,
sink_streams);
if (ret)
return ret;
priv->enabled_source_streams |= streams_mask;
return 0;
static int ub953_disable_streams(struct v4l2_subdev *sd,
u64 streams_mask)
u64 sink_streams;
int ret;
UB953_PAD_SINK,
&streams_mask);
ret = v4l2_subdev_disable_streams(priv->source_sd, priv->source_sd_pad,
sink_streams);
if (ret)
return ret;
priv->enabled_source_streams &= ~streams_mask;
return 0;
static const struct v4l2_subdev_pad_ops ub953_pad_ops = {
.enable_streams = ub953_enable_streams,
.disable_streams = ub953_disable_streams,
.set_routing = ub953_set_routing,
.get_frame_desc = ub953_get_frame_desc,
.get_fmt = v4l2_subdev_get_fmt,
.set_fmt = ub953_set_fmt,
static const struct v4l2_subdev_core_ops ub953_subdev_core_ops = {
.log_status = ub953_log_status,
.subscribe_event = v4l2_ctrl_subdev_subscribe_event,
.unsubscribe_event = v4l2_event_subdev_unsubscribe,
static const struct v4l2_subdev_ops ub953_subdev_ops = {
.core = &ub953_subdev_core_ops,
.pad = &ub953_pad_ops,
static const struct v4l2_subdev_internal_ops ub953_internal_ops = {
.init_state = ub953_init_state,
static const struct media_entity_operations ub953_entity_ops = {
.link_validate = v4l2_subdev_link_validate,
static int ub953_notify_bound(struct v4l2_async_notifier *notifier,
struct v4l2_subdev *source_subdev,
struct v4l2_async_connection *asd)
struct ub953_data *priv = sd_to_ub953(notifier->sd);
int ret;
ret = media_entity_get_fwnode_pad(&source_subdev->entity,
source_subdev->fwnode,
MEDIA_PAD_FL_SOURCE);
if (ret < 0) {
dev_err(dev, "Failed to find pad for %s\n",
source_subdev->name);
return ret;
priv->source_sd = source_subdev;
priv->source_sd_pad = ret;
ret = media_create_pad_link(&source_subdev->entity, priv->source_sd_pad,
&priv->sd.entity, 0,
MEDIA_LNK_FL_ENABLED |
MEDIA_LNK_FL_IMMUTABLE);
if (ret) {
dev_err(dev, "Unable to link %s:%u -> %s:0\n",
source_subdev->name, priv->source_sd_pad,
priv->sd.name);
return ret;
return 0;
static const struct v4l2_async_notifier_operations ub953_notify_ops = {
.bound = ub953_notify_bound,
static int ub953_v4l2_notifier_register(struct ub953_data *priv)
struct v4l2_async_connection *asd;
struct fwnode_handle *ep_fwnode;
int ret;
ep_fwnode = fwnode_graph_get_endpoint_by_id(dev_fwnode(dev),
UB953_PAD_SINK, 0, 0);
if (!ep_fwnode) {
dev_err(dev, "No graph endpoint\n");
return -ENODEV;
v4l2_async_subdev_nf_init(&priv->notifier, &priv->sd);
asd = v4l2_async_nf_add_fwnode_remote(&priv->notifier, ep_fwnode,
struct v4l2_async_connection);
fwnode_handle_put(ep_fwnode);
if (IS_ERR(asd)) {
dev_err(dev, "Failed to add subdev: %ld", PTR_ERR(asd));
v4l2_async_nf_cleanup(&priv->notifier);
return PTR_ERR(asd);
priv->notifier.ops = &ub953_notify_ops;
ret = v4l2_async_nf_register(&priv->notifier);
if (ret) {
dev_err(dev, "Failed to register subdev_notifier");
return ret;
return 0;
static void ub953_v4l2_notifier_unregister(struct ub953_data *priv)
v4l2_async_nf_unregister(&priv->notifier);
* Probing
static int ub953_i2c_master_init(struct ub953_data *priv)
/* i2c fast mode */
u32 ref = 26250000;
u32 scl_high = 915; /* ns */
u32 scl_low = 1641; /* ns */
int ret;
scl_high = div64_u64((u64)scl_high * ref, 1000000000) - 5;
scl_low = div64_u64((u64)scl_low * ref, 1000000000) - 5;
ret = ub953_write(priv, UB953_REG_SCL_HIGH_TIME, scl_high);
if (ret)
return ret;
ret = ub953_write(priv, UB953_REG_SCL_LOW_TIME, scl_low);
if (ret)
return ret;
return 0;
static u64 ub953_get_fc_rate(struct ub953_data *priv)
switch (priv->mode) {
case UB953_MODE_SYNC:
if (priv->hw_data->is_ub971)
return priv->plat_data->bc_rate * 160ull;
else
return priv->plat_data->bc_rate / 2 * 160ull;
case UB953_MODE_NONSYNC_EXT:
/* CLKIN_DIV = 1 always */
return clk_get_rate(priv->clkin) * 80ull;
default:
/* Not supported */
return 0;
static unsigned long ub953_calc_clkout_ub953(struct ub953_data *priv,
unsigned long target, u64 fc,
u8 *hs_div, u8 *m, u8 *n)
* We always use 4 as a pre-divider (HS_CLK_DIV = 2).
* According to the datasheet:
* - "HS_CLK_DIV typically should be set to either 16, 8, or 4 (default)."
* - "if it is not possible to have an integer ratio of N/M, it is best to
* select a smaller value for HS_CLK_DIV.
* For above reasons the default HS_CLK_DIV seems the best in the average
* case. Use always that value to keep the code simple.
static const unsigned long hs_clk_div = 4;
u64 fc_divided;
unsigned long mul, div;
unsigned long res;
/* clkout = fc / hs_clk_div * m / n */
fc_divided = div_u64(fc, hs_clk_div);
rational_best_approximation(target, fc_divided, (1 << 5) - 1,
(1 << 8) - 1, &mul, &div);
res = div_u64(fc_divided * mul, div);
*hs_div = hs_clk_div;
*m = mul;
*n = div;
return res;
static unsigned long ub953_calc_clkout_ub971(struct ub953_data *priv,
u8 *m, u8 *n)
u64 fc_divided;
unsigned long res;
/* clkout = fc * m / (8 * n) */
fc_divided = div_u64(fc, 8);
*m = mul;
*n = div;
return res;
static void ub953_calc_clkout_params(struct ub953_data *priv,
unsigned long target_rate,
struct ub953_clkout_data *clkout_data)
unsigned long clkout_rate;
u64 fc_rate;
fc_rate = ub953_get_fc_rate(priv);
if (priv->hw_data->is_ub971) {
u8 m, n;
clkout_rate = ub953_calc_clkout_ub971(priv, target_rate,
fc_rate, &m, &n);
clkout_data->m = m;
clkout_data->n = n;
dev_dbg(dev, "%s %llu * %u / (8 * %u) = %lu (requested %lu)",
__func__, fc_rate, m, n, clkout_rate, target_rate);
} else {
u8 hs_div, m, n;
clkout_rate = ub953_calc_clkout_ub953(priv, target_rate,
fc_rate, &hs_div, &m, &n);
clkout_data->hs_div = hs_div;
clkout_data->m = m;
clkout_data->n = n;
dev_dbg(dev, "%s %llu / %u * %u / %u = %lu (requested %lu)",
__func__, fc_rate, hs_div, m, n, clkout_rate,
target_rate);
clkout_data->rate = clkout_rate;
static int ub953_write_clkout_regs(struct ub953_data *priv,
const struct ub953_clkout_data *clkout_data)
u8 clkout_ctrl0, clkout_ctrl1;
int ret;
clkout_ctrl0 = clkout_data->m;
else
clkout_ctrl0 = (__ffs(clkout_data->hs_div) << 5) |
clkout_data->m;
clkout_ctrl1 = clkout_data->n;
ret = ub953_write(priv, UB953_REG_CLKOUT_CTRL0, clkout_ctrl0);
if (ret)
return ret;
ret = ub953_write(priv, UB953_REG_CLKOUT_CTRL1, clkout_ctrl1);
if (ret)
return ret;
return 0;
static unsigned long ub953_clkout_recalc_rate(struct clk_hw *hw,
unsigned long parent_rate)
struct ub953_data *priv = container_of(hw, struct ub953_data, clkout_clk_hw);
u8 ctrl0, ctrl1;
u32 mul, div;
u64 fc_rate;
u32 hs_clk_div;
u64 rate;
int ret;
ret = ub953_read(priv, UB953_REG_CLKOUT_CTRL0, &ctrl0);
if (ret) {
dev_err(dev, "Failed to read CLKOUT_CTRL0: %d\n", ret);
return 0;
ret = ub953_read(priv, UB953_REG_CLKOUT_CTRL1, &ctrl1);
if (ret) {
dev_err(dev, "Failed to read CLKOUT_CTRL1: %d\n", ret);
return 0;
mul = ctrl0 & 0x1f;
div = ctrl1;
if (div == 0)
return 0;
rate = div_u64(fc_rate * mul, 8 * div);
dev_dbg(dev, "clkout: fc rate %llu, mul %u, div %u = %llu\n",
fc_rate, mul, div, rate);
} else {
mul = ctrl0 & 0x1f;
hs_clk_div = 1 << (ctrl0 >> 5);
div = ctrl1;
if (div == 0)
return 0;
rate = div_u64(div_u64(fc_rate, hs_clk_div) * mul, div);
dev_dbg(dev,
"clkout: fc rate %llu, hs_clk_div %u, mul %u, div %u = %llu\n",
fc_rate, hs_clk_div, mul, div, rate);
return rate;
static long ub953_clkout_round_rate(struct clk_hw *hw, unsigned long rate,
unsigned long *parent_rate)
struct ub953_clkout_data clkout_data;
ub953_calc_clkout_params(priv, rate, &clkout_data);
return clkout_data.rate;
static int ub953_clkout_set_rate(struct clk_hw *hw, unsigned long rate,
dev_dbg(&priv->client->dev, "%s %lu (requested %lu)\n", __func__,
clkout_data.rate, rate);
return ub953_write_clkout_regs(priv, &clkout_data);
static const struct clk_ops ub953_clkout_ops = {
.recalc_rate = ub953_clkout_recalc_rate,
.round_rate = ub953_clkout_round_rate,
.set_rate = ub953_clkout_set_rate,
static int ub953_register_clkout(struct ub953_data *priv)
const struct clk_init_data init = {
.name = kasprintf(GFP_KERNEL, "ds90%s.%s.clk_out",
priv->hw_data->model, dev_name(dev)),
.ops = &ub953_clkout_ops,
int ret;
if (!init.name)
return -ENOMEM;
/* Initialize clkout to 25MHz by default */
ub953_calc_clkout_params(priv, UB953_DEFAULT_CLKOUT_RATE, &clkout_data);
ret = ub953_write_clkout_regs(priv, &clkout_data);
if (ret)
return ret;
priv->clkout_clk_hw.init = &init;
ret = devm_clk_hw_register(dev, &priv->clkout_clk_hw);
kfree(init.name);
if (ret)
return dev_err_probe(dev, ret, "Cannot register clock HW\n");
ret = devm_of_clk_add_hw_provider(dev, of_clk_hw_simple_get,
if (ret)
"Cannot add OF clock provider\n");
return 0;
static int ub953_add_i2c_adapter(struct ub953_data *priv)
struct fwnode_handle *i2c_handle;
int ret;
i2c_handle = device_get_named_child_node(dev, "i2c");
if (!i2c_handle)
return 0;
ret = i2c_atr_add_adapter(priv->plat_data->atr, priv->plat_data->port,
dev, i2c_handle);
fwnode_handle_put(i2c_handle);
if (ret)
return ret;
return 0;
static const struct regmap_config ub953_regmap_config = {
.name = "ds90ub953",
.reg_bits = 8,
.val_bits = 8,
.reg_format_endian = REGMAP_ENDIAN_DEFAULT,
.val_format_endian = REGMAP_ENDIAN_DEFAULT,
static int ub953_parse_dt(struct ub953_data *priv)
struct v4l2_fwnode_endpoint vep = {
.bus_type = V4L2_MBUS_CSI2_DPHY,
unsigned char nlanes;
int ret;
if (!ep_fwnode)
return dev_err_probe(dev, -ENOENT, "no endpoint found\n");
ret = v4l2_fwnode_endpoint_parse(ep_fwnode, &vep);
if (ret)
"failed to parse sink endpoint data\n");
nlanes = vep.bus.mipi_csi2.num_data_lanes;
if (nlanes != 1 && nlanes != 2 && nlanes != 4)
return dev_err_probe(dev, -EINVAL,
"bad number of data-lanes: %u\n", nlanes);
priv->num_data_lanes = nlanes;
priv->non_continous_clk = vep.bus.mipi_csi2.flags &
V4L2_MBUS_CSI2_NONCONTINUOUS_CLOCK;
return 0;
static int ub953_hw_init(struct ub953_data *priv)
bool mode_override;
int ret;
u8 v;
ret = ub953_read(priv, UB953_REG_MODE_SEL, &v);
if (ret)
return ret;
if (!(v & UB953_REG_MODE_SEL_MODE_DONE))
return dev_err_probe(dev, -EIO, "Mode value not stabilized\n");
mode_override = v & UB953_REG_MODE_SEL_MODE_OVERRIDE;
switch (v & UB953_REG_MODE_SEL_MODE_MASK) {
case 0:
priv->mode = UB953_MODE_SYNC;
break;
case 2:
priv->mode = UB953_MODE_NONSYNC_EXT;
break;
case 3:
priv->mode = UB953_MODE_NONSYNC_INT;
break;
case 5:
priv->mode = UB953_MODE_DVP;
break;
default:
"Invalid mode in mode register\n");
dev_dbg(dev, "mode from %s: %#x\n", mode_override ? "reg" : "strap",
priv->mode);
if (priv->mode != UB953_MODE_SYNC &&
priv->mode != UB953_MODE_NONSYNC_EXT)
return dev_err_probe(dev, -ENODEV,
"Unsupported mode selected: %u\n",
priv->mode);
if (priv->mode == UB953_MODE_NONSYNC_EXT && !priv->clkin)
"clkin required for non-sync ext mode\n");
ret = ub953_read(priv, UB953_REG_REV_MASK_ID, &v);
if (ret)
return dev_err_probe(dev, ret, "Failed to read revision");
dev_info(dev, "Found %s rev/mask %#04x\n", priv->hw_data->model, v);
ret = ub953_read(priv, UB953_REG_GENERAL_CFG, &v);
if (ret)
return ret;
dev_dbg(dev, "i2c strap setting %s V\n",
(v & UB953_REG_GENERAL_CFG_I2C_STRAP_MODE) ? "1.8" : "3.3");
ret = ub953_i2c_master_init(priv);
if (ret)
return dev_err_probe(dev, ret, "i2c init failed\n");
v = 0;
v |= priv->non_continous_clk ? 0 : UB953_REG_GENERAL_CFG_CONT_CLK;
v |= (priv->num_data_lanes - 1) <<
UB953_REG_GENERAL_CFG_CSI_LANE_SEL_SHIFT;
v |= UB953_REG_GENERAL_CFG_CRC_TX_GEN_ENABLE;
ret = ub953_write(priv, UB953_REG_GENERAL_CFG, v);
if (ret)
return ret;
return 0;
static int ub953_subdev_init(struct ub953_data *priv)
int ret;
v4l2_i2c_subdev_init(&priv->sd, priv->client, &ub953_subdev_ops);
priv->sd.internal_ops = &ub953_internal_ops;
priv->sd.flags |= V4L2_SUBDEV_FL_HAS_DEVNODE |
V4L2_SUBDEV_FL_HAS_EVENTS | V4L2_SUBDEV_FL_STREAMS;
priv->sd.entity.function = MEDIA_ENT_F_VID_IF_BRIDGE;
priv->sd.entity.ops = &ub953_entity_ops;
priv->pads[0].flags = MEDIA_PAD_FL_SINK;
priv->pads[1].flags = MEDIA_PAD_FL_SOURCE;
ret = media_entity_pads_init(&priv->sd.entity, 2, priv->pads);
if (ret)
return dev_err_probe(dev, ret, "Failed to init pads\n");
ret = v4l2_subdev_init_finalize(&priv->sd);
if (ret)
goto err_entity_cleanup;
ret = ub953_v4l2_notifier_register(priv);
if (ret) {
"v4l2 subdev notifier register failed\n");
goto err_free_state;
ret = v4l2_async_register_subdev(&priv->sd);
if (ret) {
dev_err_probe(dev, ret, "v4l2_async_register_subdev error\n");
goto err_unreg_notif;
return 0;
err_unreg_notif:
ub953_v4l2_notifier_unregister(priv);
err_free_state:
v4l2_subdev_cleanup(&priv->sd);
err_entity_cleanup:
media_entity_cleanup(&priv->sd.entity);
return ret;
static void ub953_subdev_uninit(struct ub953_data *priv)
v4l2_async_unregister_subdev(&priv->sd);
static int ub953_probe(struct i2c_client *client)
struct device *dev = &client->dev;
struct ub953_data *priv;
int ret;
priv = devm_kzalloc(dev, sizeof(*priv), GFP_KERNEL);
if (!priv)
return -ENOMEM;
priv->client = client;
priv->hw_data = device_get_match_data(dev);
priv->plat_data = dev_get_platdata(&client->dev);
if (!priv->plat_data)
return dev_err_probe(dev, -ENODEV, "Platform data missing\n");
mutex_init(&priv->reg_lock);
* Initialize to invalid values so that the first reg writes will
* configure the target.
priv->current_indirect_target = 0xff;
priv->regmap = devm_regmap_init_i2c(client, &ub953_regmap_config);
if (IS_ERR(priv->regmap)) {
ret = PTR_ERR(priv->regmap);
dev_err_probe(dev, ret, "Failed to init regmap\n");
goto err_mutex_destroy;
priv->clkin = devm_clk_get_optional(dev, "clkin");
if (IS_ERR(priv->clkin)) {
ret = PTR_ERR(priv->clkin);
dev_err_probe(dev, ret, "failed to parse 'clkin'\n");
ret = ub953_parse_dt(priv);
if (ret)
ret = ub953_hw_init(priv);
if (ret)
ret = ub953_gpiochip_probe(priv);
if (ret) {
dev_err_probe(dev, ret, "Failed to init gpiochip\n");
ret = ub953_register_clkout(priv);
if (ret) {
dev_err_probe(dev, ret, "Failed to register clkout\n");
goto err_gpiochip_remove;
ret = ub953_subdev_init(priv);
if (ret)
ret = ub953_add_i2c_adapter(priv);
if (ret) {
dev_err_probe(dev, ret, "failed to add remote i2c adapter\n");
goto err_subdev_uninit;
return 0;
err_subdev_uninit:
ub953_subdev_uninit(priv);
err_gpiochip_remove:
ub953_gpiochip_remove(priv);
err_mutex_destroy:
mutex_destroy(&priv->reg_lock);
return ret;
static void ub953_remove(struct i2c_client *client)
struct v4l2_subdev *sd = i2c_get_clientdata(client);
i2c_atr_del_adapter(priv->plat_data->atr, priv->plat_data->port);
static const struct ub953_hw_data ds90ub953_hw = {
.model = "ub953",
static const struct ub953_hw_data ds90ub971_hw = {
.model = "ub971",
.is_ub971 = true,
static const struct i2c_device_id ub953_id[] = {
{ "ds90ub953-q1", (kernel_ulong_t)&ds90ub953_hw },
{ "ds90ub971-q1", (kernel_ulong_t)&ds90ub971_hw },
MODULE_DEVICE_TABLE(i2c, ub953_id);
static const struct of_device_id ub953_dt_ids[] = {
{ .compatible = "ti,ds90ub953-q1", .data = &ds90ub953_hw },
{ .compatible = "ti,ds90ub971-q1", .data = &ds90ub971_hw },
MODULE_DEVICE_TABLE(of, ub953_dt_ids);
static struct i2c_driver ds90ub953_driver = {
.probe = ub953_probe,
.remove = ub953_remove,
.id_table = ub953_id,
.driver = {
.of_match_table = ub953_dt_ids,
module_i2c_driver(ds90ub953_driver);
MODULE_LICENSE("GPL");
MODULE_DESCRIPTION("Texas Instruments FPD-Link III/IV CSI-2 Serializers Driver");
MODULE_AUTHOR("Luca Ceresoli <luca@lucaceresoli.net>");
MODULE_AUTHOR("Tomi Valkeinen <tomi.valkeinen@ideasonboard.com>");
MODULE_IMPORT_NS(I2C_ATR);
* Driver for the Texas Instruments DS90UB960-Q1 video deserializer
* (Possible) TODOs:
* - PM for serializer and remote peripherals. We need to manage:
* - VPOC
* - Power domain? Regulator? Somehow any remote device should be able to
* cause the VPOC to be turned on.
* - Link between the deserializer and the serializer
* - Related to VPOC management. We probably always want to turn on the VPOC
* and then enable the link.
* - Serializer's services: i2c, gpios, power
* - The serializer needs to resume before the remote peripherals can
* e.g. use the i2c.
* - How to handle gpios? Reserving a gpio essentially keeps the provider
* (serializer) always powered on.
* - Do we need a new bus for the FPD-Link? At the moment the serializers
* are children of the same i2c-adapter where the deserializer resides.
* - i2c-atr could be made embeddable instead of allocatable.
#include <linux/bitops.h>
#include <linux/bitfield.h>
#include <linux/gpio/consumer.h>
#include <linux/init.h>
#include <linux/interrupt.h>
#include <linux/kthread.h>
#include <linux/mutex.h>
#include <linux/regulator/consumer.h>
#include <linux/slab.h>
#include <linux/workqueue.h>
#include <media/mipi-csi2.h>
#define MHZ(v) ((u32)((v) * 1000000U))
#define UB960_POLL_TIME_MS 500
#define UB960_MAX_RX_NPORTS 4
#define UB960_MAX_TX_NPORTS 2
#define UB960_MAX_NPORTS (UB960_MAX_RX_NPORTS + UB960_MAX_TX_NPORTS)
#define UB960_MAX_VC 4
#define UB960_MAX_PORT_ALIASES 8
#define UB960_NUM_BC_GPIOS 4
#define UB960_CSI_TX0 BIT(4)
* Register map
* 0x00-0x32 Shared (UB960_SR)
* 0x33-0x3a CSI-2 TX (per-port paged on DS90UB960, shared on 954) (UB960_TR)
* 0x4c Shared (UB960_SR)
* 0x4d-0x7f FPD-Link RX, per-port paged (UB960_RR)
* 0xb0-0xbf Shared (UB960_SR)
* 0xd0-0xdf FPD-Link RX, per-port paged (UB960_RR)
* 0xf0-0xf5 Shared (UB960_SR)
* 0xf8-0xfb Shared (UB960_SR)
* All others Reserved
* Register prefixes:
* UB960_SR_* = Shared register
* UB960_RR_* = FPD-Link RX, per-port paged register
* UB960_TR_* = CSI-2 TX, per-port paged register
* UB960_XR_* = Reserved register
* UB960_IR_* = Indirect register
#define UB960_SR_I2C_DEV_ID 0x00
#define UB960_SR_RESET 0x01
#define UB960_SR_RESET_DIGITAL_RESET1 BIT(1)
#define UB960_SR_RESET_DIGITAL_RESET0 BIT(0)
#define UB960_SR_RESET_GPIO_LOCK_RELEASE BIT(5)
#define UB960_SR_GEN_CONFIG 0x02
#define UB960_SR_REV_MASK 0x03
#define UB960_SR_DEVICE_STS 0x04
#define UB960_SR_PAR_ERR_THOLD_HI 0x05
#define UB960_SR_PAR_ERR_THOLD_LO 0x06
#define UB960_SR_BCC_WDOG_CTL 0x07
#define UB960_SR_I2C_CTL1 0x08
#define UB960_SR_I2C_CTL2 0x09
#define UB960_SR_SCL_HIGH_TIME 0x0a
#define UB960_SR_SCL_LOW_TIME 0x0b
#define UB960_SR_RX_PORT_CTL 0x0c
#define UB960_SR_RX_PORT_CTL_BCC_MAP GENMASK(7, 4)
#define UB960_SR_IO_CTL 0x0d
#define UB960_SR_GPIO_PIN_STS 0x0e
#define UB960_SR_GPIO_INPUT_CTL 0x0f
#define UB960_SR_GPIO_PIN_CTL(n) (0x10 + (n)) /* n < UB960_NUM_GPIOS */
#define UB960_SR_GPIO_PIN_CTL_GPIO_OUT_SEL 5
#define UB960_SR_GPIO_PIN_CTL_GPIO_OUT_SRC_SHIFT 2
#define UB960_SR_GPIO_PIN_CTL_GPIO_OUT_EN BIT(0)
#define UB960_SR_FS_CTL 0x18
#define UB960_SR_FS_HIGH_TIME_1 0x19
#define UB960_SR_FS_HIGH_TIME_0 0x1a
#define UB960_SR_FS_LOW_TIME_1 0x1b
#define UB960_SR_FS_LOW_TIME_0 0x1c
#define UB960_SR_MAX_FRM_HI 0x1d
#define UB960_SR_MAX_FRM_LO 0x1e
#define UB960_SR_CSI_PLL_CTL 0x1f
#define UB960_SR_FWD_CTL1 0x20
#define UB960_SR_FWD_CTL1_PORT_DIS(n) BIT((n) + 4)
#define UB960_SR_FWD_CTL2 0x21
#define UB960_SR_FWD_STS 0x22
#define UB960_SR_INTERRUPT_CTL 0x23
#define UB960_SR_INTERRUPT_CTL_INT_EN BIT(7)
#define UB960_SR_INTERRUPT_CTL_IE_CSI_TX0 BIT(4)
#define UB960_SR_INTERRUPT_CTL_IE_RX(n) BIT((n)) /* rxport[n] IRQ */
#define UB960_SR_INTERRUPT_STS 0x24
#define UB960_SR_INTERRUPT_STS_INT BIT(7)
#define UB960_SR_INTERRUPT_STS_IS_CSI_TX(n) BIT(4 + (n)) /* txport[n] IRQ */
#define UB960_SR_INTERRUPT_STS_IS_RX(n) BIT((n)) /* rxport[n] IRQ */
#define UB960_SR_TS_CONFIG 0x25
#define UB960_SR_TS_CONTROL 0x26
#define UB960_SR_TS_LINE_HI 0x27
#define UB960_SR_TS_LINE_LO 0x28
#define UB960_SR_TS_STATUS 0x29
#define UB960_SR_TIMESTAMP_P0_HI 0x2a
#define UB960_SR_TIMESTAMP_P0_LO 0x2b
#define UB960_SR_TIMESTAMP_P1_HI 0x2c
#define UB960_SR_TIMESTAMP_P1_LO 0x2d
#define UB960_SR_CSI_PORT_SEL 0x32
#define UB960_TR_CSI_CTL 0x33
#define UB960_TR_CSI_CTL_CSI_CAL_EN BIT(6)
#define UB960_TR_CSI_CTL_CSI_CONTS_CLOCK BIT(1)
#define UB960_TR_CSI_CTL_CSI_ENABLE BIT(0)
#define UB960_TR_CSI_CTL2 0x34
#define UB960_TR_CSI_STS 0x35
#define UB960_TR_CSI_TX_ICR 0x36
#define UB960_TR_CSI_TX_ISR 0x37
#define UB960_TR_CSI_TX_ISR_IS_CSI_SYNC_ERROR BIT(3)
#define UB960_TR_CSI_TX_ISR_IS_CSI_PASS_ERROR BIT(1)
#define UB960_TR_CSI_TEST_CTL 0x38
#define UB960_TR_CSI_TEST_PATT_HI 0x39
#define UB960_TR_CSI_TEST_PATT_LO 0x3a
#define UB960_XR_SFILTER_CFG 0x41
#define UB960_XR_SFILTER_CFG_SFILTER_MAX_SHIFT 4
#define UB960_XR_SFILTER_CFG_SFILTER_MIN_SHIFT 0
#define UB960_XR_AEQ_CTL1 0x42
#define UB960_XR_AEQ_CTL1_AEQ_ERR_CTL_FPD_CLK BIT(6)
#define UB960_XR_AEQ_CTL1_AEQ_ERR_CTL_ENCODING BIT(5)
#define UB960_XR_AEQ_CTL1_AEQ_ERR_CTL_PARITY BIT(4)
#define UB960_XR_AEQ_CTL1_AEQ_ERR_CTL_MASK \
(UB960_XR_AEQ_CTL1_AEQ_ERR_CTL_FPD_CLK | \
UB960_XR_AEQ_CTL1_AEQ_ERR_CTL_ENCODING | \
UB960_XR_AEQ_CTL1_AEQ_ERR_CTL_PARITY)
#define UB960_XR_AEQ_CTL1_AEQ_SFILTER_EN BIT(0)
#define UB960_XR_AEQ_ERR_THOLD 0x43
#define UB960_RR_BCC_ERR_CTL 0x46
#define UB960_RR_BCC_STATUS 0x47
#define UB960_RR_BCC_STATUS_SEQ_ERROR BIT(5)
#define UB960_RR_BCC_STATUS_MASTER_ERR BIT(4)
#define UB960_RR_BCC_STATUS_MASTER_TO BIT(3)
#define UB960_RR_BCC_STATUS_SLAVE_ERR BIT(2)
#define UB960_RR_BCC_STATUS_SLAVE_TO BIT(1)
#define UB960_RR_BCC_STATUS_RESP_ERR BIT(0)
#define UB960_RR_BCC_STATUS_ERROR_MASK \
(UB960_RR_BCC_STATUS_SEQ_ERROR | UB960_RR_BCC_STATUS_MASTER_ERR | \
UB960_RR_BCC_STATUS_MASTER_TO | UB960_RR_BCC_STATUS_SLAVE_ERR | \
UB960_RR_BCC_STATUS_SLAVE_TO | UB960_RR_BCC_STATUS_RESP_ERR)
#define UB960_RR_FPD3_CAP 0x4a
#define UB960_RR_RAW_EMBED_DTYPE 0x4b
#define UB960_RR_RAW_EMBED_DTYPE_LINES_SHIFT 6
#define UB960_SR_FPD3_PORT_SEL 0x4c
#define UB960_RR_RX_PORT_STS1 0x4d
#define UB960_RR_RX_PORT_STS1_BCC_CRC_ERROR BIT(5)
#define UB960_RR_RX_PORT_STS1_LOCK_STS_CHG BIT(4)
#define UB960_RR_RX_PORT_STS1_BCC_SEQ_ERROR BIT(3)
#define UB960_RR_RX_PORT_STS1_PARITY_ERROR BIT(2)
#define UB960_RR_RX_PORT_STS1_PORT_PASS BIT(1)
#define UB960_RR_RX_PORT_STS1_LOCK_STS BIT(0)
#define UB960_RR_RX_PORT_STS1_ERROR_MASK \
(UB960_RR_RX_PORT_STS1_BCC_CRC_ERROR | \
UB960_RR_RX_PORT_STS1_BCC_SEQ_ERROR | \
UB960_RR_RX_PORT_STS1_PARITY_ERROR)
#define UB960_RR_RX_PORT_STS2 0x4e
#define UB960_RR_RX_PORT_STS2_LINE_LEN_UNSTABLE BIT(7)
#define UB960_RR_RX_PORT_STS2_LINE_LEN_CHG BIT(6)
#define UB960_RR_RX_PORT_STS2_FPD3_ENCODE_ERROR BIT(5)
#define UB960_RR_RX_PORT_STS2_BUFFER_ERROR BIT(4)
#define UB960_RR_RX_PORT_STS2_CSI_ERROR BIT(3)
#define UB960_RR_RX_PORT_STS2_FREQ_STABLE BIT(2)
#define UB960_RR_RX_PORT_STS2_CABLE_FAULT BIT(1)
#define UB960_RR_RX_PORT_STS2_LINE_CNT_CHG BIT(0)
#define UB960_RR_RX_PORT_STS2_ERROR_MASK \
#define UB960_RR_RX_FREQ_HIGH 0x4f
#define UB960_RR_RX_FREQ_LOW 0x50
#define UB960_RR_SENSOR_STS_0 0x51
#define UB960_RR_SENSOR_STS_1 0x52
#define UB960_RR_SENSOR_STS_2 0x53
#define UB960_RR_SENSOR_STS_3 0x54
#define UB960_RR_RX_PAR_ERR_HI 0x55
#define UB960_RR_RX_PAR_ERR_LO 0x56
#define UB960_RR_BIST_ERR_COUNT 0x57
#define UB960_RR_BCC_CONFIG 0x58
#define UB960_RR_BCC_CONFIG_I2C_PASS_THROUGH BIT(6)
#define UB960_RR_BCC_CONFIG_BC_FREQ_SEL_MASK GENMASK(2, 0)
#define UB960_RR_DATAPATH_CTL1 0x59
#define UB960_RR_DATAPATH_CTL2 0x5a
#define UB960_RR_SER_ID 0x5b
#define UB960_RR_SER_ALIAS_ID 0x5c
/* For these two register sets: n < UB960_MAX_PORT_ALIASES */
#define UB960_RR_SLAVE_ID(n) (0x5d + (n))
#define UB960_RR_SLAVE_ALIAS(n) (0x65 + (n))
#define UB960_RR_PORT_CONFIG 0x6d
#define UB960_RR_PORT_CONFIG_FPD3_MODE_MASK GENMASK(1, 0)
#define UB960_RR_BC_GPIO_CTL(n) (0x6e + (n)) /* n < 2 */
#define UB960_RR_RAW10_ID 0x70
#define UB960_RR_RAW10_ID_VC_SHIFT 6
#define UB960_RR_RAW10_ID_DT_SHIFT 0
#define UB960_RR_RAW12_ID 0x71
#define UB960_RR_CSI_VC_MAP 0x72
#define UB960_RR_CSI_VC_MAP_SHIFT(x) ((x) * 2)
#define UB960_RR_LINE_COUNT_HI 0x73
#define UB960_RR_LINE_COUNT_LO 0x74
#define UB960_RR_LINE_LEN_1 0x75
#define UB960_RR_LINE_LEN_0 0x76
#define UB960_RR_FREQ_DET_CTL 0x77
#define UB960_RR_MAILBOX_1 0x78
#define UB960_RR_MAILBOX_2 0x79
#define UB960_RR_CSI_RX_STS 0x7a
#define UB960_RR_CSI_RX_STS_LENGTH_ERR BIT(3)
#define UB960_RR_CSI_RX_STS_CKSUM_ERR BIT(2)
#define UB960_RR_CSI_RX_STS_ECC2_ERR BIT(1)
#define UB960_RR_CSI_RX_STS_ECC1_ERR BIT(0)
#define UB960_RR_CSI_RX_STS_ERROR_MASK \
(UB960_RR_CSI_RX_STS_LENGTH_ERR | UB960_RR_CSI_RX_STS_CKSUM_ERR | \
UB960_RR_CSI_RX_STS_ECC2_ERR | UB960_RR_CSI_RX_STS_ECC1_ERR)
#define UB960_RR_CSI_ERR_COUNTER 0x7b
#define UB960_RR_PORT_CONFIG2 0x7c
#define UB960_RR_PORT_CONFIG2_RAW10_8BIT_CTL_MASK GENMASK(7, 6)
#define UB960_RR_PORT_CONFIG2_RAW10_8BIT_CTL_SHIFT 6
#define UB960_RR_PORT_CONFIG2_LV_POL_LOW BIT(1)
#define UB960_RR_PORT_CONFIG2_FV_POL_LOW BIT(0)
#define UB960_RR_PORT_PASS_CTL 0x7d
#define UB960_RR_SEN_INT_RISE_CTL 0x7e
#define UB960_RR_SEN_INT_FALL_CTL 0x7f
#define UB960_SR_CSI_FRAME_COUNT_HI(n) (0x90 + 8 * (n))
#define UB960_SR_CSI_FRAME_COUNT_LO(n) (0x91 + 8 * (n))
#define UB960_SR_CSI_FRAME_ERR_COUNT_HI(n) (0x92 + 8 * (n))
#define UB960_SR_CSI_FRAME_ERR_COUNT_LO(n) (0x93 + 8 * (n))
#define UB960_SR_CSI_LINE_COUNT_HI(n) (0x94 + 8 * (n))
#define UB960_SR_CSI_LINE_COUNT_LO(n) (0x95 + 8 * (n))
#define UB960_SR_CSI_LINE_ERR_COUNT_HI(n) (0x96 + 8 * (n))
#define UB960_SR_CSI_LINE_ERR_COUNT_LO(n) (0x97 + 8 * (n))
#define UB960_XR_REFCLK_FREQ 0xa5 /* UB960 */
#define UB960_RR_VC_ID_MAP(x) (0xa0 + (x)) /* UB9702 */
#define UB960_SR_IND_ACC_CTL 0xb0
#define UB960_SR_IND_ACC_CTL_IA_AUTO_INC BIT(1)
#define UB960_SR_IND_ACC_ADDR 0xb1
#define UB960_SR_IND_ACC_DATA 0xb2
#define UB960_SR_BIST_CONTROL 0xb3
#define UB960_SR_MODE_IDX_STS 0xb8
#define UB960_SR_LINK_ERROR_COUNT 0xb9
#define UB960_SR_FPD3_ENC_CTL 0xba
#define UB960_SR_FV_MIN_TIME 0xbc
#define UB960_SR_GPIO_PD_CTL 0xbe
#define UB960_SR_FPD_RATE_CFG 0xc2 /* UB9702 */
#define UB960_SR_CSI_PLL_DIV 0xc9 /* UB9702 */
#define UB960_RR_PORT_DEBUG 0xd0
#define UB960_RR_AEQ_CTL2 0xd2
#define UB960_RR_AEQ_CTL2_SET_AEQ_FLOOR BIT(2)
#define UB960_RR_AEQ_STATUS 0xd3
#define UB960_RR_AEQ_STATUS_STATUS_2 GENMASK(5, 3)
#define UB960_RR_AEQ_STATUS_STATUS_1 GENMASK(2, 0)
#define UB960_RR_AEQ_BYPASS 0xd4
#define UB960_RR_AEQ_BYPASS_EQ_STAGE1_VALUE_SHIFT 5
#define UB960_RR_AEQ_BYPASS_EQ_STAGE1_VALUE_MASK GENMASK(7, 5)
#define UB960_RR_AEQ_BYPASS_EQ_STAGE2_VALUE_SHIFT 1
#define UB960_RR_AEQ_BYPASS_EQ_STAGE2_VALUE_MASK GENMASK(3, 1)
#define UB960_RR_AEQ_BYPASS_ENABLE BIT(0)
#define UB960_RR_AEQ_MIN_MAX 0xd5
#define UB960_RR_AEQ_MIN_MAX_AEQ_MAX_SHIFT 4
#define UB960_RR_AEQ_MIN_MAX_AEQ_FLOOR_SHIFT 0
#define UB960_RR_SFILTER_STS_0 0xd6
#define UB960_RR_SFILTER_STS_1 0xd7
#define UB960_RR_PORT_ICR_HI 0xd8
#define UB960_RR_PORT_ICR_LO 0xd9
#define UB960_RR_PORT_ISR_HI 0xda
#define UB960_RR_PORT_ISR_LO 0xdb
#define UB960_RR_FC_GPIO_STS 0xdc
#define UB960_RR_FC_GPIO_ICR 0xdd
#define UB960_RR_SEN_INT_RISE_STS 0xde
#define UB960_RR_SEN_INT_FALL_STS 0xdf
#define UB960_RR_CHANNEL_MODE 0xe4 /* UB9702 */
#define UB960_SR_FPD3_RX_ID(n) (0xf0 + (n))
#define UB960_SR_FPD3_RX_ID_LEN 6
#define UB960_SR_I2C_RX_ID(n) (0xf8 + (n)) /* < UB960_FPD_RX_NPORTS */
#define UB9702_SR_REFCLK_FREQ 0x3d
#define UB960_IND_TARGET_PAT_GEN 0x00
#define UB960_IND_TARGET_RX_ANA(n) (0x01 + (n))
#define UB960_IND_TARGET_CSI_CSIPLL_REG_1 0x92 /* UB9702 */
#define UB960_IND_TARGET_CSI_ANA 0x07
/* UB960_IR_PGEN_*: Indirect Registers for Test Pattern Generator */
#define UB960_IR_PGEN_CTL 0x01
#define UB960_IR_PGEN_CTL_PGEN_ENABLE BIT(0)
#define UB960_IR_PGEN_CFG 0x02
#define UB960_IR_PGEN_CSI_DI 0x03
#define UB960_IR_PGEN_LINE_SIZE1 0x04
#define UB960_IR_PGEN_LINE_SIZE0 0x05
#define UB960_IR_PGEN_BAR_SIZE1 0x06
#define UB960_IR_PGEN_BAR_SIZE0 0x07
#define UB960_IR_PGEN_ACT_LPF1 0x08
#define UB960_IR_PGEN_ACT_LPF0 0x09
#define UB960_IR_PGEN_TOT_LPF1 0x0a
#define UB960_IR_PGEN_TOT_LPF0 0x0b
#define UB960_IR_PGEN_LINE_PD1 0x0c
#define UB960_IR_PGEN_LINE_PD0 0x0d
#define UB960_IR_PGEN_VBP 0x0e
#define UB960_IR_PGEN_VFP 0x0f
#define UB960_IR_PGEN_COLOR(n) (0x10 + (n)) /* n < 15 */
#define UB960_IR_RX_ANA_STROBE_SET_CLK 0x08
#define UB960_IR_RX_ANA_STROBE_SET_CLK_NO_EXTRA_DELAY BIT(3)
#define UB960_IR_RX_ANA_STROBE_SET_CLK_DELAY_MASK GENMASK(2, 0)
#define UB960_IR_RX_ANA_STROBE_SET_DATA 0x09
#define UB960_IR_RX_ANA_STROBE_SET_DATA_NO_EXTRA_DELAY BIT(3)
#define UB960_IR_RX_ANA_STROBE_SET_DATA_DELAY_MASK GENMASK(2, 0)
/* EQ related */
#define UB960_MIN_AEQ_STROBE_POS -7
#define UB960_MAX_AEQ_STROBE_POS 7
#define UB960_MANUAL_STROBE_EXTRA_DELAY 6
#define UB960_MIN_MANUAL_STROBE_POS -(7 + UB960_MANUAL_STROBE_EXTRA_DELAY)
#define UB960_MAX_MANUAL_STROBE_POS (7 + UB960_MANUAL_STROBE_EXTRA_DELAY)
#define UB960_NUM_MANUAL_STROBE_POS (UB960_MAX_MANUAL_STROBE_POS - UB960_MIN_MANUAL_STROBE_POS + 1)
#define UB960_MIN_EQ_LEVEL 0
#define UB960_MAX_EQ_LEVEL 14
#define UB960_NUM_EQ_LEVELS (UB960_MAX_EQ_LEVEL - UB960_MIN_EQ_LEVEL + 1)
struct ub960_hw_data {
const char *model;
u8 num_rxports;
u8 num_txports;
bool is_ub9702;
bool is_fpdlink4;
bool ignore_strobe_pos;
enum ub960_rxport_mode {
RXPORT_MODE_RAW10 = 0,
RXPORT_MODE_RAW12_HF = 1,
RXPORT_MODE_RAW12_LF = 2,
RXPORT_MODE_CSI2_SYNC = 3,
RXPORT_MODE_CSI2_NONSYNC = 4,
RXPORT_MODE_LAST = RXPORT_MODE_CSI2_NONSYNC,
enum ub960_rxport_cdr {
RXPORT_CDR_FPD3 = 0,
RXPORT_CDR_FPD4 = 1,
RXPORT_CDR_LAST = RXPORT_CDR_FPD4,
struct ub960_rxport {
struct ub960_data *priv;
u8 nport; /* RX port number, and index in priv->rxport[] */
struct {
struct v4l2_subdev *sd;
u16 pad;
} source;
/* Serializer */
struct {
struct fwnode_handle *fwnode;
unsigned short alias; /* I2C alias (lower 7 bits) */
struct ds90ub9xx_platform_data pdata;
} ser;
enum ub960_rxport_mode rx_mode;
enum ub960_rxport_cdr cdr_mode;
u8 lv_fv_pol; /* LV and FV polarities */
struct regulator *vpoc;
/* EQ settings */
struct {
bool manual_eq;
s8 strobe_pos;
union {
struct {
u8 eq_level_min;
u8 eq_level_max;
} aeq;
struct {
u8 eq_level;
} manual;
} eq;
const struct i2c_client *aliased_clients[UB960_MAX_PORT_ALIASES];
struct ub960_asd {
struct v4l2_async_connection base;
struct ub960_rxport *rxport;
static inline struct ub960_asd *to_ub960_asd(struct v4l2_async_connection *asd)
return container_of(asd, struct ub960_asd, base);
struct ub960_txport {
u8 nport; /* TX port number, and index in priv->txport[] */
u32 num_data_lanes;
struct ub960_data {
const struct ub960_hw_data *hw_data;
struct i2c_client *client; /* for shared local registers */
struct clk *refclk;
struct regulator *vddio;
struct gpio_desc *pd_gpio;
struct delayed_work poll_work;
struct ub960_rxport *rxports[UB960_MAX_RX_NPORTS];
struct ub960_txport *txports[UB960_MAX_TX_NPORTS];
struct media_pad pads[UB960_MAX_NPORTS];
struct v4l2_ctrl_handler ctrl_handler;
u32 tx_data_rate; /* Nominal data rate (Gb/s) */
s64 tx_link_freq[1];
u8 rx_mask;
u8 tx_mask;
struct i2c_atr *atr;
struct {
u8 rxport;
u8 txport;
u8 indirect_target;
} reg_current;
bool streaming;
u8 stored_fwd_ctl;
u64 stream_enable_mask[UB960_MAX_NPORTS];
/* These are common to all ports */
struct {
bool manual;
s8 min;
s8 max;
} strobe;
static inline struct ub960_data *sd_to_ub960(struct v4l2_subdev *sd)
return container_of(sd, struct ub960_data, sd);
static inline bool ub960_pad_is_sink(struct ub960_data *priv, u32 pad)
return pad < priv->hw_data->num_rxports;
static inline bool ub960_pad_is_source(struct ub960_data *priv, u32 pad)
return pad >= priv->hw_data->num_rxports;
static inline unsigned int ub960_pad_to_port(struct ub960_data *priv, u32 pad)
if (ub960_pad_is_sink(priv, pad))
return pad;
else
return pad - priv->hw_data->num_rxports;
struct ub960_format_info {
u32 code;
u32 bpp;
u8 datatype;
bool meta;
static const struct ub960_format_info ub960_formats[] = {
{ .code = MEDIA_BUS_FMT_YUYV8_1X16, .bpp = 16, .datatype = MIPI_CSI2_DT_YUV422_8B, },
{ .code = MEDIA_BUS_FMT_UYVY8_1X16, .bpp = 16, .datatype = MIPI_CSI2_DT_YUV422_8B, },
{ .code = MEDIA_BUS_FMT_VYUY8_1X16, .bpp = 16, .datatype = MIPI_CSI2_DT_YUV422_8B, },
{ .code = MEDIA_BUS_FMT_YVYU8_1X16, .bpp = 16, .datatype = MIPI_CSI2_DT_YUV422_8B, },
{ .code = MEDIA_BUS_FMT_SBGGR12_1X12, .bpp = 12, .datatype = MIPI_CSI2_DT_RAW12, },
{ .code = MEDIA_BUS_FMT_SGBRG12_1X12, .bpp = 12, .datatype = MIPI_CSI2_DT_RAW12, },
{ .code = MEDIA_BUS_FMT_SGRBG12_1X12, .bpp = 12, .datatype = MIPI_CSI2_DT_RAW12, },
{ .code = MEDIA_BUS_FMT_SRGGB12_1X12, .bpp = 12, .datatype = MIPI_CSI2_DT_RAW12, },
{ .code = MEDIA_BUS_FMT_SRGGB8_1X8, .bpp = 8, .datatype = MIPI_CSI2_DT_RAW8, },
{ .code = MEDIA_BUS_FMT_SGRBG8_1X8, .bpp = 8, .datatype = MIPI_CSI2_DT_RAW8, },
{ .code = MEDIA_BUS_FMT_SGBRG8_1X8, .bpp = 8, .datatype = MIPI_CSI2_DT_RAW8, },
{ .code = MEDIA_BUS_FMT_SBGGR8_1X8, .bpp = 8, .datatype = MIPI_CSI2_DT_RAW8, },
{ .code = MEDIA_BUS_FMT_SRGGB10_1X10, .bpp = 10, .datatype = MIPI_CSI2_DT_RAW10, },
{ .code = MEDIA_BUS_FMT_SGRBG10_1X10, .bpp = 10, .datatype = MIPI_CSI2_DT_RAW10, },
{ .code = MEDIA_BUS_FMT_SGBRG10_1X10, .bpp = 10, .datatype = MIPI_CSI2_DT_RAW10, },
{ .code = MEDIA_BUS_FMT_SBGGR10_1X10, .bpp = 10, .datatype = MIPI_CSI2_DT_RAW10, },
{ .code = MEDIA_BUS_FMT_SRGGI10_1X10, .bpp = 10, .datatype = MIPI_CSI2_DT_RAW10, },
{ .code = MEDIA_BUS_FMT_SGRIG10_1X10, .bpp = 10, .datatype = MIPI_CSI2_DT_RAW10, },
{ .code = MEDIA_BUS_FMT_SBGGI10_1X10, .bpp = 10, .datatype = MIPI_CSI2_DT_RAW10, },
{ .code = MEDIA_BUS_FMT_SGBIG10_1X10, .bpp = 10, .datatype = MIPI_CSI2_DT_RAW10, },
{ .code = MEDIA_BUS_FMT_SGIRG10_1X10, .bpp = 10, .datatype = MIPI_CSI2_DT_RAW10, },
{ .code = MEDIA_BUS_FMT_SIGGR10_1X10, .bpp = 10, .datatype = MIPI_CSI2_DT_RAW10, },
{ .code = MEDIA_BUS_FMT_SGIBG10_1X10, .bpp = 10, .datatype = MIPI_CSI2_DT_RAW10, },
{ .code = MEDIA_BUS_FMT_SIGGB10_1X10, .bpp = 10, .datatype = MIPI_CSI2_DT_RAW10, },
static const struct ub960_format_info *ub960_find_format(u32 code)
unsigned int i;
for (i = 0; i < ARRAY_SIZE(ub960_formats); i++) {
if (ub960_formats[i].code == code)
return &ub960_formats[i];
return NULL;
* Basic device access
static int ub960_read(struct ub960_data *priv, u8 reg, u8 *val)
unsigned int v;
int ret;
if (ret) {
dev_err(dev, "%s: cannot read register 0x%02x (%d)!\n",
__func__, reg, ret);
goto out_unlock;
*val = v;
out_unlock:
return ret;
static int ub960_write(struct ub960_data *priv, u8 reg, u8 val)
int ret;
if (ret)
dev_err(dev, "%s: cannot write register 0x%02x (%d)!\n",
return ret;
static int ub960_update_bits(struct ub960_data *priv, u8 reg, u8 mask, u8 val)
int ret;
ret = regmap_update_bits(priv->regmap, reg, mask, val);
if (ret)
dev_err(dev, "%s: cannot update register 0x%02x (%d)!\n",
return ret;
static int ub960_read16(struct ub960_data *priv, u8 reg, u16 *val)
__be16 __v;
int ret;
ret = regmap_bulk_read(priv->regmap, reg, &__v, sizeof(__v));
if (ret) {
goto out_unlock;
*val = be16_to_cpu(__v);
out_unlock:
return ret;
static int ub960_rxport_select(struct ub960_data *priv, u8 nport)
int ret;
lockdep_assert_held(&priv->reg_lock);
if (priv->reg_current.rxport == nport)
return 0;
ret = regmap_write(priv->regmap, UB960_SR_FPD3_PORT_SEL,
(nport << 4) | BIT(nport));
if (ret) {
dev_err(dev, "%s: cannot select rxport %d (%d)!\n", __func__,
nport, ret);
return ret;
priv->reg_current.rxport = nport;
return 0;
static int ub960_rxport_read(struct ub960_data *priv, u8 nport, u8 reg, u8 *val)
unsigned int v;
int ret;
ret = ub960_rxport_select(priv, nport);
if (ret)
goto out_unlock;
if (ret) {
goto out_unlock;
*val = v;
out_unlock:
return ret;
static int ub960_rxport_write(struct ub960_data *priv, u8 nport, u8 reg, u8 val)
int ret;
if (ret)
goto out_unlock;
if (ret)
out_unlock:
return ret;
static int ub960_rxport_update_bits(struct ub960_data *priv, u8 nport, u8 reg,
u8 mask, u8 val)
int ret;
if (ret)
goto out_unlock;
if (ret)
out_unlock:
return ret;
static int ub960_rxport_read16(struct ub960_data *priv, u8 nport, u8 reg,
u16 *val)
__be16 __v;
int ret;
if (ret)
goto out_unlock;
if (ret) {
goto out_unlock;
out_unlock:
return ret;
static int ub960_txport_select(struct ub960_data *priv, u8 nport)
int ret;
if (priv->reg_current.txport == nport)
return 0;
ret = regmap_write(priv->regmap, UB960_SR_CSI_PORT_SEL,
if (ret) {
dev_err(dev, "%s: cannot select tx port %d (%d)!\n", __func__,
nport, ret);
return ret;
priv->reg_current.txport = nport;
return 0;
static int ub960_txport_read(struct ub960_data *priv, u8 nport, u8 reg, u8 *val)
unsigned int v;
int ret;
ret = ub960_txport_select(priv, nport);
if (ret)
goto out_unlock;
if (ret) {
goto out_unlock;
*val = v;
out_unlock:
return ret;
static int ub960_txport_write(struct ub960_data *priv, u8 nport, u8 reg, u8 val)
int ret;
if (ret)
goto out_unlock;
if (ret)
out_unlock:
return ret;
static int ub960_txport_update_bits(struct ub960_data *priv, u8 nport, u8 reg,
u8 mask, u8 val)
int ret;
if (ret)
goto out_unlock;
if (ret)
out_unlock:
return ret;
static int ub960_select_ind_reg_block(struct ub960_data *priv, u8 block)
int ret;
if (priv->reg_current.indirect_target == block)
return 0;
ret = regmap_write(priv->regmap, UB960_SR_IND_ACC_CTL, block << 2);
if (ret) {
dev_err(dev, "%s: cannot select indirect target %u (%d)!\n",
return ret;
priv->reg_current.indirect_target = block;
return 0;
static int ub960_read_ind(struct ub960_data *priv, u8 block, u8 reg, u8 *val)
unsigned int v;
int ret;
ret = ub960_select_ind_reg_block(priv, block);
if (ret)
goto out_unlock;
ret = regmap_write(priv->regmap, UB960_SR_IND_ACC_ADDR, reg);
if (ret) {
dev_err(dev,
block, reg, ret);
goto out_unlock;
ret = regmap_read(priv->regmap, UB960_SR_IND_ACC_DATA, &v);
if (ret) {
dev_err(dev,
block, reg, ret);
goto out_unlock;
*val = v;
out_unlock:
return ret;
static int ub960_write_ind(struct ub960_data *priv, u8 block, u8 reg, u8 val)
int ret;
if (ret)
goto out_unlock;
if (ret) {
dev_err(dev,
block, reg, ret);
goto out_unlock;
ret = regmap_write(priv->regmap, UB960_SR_IND_ACC_DATA, val);
if (ret) {
dev_err(dev,
"Write to IND_ACC_DATA failed when writing %u:%x02x: %d\n",
block, reg, ret);
goto out_unlock;
out_unlock:
return ret;
static int ub960_ind_update_bits(struct ub960_data *priv, u8 block, u8 reg,
u8 mask, u8 val)
int ret;
if (ret)
goto out_unlock;
if (ret) {
dev_err(dev,
"Write to IND_ACC_ADDR failed when updating %u:%x02x: %d\n",
block, reg, ret);
goto out_unlock;
ret = regmap_update_bits(priv->regmap, UB960_SR_IND_ACC_DATA, mask,
val);
if (ret) {
dev_err(dev,
"Write to IND_ACC_DATA failed when updating %u:%x02x: %d\n",
block, reg, ret);
goto out_unlock;
out_unlock:
return ret;
* I2C-ATR (address translator)
static int ub960_atr_attach_client(struct i2c_atr *atr, u32 chan_id,
const struct i2c_client *client, u16 alias)
struct ub960_data *priv = i2c_atr_get_driver_data(atr);
struct ub960_rxport *rxport = priv->rxports[chan_id];
unsigned int reg_idx;
for (reg_idx = 0; reg_idx < ARRAY_SIZE(rxport->aliased_clients); reg_idx++) {
if (!rxport->aliased_clients[reg_idx])
break;
if (reg_idx == ARRAY_SIZE(rxport->aliased_clients)) {
dev_err(dev, "rx%u: alias pool exhausted\n", rxport->nport);
return -EADDRNOTAVAIL;
rxport->aliased_clients[reg_idx] = client;
ub960_rxport_write(priv, chan_id, UB960_RR_SLAVE_ID(reg_idx),
client->addr << 1);
ub960_rxport_write(priv, chan_id, UB960_RR_SLAVE_ALIAS(reg_idx),
alias << 1);
dev_dbg(dev, "rx%u: client 0x%02x assigned alias 0x%02x at slot %u\n",
rxport->nport, client->addr, alias, reg_idx);
return 0;
static void ub960_atr_detach_client(struct i2c_atr *atr, u32 chan_id,
const struct i2c_client *client)
if (rxport->aliased_clients[reg_idx] == client)
break;
dev_err(dev, "rx%u: client 0x%02x is not mapped!\n",
rxport->nport, client->addr);
return;
rxport->aliased_clients[reg_idx] = NULL;
ub960_rxport_write(priv, chan_id, UB960_RR_SLAVE_ALIAS(reg_idx), 0);
dev_dbg(dev, "rx%u: client 0x%02x released at slot %u\n", rxport->nport,
client->addr, reg_idx);
static const struct i2c_atr_ops ub960_atr_ops = {
.attach_client = ub960_atr_attach_client,
.detach_client = ub960_atr_detach_client,
static int ub960_init_atr(struct ub960_data *priv)
struct i2c_adapter *parent_adap = priv->client->adapter;
priv->atr = i2c_atr_new(parent_adap, dev, &ub960_atr_ops,
priv->hw_data->num_rxports);
if (IS_ERR(priv->atr))
return PTR_ERR(priv->atr);
i2c_atr_set_driver_data(priv->atr, priv);
return 0;
static void ub960_uninit_atr(struct ub960_data *priv)
i2c_atr_delete(priv->atr);
priv->atr = NULL;
* TX ports
static int ub960_parse_dt_txport(struct ub960_data *priv,
struct fwnode_handle *ep_fwnode,
u8 nport)
struct v4l2_fwnode_endpoint vep = {};
struct ub960_txport *txport;
int ret;
txport = kzalloc(sizeof(*txport), GFP_KERNEL);
if (!txport)
return -ENOMEM;
txport->priv = priv;
txport->nport = nport;
vep.bus_type = V4L2_MBUS_CSI2_DPHY;
ret = v4l2_fwnode_endpoint_alloc_parse(ep_fwnode, &vep);
if (ret) {
dev_err(dev, "tx%u: failed to parse endpoint data\n", nport);
goto err_free_txport;
txport->non_continous_clk = vep.bus.mipi_csi2.flags &
txport->num_data_lanes = vep.bus.mipi_csi2.num_data_lanes;
if (vep.nr_of_link_frequencies != 1) {
ret = -EINVAL;
goto err_free_vep;
priv->tx_link_freq[0] = vep.link_frequencies[0];
priv->tx_data_rate = priv->tx_link_freq[0] * 2;
if (priv->tx_data_rate != MHZ(1600) &&
priv->tx_data_rate != MHZ(1200) &&
priv->tx_data_rate != MHZ(800) &&
priv->tx_data_rate != MHZ(400)) {
dev_err(dev, "tx%u: invalid 'link-frequencies' value\n", nport);
ret = -EINVAL;
goto err_free_vep;
v4l2_fwnode_endpoint_free(&vep);
priv->txports[nport] = txport;
return 0;
err_free_vep:
err_free_txport:
kfree(txport);
return ret;
static void ub960_csi_handle_events(struct ub960_data *priv, u8 nport)
u8 csi_tx_isr;
int ret;
ret = ub960_txport_read(priv, nport, UB960_TR_CSI_TX_ISR, &csi_tx_isr);
if (ret)
return;
if (csi_tx_isr & UB960_TR_CSI_TX_ISR_IS_CSI_SYNC_ERROR)
dev_warn(dev, "TX%u: CSI_SYNC_ERROR\n", nport);
if (csi_tx_isr & UB960_TR_CSI_TX_ISR_IS_CSI_PASS_ERROR)
dev_warn(dev, "TX%u: CSI_PASS_ERROR\n", nport);
* RX ports
static int ub960_rxport_enable_vpocs(struct ub960_data *priv)
unsigned int nport;
int ret;
for (nport = 0; nport < priv->hw_data->num_rxports; nport++) {
struct ub960_rxport *rxport = priv->rxports[nport];
if (!rxport || !rxport->vpoc)
continue;
ret = regulator_enable(rxport->vpoc);
if (ret)
goto err_disable_vpocs;
return 0;
err_disable_vpocs:
while (nport--) {
continue;
regulator_disable(rxport->vpoc);
return ret;
static void ub960_rxport_disable_vpocs(struct ub960_data *priv)
unsigned int nport;
continue;
static void ub960_rxport_clear_errors(struct ub960_data *priv,
unsigned int nport)
u8 v;
ub960_rxport_read(priv, nport, UB960_RR_RX_PORT_STS1, &v);
ub960_rxport_read(priv, nport, UB960_RR_RX_PORT_STS2, &v);
ub960_rxport_read(priv, nport, UB960_RR_CSI_RX_STS, &v);
ub960_rxport_read(priv, nport, UB960_RR_BCC_STATUS, &v);
ub960_rxport_read(priv, nport, UB960_RR_RX_PAR_ERR_HI, &v);
ub960_rxport_read(priv, nport, UB960_RR_RX_PAR_ERR_LO, &v);
ub960_rxport_read(priv, nport, UB960_RR_CSI_ERR_COUNTER, &v);
static void ub960_clear_rx_errors(struct ub960_data *priv)
unsigned int nport;
ub960_rxport_clear_errors(priv, nport);
static int ub960_rxport_get_strobe_pos(struct ub960_data *priv,
unsigned int nport, s8 *strobe_pos)
u8 v;
u8 clk_delay, data_delay;
int ret;
ub960_read_ind(priv, UB960_IND_TARGET_RX_ANA(nport),
UB960_IR_RX_ANA_STROBE_SET_CLK, &v);
clk_delay = (v & UB960_IR_RX_ANA_STROBE_SET_CLK_NO_EXTRA_DELAY) ?
0 : UB960_MANUAL_STROBE_EXTRA_DELAY;
UB960_IR_RX_ANA_STROBE_SET_DATA, &v);
data_delay = (v & UB960_IR_RX_ANA_STROBE_SET_DATA_NO_EXTRA_DELAY) ?
ret = ub960_rxport_read(priv, nport, UB960_RR_SFILTER_STS_0, &v);
if (ret)
return ret;
clk_delay += v & UB960_IR_RX_ANA_STROBE_SET_CLK_DELAY_MASK;
ret = ub960_rxport_read(priv, nport, UB960_RR_SFILTER_STS_1, &v);
if (ret)
return ret;
data_delay += v & UB960_IR_RX_ANA_STROBE_SET_DATA_DELAY_MASK;
*strobe_pos = data_delay - clk_delay;
return 0;
static void ub960_rxport_set_strobe_pos(struct ub960_data *priv,
unsigned int nport, s8 strobe_pos)
clk_delay = UB960_IR_RX_ANA_STROBE_SET_CLK_NO_EXTRA_DELAY;
data_delay = UB960_IR_RX_ANA_STROBE_SET_DATA_NO_EXTRA_DELAY;
if (strobe_pos < UB960_MIN_AEQ_STROBE_POS)
clk_delay = abs(strobe_pos) - UB960_MANUAL_STROBE_EXTRA_DELAY;
else if (strobe_pos > UB960_MAX_AEQ_STROBE_POS)
data_delay = strobe_pos - UB960_MANUAL_STROBE_EXTRA_DELAY;
else if (strobe_pos < 0)
clk_delay = abs(strobe_pos) | UB960_IR_RX_ANA_STROBE_SET_CLK_NO_EXTRA_DELAY;
else if (strobe_pos > 0)
data_delay = strobe_pos | UB960_IR_RX_ANA_STROBE_SET_DATA_NO_EXTRA_DELAY;
ub960_write_ind(priv, UB960_IND_TARGET_RX_ANA(nport),
UB960_IR_RX_ANA_STROBE_SET_CLK, clk_delay);
UB960_IR_RX_ANA_STROBE_SET_DATA, data_delay);
static void ub960_rxport_set_strobe_range(struct ub960_data *priv,
s8 strobe_min, s8 strobe_max)
/* Convert the signed strobe pos to positive zero based value */
strobe_min -= UB960_MIN_AEQ_STROBE_POS;
strobe_max -= UB960_MIN_AEQ_STROBE_POS;
ub960_write(priv, UB960_XR_SFILTER_CFG,
((u8)strobe_min << UB960_XR_SFILTER_CFG_SFILTER_MIN_SHIFT) |
((u8)strobe_max << UB960_XR_SFILTER_CFG_SFILTER_MAX_SHIFT));
static int ub960_rxport_get_eq_level(struct ub960_data *priv,
unsigned int nport, u8 *eq_level)
int ret;
u8 v;
ret = ub960_rxport_read(priv, nport, UB960_RR_AEQ_STATUS, &v);
if (ret)
return ret;
*eq_level = (v & UB960_RR_AEQ_STATUS_STATUS_1) +
(v & UB960_RR_AEQ_STATUS_STATUS_2);
return 0;
static void ub960_rxport_set_eq_level(struct ub960_data *priv,
unsigned int nport, u8 eq_level)
u8 eq_stage_1_select_value, eq_stage_2_select_value;
const unsigned int eq_stage_max = 7;
u8 v;
if (eq_level <= eq_stage_max) {
eq_stage_1_select_value = eq_level;
eq_stage_2_select_value = 0;
} else {
eq_stage_1_select_value = eq_stage_max;
eq_stage_2_select_value = eq_level - eq_stage_max;
ub960_rxport_read(priv, nport, UB960_RR_AEQ_BYPASS, &v);
v &= ~(UB960_RR_AEQ_BYPASS_EQ_STAGE1_VALUE_MASK |
UB960_RR_AEQ_BYPASS_EQ_STAGE2_VALUE_MASK);
v |= eq_stage_1_select_value << UB960_RR_AEQ_BYPASS_EQ_STAGE1_VALUE_SHIFT;
v |= eq_stage_2_select_value << UB960_RR_AEQ_BYPASS_EQ_STAGE2_VALUE_SHIFT;
v |= UB960_RR_AEQ_BYPASS_ENABLE;
ub960_rxport_write(priv, nport, UB960_RR_AEQ_BYPASS, v);
static void ub960_rxport_set_eq_range(struct ub960_data *priv,
unsigned int nport, u8 eq_min, u8 eq_max)
ub960_rxport_write(priv, nport, UB960_RR_AEQ_MIN_MAX,
(eq_min << UB960_RR_AEQ_MIN_MAX_AEQ_FLOOR_SHIFT) |
(eq_max << UB960_RR_AEQ_MIN_MAX_AEQ_MAX_SHIFT));
/* Enable AEQ min setting */
ub960_rxport_update_bits(priv, nport, UB960_RR_AEQ_CTL2,
UB960_RR_AEQ_CTL2_SET_AEQ_FLOOR,
UB960_RR_AEQ_CTL2_SET_AEQ_FLOOR);
static void ub960_rxport_config_eq(struct ub960_data *priv, unsigned int nport)
/* We also set common settings here. Should be moved elsewhere. */
if (priv->strobe.manual) {
/* Disable AEQ_SFILTER_EN */
ub960_update_bits(priv, UB960_XR_AEQ_CTL1,
UB960_XR_AEQ_CTL1_AEQ_SFILTER_EN, 0);
} else {
/* Enable SFILTER and error control */
ub960_write(priv, UB960_XR_AEQ_CTL1,
UB960_XR_AEQ_CTL1_AEQ_ERR_CTL_MASK |
UB960_XR_AEQ_CTL1_AEQ_SFILTER_EN);
/* Set AEQ strobe range */
ub960_rxport_set_strobe_range(priv, priv->strobe.min,
priv->strobe.max);
/* The rest are port specific */
ub960_rxport_set_strobe_pos(priv, nport, rxport->eq.strobe_pos);
else if (!priv->hw_data->ignore_strobe_pos)
ub960_rxport_set_strobe_pos(priv, nport, 0);
if (rxport->eq.manual_eq) {
ub960_rxport_set_eq_level(priv, nport,
rxport->eq.manual.eq_level);
/* Enable AEQ Bypass */
ub960_rxport_update_bits(priv, nport, UB960_RR_AEQ_BYPASS,
UB960_RR_AEQ_BYPASS_ENABLE,
UB960_RR_AEQ_BYPASS_ENABLE);
} else {
ub960_rxport_set_eq_range(priv, nport,
rxport->eq.aeq.eq_level_min,
rxport->eq.aeq.eq_level_max);
/* Disable AEQ Bypass */
UB960_RR_AEQ_BYPASS_ENABLE, 0);
static int ub960_rxport_link_ok(struct ub960_data *priv, unsigned int nport,
bool *ok)
u8 rx_port_sts1, rx_port_sts2;
u16 parity_errors;
u8 csi_rx_sts;
u8 csi_err_cnt;
u8 bcc_sts;
int ret;
bool errors;
ret = ub960_rxport_read(priv, nport, UB960_RR_RX_PORT_STS1,
&rx_port_sts1);
if (ret)
return ret;
if (!(rx_port_sts1 & UB960_RR_RX_PORT_STS1_LOCK_STS)) {
*ok = false;
return 0;
ret = ub960_rxport_read(priv, nport, UB960_RR_RX_PORT_STS2,
&rx_port_sts2);
if (ret)
return ret;
ret = ub960_rxport_read(priv, nport, UB960_RR_CSI_RX_STS, &csi_rx_sts);
if (ret)
return ret;
ret = ub960_rxport_read(priv, nport, UB960_RR_CSI_ERR_COUNTER,
&csi_err_cnt);
if (ret)
return ret;
ret = ub960_rxport_read(priv, nport, UB960_RR_BCC_STATUS, &bcc_sts);
if (ret)
return ret;
ret = ub960_rxport_read16(priv, nport, UB960_RR_RX_PAR_ERR_HI,
&parity_errors);
if (ret)
return ret;
errors = (rx_port_sts1 & UB960_RR_RX_PORT_STS1_ERROR_MASK) ||
(rx_port_sts2 & UB960_RR_RX_PORT_STS2_ERROR_MASK) ||
(bcc_sts & UB960_RR_BCC_STATUS_ERROR_MASK) ||
(csi_rx_sts & UB960_RR_CSI_RX_STS_ERROR_MASK) || csi_err_cnt ||
parity_errors;
*ok = !errors;
return 0;
* Wait for the RX ports to lock, have no errors and have stable strobe position
* and EQ level.
static int ub960_rxport_wait_locks(struct ub960_data *priv,
unsigned long port_mask,
unsigned int *lock_mask)
unsigned long timeout;
unsigned int link_ok_mask;
unsigned int missing;
unsigned int loops;
u8 nport;
int ret;
if (port_mask == 0) {
if (lock_mask)
*lock_mask = 0;
return 0;
if (port_mask >= BIT(priv->hw_data->num_rxports))
return -EINVAL;
timeout = jiffies + msecs_to_jiffies(1000);
loops = 0;
link_ok_mask = 0;
while (time_before(jiffies, timeout)) {
missing = 0;
for_each_set_bit(nport, &port_mask,
priv->hw_data->num_rxports) {
bool ok;
if (!rxport)
continue;
ret = ub960_rxport_link_ok(priv, nport, &ok);
if (ret)
return ret;
* We want the link to be ok for two consecutive loops,
* as a link could get established just before our test
* and drop soon after.
if (!ok || !(link_ok_mask & BIT(nport)))
missing++;
if (ok)
link_ok_mask |= BIT(nport);
else
link_ok_mask &= ~BIT(nport);
loops++;
if (missing == 0)
break;
msleep(50);
if (lock_mask)
*lock_mask = link_ok_mask;
dev_dbg(dev, "Wait locks done in %u loops\n", loops);
for_each_set_bit(nport, &port_mask, priv->hw_data->num_rxports) {
s8 strobe_pos, eq_level;
u16 v;
if (!rxport)
continue;
if (!(link_ok_mask & BIT(nport))) {
dev_dbg(dev, "\trx%u: not locked\n", nport);
continue;
ub960_rxport_read16(priv, nport, UB960_RR_RX_FREQ_HIGH, &v);
if (priv->hw_data->is_ub9702) {
dev_dbg(dev, "\trx%u: locked, freq %llu Hz\n",
nport, (v * 1000000ULL) >> 8);
} else {
ret = ub960_rxport_get_strobe_pos(priv, nport,
&strobe_pos);
if (ret)
return ret;
ret = ub960_rxport_get_eq_level(priv, nport, &eq_level);
if (ret)
return ret;
dev_dbg(dev,
"\trx%u: locked, SP: %d, EQ: %u, freq %llu Hz\n",
nport, strobe_pos, eq_level,
return 0;
static unsigned long ub960_calc_bc_clk_rate_ub960(struct ub960_data *priv,
struct ub960_rxport *rxport)
unsigned int mult;
unsigned int div;
switch (rxport->rx_mode) {
case RXPORT_MODE_RAW10:
case RXPORT_MODE_RAW12_HF:
case RXPORT_MODE_RAW12_LF:
mult = 1;
div = 10;
break;
case RXPORT_MODE_CSI2_SYNC:
mult = 2;
div = 1;
break;
case RXPORT_MODE_CSI2_NONSYNC:
mult = 2;
div = 5;
break;
default:
return 0;
return clk_get_rate(priv->refclk) * mult / div;
static unsigned long ub960_calc_bc_clk_rate_ub9702(struct ub960_data *priv,
return 2359400;
return 47187500;
return 9437500;
default:
return 0;
static int ub960_rxport_add_serializer(struct ub960_data *priv, u8 nport)
struct ds90ub9xx_platform_data *ser_pdata = &rxport->ser.pdata;
struct i2c_board_info ser_info = {
.of_node = to_of_node(rxport->ser.fwnode),
.fwnode = rxport->ser.fwnode,
.platform_data = ser_pdata,
ser_pdata->port = nport;
ser_pdata->atr = priv->atr;
ser_pdata->bc_rate = ub960_calc_bc_clk_rate_ub9702(priv, rxport);
else
ser_pdata->bc_rate = ub960_calc_bc_clk_rate_ub960(priv, rxport);
* The serializer is added under the same i2c adapter as the
* deserializer. This is not quite right, as the serializer is behind
* the FPD-Link.
ser_info.addr = rxport->ser.alias;
rxport->ser.client =
i2c_new_client_device(priv->client->adapter, &ser_info);
if (IS_ERR(rxport->ser.client)) {
dev_err(dev, "rx%u: cannot add %s i2c device", nport,
ser_info.type);
return PTR_ERR(rxport->ser.client);
dev_dbg(dev, "rx%u: remote serializer at alias 0x%02x (%u-%04x)\n",
nport, rxport->ser.client->addr,
rxport->ser.client->adapter->nr, rxport->ser.client->addr);
return 0;
static void ub960_rxport_remove_serializer(struct ub960_data *priv, u8 nport)
i2c_unregister_device(rxport->ser.client);
rxport->ser.client = NULL;
/* Add serializer i2c devices for all initialized ports */
static int ub960_rxport_add_serializers(struct ub960_data *priv)
unsigned int nport;
int ret;
if (!rxport)
continue;
ret = ub960_rxport_add_serializer(priv, nport);
if (ret)
goto err_remove_sers;
return 0;
err_remove_sers:
while (nport--) {
if (!rxport)
continue;
ub960_rxport_remove_serializer(priv, nport);
return ret;
static void ub960_rxport_remove_serializers(struct ub960_data *priv)
unsigned int nport;
if (!rxport)
continue;
static void ub960_init_tx_port(struct ub960_data *priv,
struct ub960_txport *txport)
unsigned int nport = txport->nport;
u8 csi_ctl = 0;
* From the datasheet: "initial CSI Skew-Calibration
* sequence [...] should be set when operating at 1.6 Gbps"
if (priv->tx_data_rate == MHZ(1600))
csi_ctl |= UB960_TR_CSI_CTL_CSI_CAL_EN;
csi_ctl |= (4 - txport->num_data_lanes) << 4;
if (!txport->non_continous_clk)
csi_ctl |= UB960_TR_CSI_CTL_CSI_CONTS_CLOCK;
ub960_txport_write(priv, nport, UB960_TR_CSI_CTL, csi_ctl);
static int ub960_init_tx_ports(struct ub960_data *priv)
unsigned int nport;
u8 speed_select;
u8 pll_div;
/* TX ports */
switch (priv->tx_data_rate) {
case MHZ(1600):
default:
speed_select = 0;
pll_div = 0x10;
break;
case MHZ(1200):
speed_select = 1;
pll_div = 0x18;
break;
case MHZ(800):
speed_select = 2;
pll_div = 0x10;
break;
case MHZ(400):
speed_select = 3;
pll_div = 0x10;
break;
ub960_write(priv, UB960_SR_CSI_PLL_CTL, speed_select);
ub960_write(priv, UB960_SR_CSI_PLL_DIV, pll_div);
case MHZ(1600):
default:
ub960_write_ind(priv, UB960_IND_TARGET_CSI_ANA, 0x92, 0x80);
ub960_write_ind(priv, UB960_IND_TARGET_CSI_ANA, 0x4b, 0x2a);
break;
case MHZ(800):
ub960_write_ind(priv, UB960_IND_TARGET_CSI_ANA, 0x92, 0x90);
ub960_write_ind(priv, UB960_IND_TARGET_CSI_ANA, 0x4f, 0x2a);
break;
case MHZ(400):
ub960_write_ind(priv, UB960_IND_TARGET_CSI_ANA, 0x92, 0xa0);
break;
for (nport = 0; nport < priv->hw_data->num_txports; nport++) {
struct ub960_txport *txport = priv->txports[nport];
if (!txport)
continue;
ub960_init_tx_port(priv, txport);
return 0;
static void ub960_init_rx_port_ub960(struct ub960_data *priv,
unsigned int nport = rxport->nport;
u32 bc_freq_val;
* Back channel frequency select.
* Override FREQ_SELECT from the strap.
* 0 - 2.5 Mbps (DS90UB913A-Q1 / DS90UB933-Q1)
* 2 - 10 Mbps
* 6 - 50 Mbps (DS90UB953-Q1)
* Note that changing this setting will result in some errors on the back
* channel for a short period of time.
bc_freq_val = 0;
break;
bc_freq_val = 2;
break;
bc_freq_val = 6;
break;
default:
return;
ub960_rxport_update_bits(priv, nport, UB960_RR_BCC_CONFIG,
UB960_RR_BCC_CONFIG_BC_FREQ_SEL_MASK,
bc_freq_val);
/* FPD3_MODE = RAW10 Mode (DS90UB913A-Q1 / DS90UB933-Q1 compatible) */
ub960_rxport_update_bits(priv, nport, UB960_RR_PORT_CONFIG,
UB960_RR_PORT_CONFIG_FPD3_MODE_MASK,
0x3);
* RAW10_8BIT_CTL = 0b10 : 8-bit processing using upper 8 bits
ub960_rxport_update_bits(priv, nport, UB960_RR_PORT_CONFIG2,
UB960_RR_PORT_CONFIG2_RAW10_8BIT_CTL_MASK,
0x2 << UB960_RR_PORT_CONFIG2_RAW10_8BIT_CTL_SHIFT);
break;
/* Not implemented */
return;
/* CSI-2 Mode (DS90UB953-Q1 compatible) */
ub960_rxport_update_bits(priv, nport, UB960_RR_PORT_CONFIG, 0x3,
0x0);
break;
/* LV_POLARITY & FV_POLARITY */
ub960_rxport_update_bits(priv, nport, UB960_RR_PORT_CONFIG2, 0x3,
rxport->lv_fv_pol);
/* Enable all interrupt sources from this port */
ub960_rxport_write(priv, nport, UB960_RR_PORT_ICR_HI, 0x07);
ub960_rxport_write(priv, nport, UB960_RR_PORT_ICR_LO, 0x7f);
/* Enable I2C_PASS_THROUGH */
UB960_RR_BCC_CONFIG_I2C_PASS_THROUGH,
UB960_RR_BCC_CONFIG_I2C_PASS_THROUGH);
/* Enable I2C communication to the serializer via the alias addr */
ub960_rxport_write(priv, nport, UB960_RR_SER_ALIAS_ID,
rxport->ser.alias << 1);
/* Configure EQ related settings */
ub960_rxport_config_eq(priv, nport);
/* Enable RX port */
ub960_update_bits(priv, UB960_SR_RX_PORT_CTL, BIT(nport), BIT(nport));
static void ub960_init_rx_port_ub9702_fpd3(struct ub960_data *priv,
u8 bc_freq_val;
u8 fpd_func_mode;
bc_freq_val = 0;
fpd_func_mode = 5;
break;
bc_freq_val = 0;
fpd_func_mode = 4;
break;
bc_freq_val = 0;
fpd_func_mode = 6;
break;
bc_freq_val = 6;
fpd_func_mode = 2;
break;
bc_freq_val = 2;
fpd_func_mode = 2;
break;
default:
return;
ub960_rxport_update_bits(priv, nport, UB960_RR_BCC_CONFIG, 0x7,
bc_freq_val);
ub960_rxport_write(priv, nport, UB960_RR_CHANNEL_MODE, fpd_func_mode);
/* set serdes_eq_mode = 1 */
ub960_write_ind(priv, UB960_IND_TARGET_RX_ANA(nport), 0xa8, 0x80);
/* enable serdes driver */
ub960_write_ind(priv, UB960_IND_TARGET_RX_ANA(nport), 0x0d, 0x7f);
/* set serdes_eq_offset=4 */
ub960_write_ind(priv, UB960_IND_TARGET_RX_ANA(nport), 0x2b, 0x04);
/* init default serdes_eq_max in 0xa9 */
ub960_write_ind(priv, UB960_IND_TARGET_RX_ANA(nport), 0xa9, 0x23);
/* init serdes_eq_min in 0xaa */
ub960_write_ind(priv, UB960_IND_TARGET_RX_ANA(nport), 0xaa, 0);
/* serdes_driver_ctl2 control: DS90UB953-Q1/DS90UB933-Q1/DS90UB913A-Q1 */
ub960_ind_update_bits(priv, UB960_IND_TARGET_RX_ANA(nport), 0x1b,
BIT(3), BIT(3));
/* RX port to half-rate */
ub960_update_bits(priv, UB960_SR_FPD_RATE_CFG, 0x3 << (nport * 2),
BIT(nport * 2));
static void ub960_init_rx_port_ub9702_fpd4_aeq(struct ub960_data *priv,
bool first_time_power_up = true;
if (first_time_power_up) {
u8 v;
/* AEQ init */
ub960_read_ind(priv, UB960_IND_TARGET_RX_ANA(nport), 0x2c, &v);
ub960_write_ind(priv, UB960_IND_TARGET_RX_ANA(nport), 0x27, v);
ub960_write_ind(priv, UB960_IND_TARGET_RX_ANA(nport), 0x28, v + 1);
ub960_write_ind(priv, UB960_IND_TARGET_RX_ANA(nport), 0x2b, 0x00);
/* enable serdes_eq_ctl2 */
ub960_write_ind(priv, UB960_IND_TARGET_RX_ANA(nport), 0x9e, 0x00);
/* enable serdes_eq_ctl1 */
ub960_write_ind(priv, UB960_IND_TARGET_RX_ANA(nport), 0x90, 0x40);
/* enable serdes_eq_en */
ub960_write_ind(priv, UB960_IND_TARGET_RX_ANA(nport), 0x2e, 0x40);
/* disable serdes_eq_override */
ub960_write_ind(priv, UB960_IND_TARGET_RX_ANA(nport), 0xf0, 0x00);
/* disable serdes_gain_override */
ub960_write_ind(priv, UB960_IND_TARGET_RX_ANA(nport), 0x71, 0x00);
static void ub960_init_rx_port_ub9702_fpd4(struct ub960_data *priv,
u8 bc_freq_val;
bc_freq_val = 0;
break;
bc_freq_val = 0;
break;
bc_freq_val = 0;
break;
bc_freq_val = 6;
break;
bc_freq_val = 2;
break;
default:
return;
bc_freq_val);
/* FPD4 Sync Mode */
ub960_rxport_write(priv, nport, UB960_RR_CHANNEL_MODE, 0);
/* add serdes_eq_offset of 4 */
/* FPD4 serdes_start_eq in 0x27: assign default */
ub960_write_ind(priv, UB960_IND_TARGET_RX_ANA(nport), 0x27, 0x0);
/* FPD4 serdes_end_eq in 0x28: assign default */
ub960_write_ind(priv, UB960_IND_TARGET_RX_ANA(nport), 0x28, 0x23);
/* set serdes_driver_mode into FPD IV mode */
ub960_write_ind(priv, UB960_IND_TARGET_RX_ANA(nport), 0x04, 0x00);
/* set FPD PBC drv into FPD IV mode */
ub960_write_ind(priv, UB960_IND_TARGET_RX_ANA(nport), 0x1b, 0x00);
/* set serdes_system_init to 0x2f */
ub960_write_ind(priv, UB960_IND_TARGET_RX_ANA(nport), 0x21, 0x2f);
/* set serdes_system_rst in reset mode */
ub960_write_ind(priv, UB960_IND_TARGET_RX_ANA(nport), 0x25, 0xc1);
/* RX port to 7.55G mode */
0 << (nport * 2));
ub960_init_rx_port_ub9702_fpd4_aeq(priv, rxport);
static void ub960_init_rx_port_ub9702(struct ub960_data *priv,
if (rxport->cdr_mode == RXPORT_CDR_FPD3)
ub960_init_rx_port_ub9702_fpd3(priv, rxport);
else /* RXPORT_CDR_FPD4 */
ub960_init_rx_port_ub9702_fpd4(priv, rxport);
* RAW10_8BIT_CTL = 0b11 : 8-bit processing using lower 8 bits
* 0b10 : 8-bit processing using upper 8 bits
0x3 << 6, 0x2 << 6);
break;
return;
break;
rxport->lv_fv_pol);
if (rxport->cdr_mode == RXPORT_CDR_FPD4) {
/* unreset 960 AEQ */
ub960_write_ind(priv, UB960_IND_TARGET_RX_ANA(nport), 0x25, 0x41);
static int ub960_init_rx_ports(struct ub960_data *priv)
unsigned int nport;
u8 enabled_rxports_mask;
u8 enabled_rxports;
int ret;
/* Configure I2C interface for RX ports */
enabled_rxports_mask = FIELD_PREP(UB960_SR_RX_PORT_CTL_BCC_MAP, priv->rx_mask);
enabled_rxports = (priv->tx_mask & UB960_CSI_TX0) ? 0x00 : enabled_rxports_mask;
ret = ub960_update_bits(priv, UB960_SR_RX_PORT_CTL, enabled_rxports_mask, enabled_rxports);
if (ret)
return ret;
if (!rxport)
continue;
ub960_init_rx_port_ub9702(priv, rxport);
else
ub960_init_rx_port_ub960(priv, rxport);
return 0;
static void ub960_rxport_handle_events(struct ub960_data *priv, u8 nport)
struct device *dev = &priv->client->dev;
u8 rx_port_sts1;
u8 rx_port_sts2;
u8 csi_rx_sts;
u8 bcc_sts;
int ret = 0;
/* Read interrupts (also clears most of them) */
if (!ret)
&rx_port_sts1);
if (!ret)
&rx_port_sts2);
if (!ret)
&csi_rx_sts);
if (!ret)
&bcc_sts);
if (ret)
return;
if (rx_port_sts1 & UB960_RR_RX_PORT_STS1_PARITY_ERROR) {
u16 v;
&v);
if (!ret)
dev_err(dev, "rx%u parity errors: %u\n", nport, v);
if (rx_port_sts1 & UB960_RR_RX_PORT_STS1_BCC_CRC_ERROR)
dev_err(dev, "rx%u BCC CRC error\n", nport);
if (rx_port_sts1 & UB960_RR_RX_PORT_STS1_BCC_SEQ_ERROR)
dev_err(dev, "rx%u BCC SEQ error\n", nport);
if (rx_port_sts2 & UB960_RR_RX_PORT_STS2_LINE_LEN_UNSTABLE)
dev_err(dev, "rx%u line length unstable\n", nport);
if (rx_port_sts2 & UB960_RR_RX_PORT_STS2_FPD3_ENCODE_ERROR)
dev_err(dev, "rx%u FPD3 encode error\n", nport);
if (rx_port_sts2 & UB960_RR_RX_PORT_STS2_BUFFER_ERROR)
dev_err(dev, "rx%u buffer error\n", nport);
if (csi_rx_sts)
dev_err(dev, "rx%u CSI error: %#02x\n", nport, csi_rx_sts);
if (csi_rx_sts & UB960_RR_CSI_RX_STS_ECC1_ERR)
dev_err(dev, "rx%u CSI ECC1 error\n", nport);
if (csi_rx_sts & UB960_RR_CSI_RX_STS_ECC2_ERR)
dev_err(dev, "rx%u CSI ECC2 error\n", nport);
if (csi_rx_sts & UB960_RR_CSI_RX_STS_CKSUM_ERR)
dev_err(dev, "rx%u CSI checksum error\n", nport);
if (csi_rx_sts & UB960_RR_CSI_RX_STS_LENGTH_ERR)
dev_err(dev, "rx%u CSI length error\n", nport);
if (bcc_sts)
dev_err(dev, "rx%u BCC error: %#02x\n", nport, bcc_sts);
if (bcc_sts & UB960_RR_BCC_STATUS_RESP_ERR)
dev_err(dev, "rx%u BCC response error", nport);
if (bcc_sts & UB960_RR_BCC_STATUS_SLAVE_TO)
dev_err(dev, "rx%u BCC slave timeout", nport);
if (bcc_sts & UB960_RR_BCC_STATUS_SLAVE_ERR)
dev_err(dev, "rx%u BCC slave error", nport);
if (bcc_sts & UB960_RR_BCC_STATUS_MASTER_TO)
dev_err(dev, "rx%u BCC master timeout", nport);
if (bcc_sts & UB960_RR_BCC_STATUS_MASTER_ERR)
dev_err(dev, "rx%u BCC master error", nport);
if (bcc_sts & UB960_RR_BCC_STATUS_SEQ_ERROR)
dev_err(dev, "rx%u BCC sequence error", nport);
if (rx_port_sts2 & UB960_RR_RX_PORT_STS2_LINE_LEN_CHG) {
u16 v;
ret = ub960_rxport_read16(priv, nport, UB960_RR_LINE_LEN_1, &v);
if (!ret)
dev_dbg(dev, "rx%u line len changed: %u\n", nport, v);
if (rx_port_sts2 & UB960_RR_RX_PORT_STS2_LINE_CNT_CHG) {
u16 v;
ret = ub960_rxport_read16(priv, nport, UB960_RR_LINE_COUNT_HI,
&v);
if (!ret)
dev_dbg(dev, "rx%u line count changed: %u\n", nport, v);
if (rx_port_sts1 & UB960_RR_RX_PORT_STS1_LOCK_STS_CHG) {
dev_dbg(dev, "rx%u: %s, %s, %s, %s\n", nport,
(rx_port_sts1 & UB960_RR_RX_PORT_STS1_LOCK_STS) ?
"locked" :
"unlocked",
(rx_port_sts1 & UB960_RR_RX_PORT_STS1_PORT_PASS) ?
"passed" :
"not passed",
(rx_port_sts2 & UB960_RR_RX_PORT_STS2_CABLE_FAULT) ?
"no clock" :
"clock ok",
(rx_port_sts2 & UB960_RR_RX_PORT_STS2_FREQ_STABLE) ?
"stable freq" :
"unstable freq");
* V4L2
* Map incoming streams with different virtual channels from 1-4 sensors to
* unique VCs on CSI TX0. Sensors using multiple VCs will work, but due to
* limited total channels (4) this will reduce the total number of sensors that
* can work simultaneously.
* The current implementation is limited to using a single CSI TX port (TX0),
* as that is the most common HW configuration found on boards with DS90UB960.
* For using both CSI TX0 & TX1 the below method will need significant changes.
* TODO: implement a more sophisticated VC mapping. As the driver cannot know
* what VCs the sinks expect (say, an FPGA with hardcoded VC routing), this
* probably needs to be somehow configurable. Device tree?
static void ub960_get_vc_maps(struct ub960_data *priv, u8 *vc_map)
u8 nport, available_vc = 0;
for (nport = 0;
nport < priv->hw_data->num_rxports && priv->rxports[nport];
++nport) {
struct v4l2_mbus_frame_desc source_fd;
bool used_vc[UB960_MAX_VC] = {false};
u8 vc, cur_vc = available_vc;
int j, ret;
u8 map;
ret = v4l2_subdev_call(priv->rxports[nport]->source.sd, pad,
get_frame_desc,
priv->rxports[nport]->source.pad,
&source_fd);
/* Mark channels used in source in used_vc[] */
if (!ret) {
for (j = 0; j < source_fd.num_entries; ++j) {
u8 source_vc = source_fd.entry[j].bus.csi2.vc;
if (source_vc < UB960_MAX_VC)
used_vc[source_vc] = true;
} else if (ret == -ENOIOCTLCMD) {
/* assume VC=0 is used if sensor driver doesn't provide info */
used_vc[0] = true;
} else {
continue;
/* Start with all channels mapped to first free output */
map = (cur_vc << 6) | (cur_vc << 4) | (cur_vc << 2) |
(cur_vc << 0);
/* Map actually used to channels to distinct free outputs */
for (vc = 0; vc < UB960_MAX_VC; ++vc) {
if (used_vc[vc]) {
map &= ~(0x03 << (2 * vc));
map |= (cur_vc << (2 * vc));
++cur_vc;
/* Don't enable port if we ran out of available channels */
if (cur_vc > UB960_MAX_VC) {
dev_err(dev,
"No VCs available for RX port %d\n",
nport);
continue;
/* Enable port and update map */
vc_map[nport] = map;
available_vc = cur_vc;
dev_dbg(dev, "%s: VC map for port %d is 0x%02x",
__func__, nport, map);
static int ub960_enable_tx_port(struct ub960_data *priv, unsigned int nport)
dev_dbg(dev, "enable TX port %u\n", nport);
return ub960_txport_update_bits(priv, nport, UB960_TR_CSI_CTL,
UB960_TR_CSI_CTL_CSI_ENABLE,
UB960_TR_CSI_CTL_CSI_ENABLE);
static void ub960_disable_tx_port(struct ub960_data *priv, unsigned int nport)
dev_dbg(dev, "disable TX port %u\n", nport);
UB960_TR_CSI_CTL_CSI_ENABLE, 0);
static int ub960_enable_rx_port(struct ub960_data *priv, unsigned int nport)
dev_dbg(dev, "enable RX port %u\n", nport);
/* Enable forwarding */
return ub960_update_bits(priv, UB960_SR_FWD_CTL1,
UB960_SR_FWD_CTL1_PORT_DIS(nport), 0);
static void ub960_disable_rx_port(struct ub960_data *priv, unsigned int nport)
dev_dbg(dev, "disable RX port %u\n", nport);
/* Disable forwarding */
UB960_SR_FWD_CTL1_PORT_DIS(nport));
static int ub960_configure_ports_for_streaming(struct ub960_data *priv,
struct v4l2_subdev_state *state)
u8 fwd_ctl = 0;
struct {
u32 num_streams;
u8 pixel_dt;
u8 meta_dt;
u32 meta_lines;
u32 tx_port;
} rx_data[UB960_MAX_RX_NPORTS] = {};
u8 vc_map[UB960_MAX_RX_NPORTS] = {};
struct v4l2_subdev_route *route;
unsigned int nport;
int ret;
ub960_get_vc_maps(priv, vc_map);
for_each_active_route(&state->routing, route) {
struct v4l2_mbus_framefmt *fmt;
const struct ub960_format_info *ub960_fmt;
unsigned int nport;
nport = ub960_pad_to_port(priv, route->sink_pad);
if (!rxport)
return -EINVAL;
txport = priv->txports[ub960_pad_to_port(priv, route->source_pad)];
if (!txport)
return -EINVAL;
rx_data[nport].tx_port = ub960_pad_to_port(priv, route->source_pad);
rx_data[nport].num_streams++;
/* For the rest, we are only interested in parallel busses */
if (rxport->rx_mode == RXPORT_MODE_CSI2_SYNC ||
rxport->rx_mode == RXPORT_MODE_CSI2_NONSYNC)
continue;
if (rx_data[nport].num_streams > 2)
return -EPIPE;
fmt = v4l2_subdev_state_get_format(state, route->sink_pad,
route->sink_stream);
if (!fmt)
return -EPIPE;
ub960_fmt = ub960_find_format(fmt->code);
if (!ub960_fmt)
return -EPIPE;
if (ub960_fmt->meta) {
if (fmt->height > 3) {
dev_err(&priv->client->dev,
"rx%u: unsupported metadata height %u\n",
nport, fmt->height);
return -EPIPE;
rx_data[nport].meta_dt = ub960_fmt->datatype;
rx_data[nport].meta_lines = fmt->height;
} else {
rx_data[nport].pixel_dt = ub960_fmt->datatype;
if (rx_data[nport].num_streams == 0)
continue;
ub960_rxport_write(priv, nport, UB960_RR_RAW10_ID,
rx_data[nport].pixel_dt | (nport << UB960_RR_RAW10_ID_VC_SHIFT));
ub960_rxport_write(priv, rxport->nport,
UB960_RR_RAW_EMBED_DTYPE,
(rx_data[nport].meta_lines << UB960_RR_RAW_EMBED_DTYPE_LINES_SHIFT) |
rx_data[nport].meta_dt);
break;
break;
if (!priv->hw_data->is_ub9702) {
UB960_RR_CSI_VC_MAP,
vc_map[nport]);
} else {
unsigned int i;
/* Map all VCs from this port to VC(nport) */
for (i = 0; i < 8; i++)
UB960_RR_VC_ID_MAP(i),
(nport << 4) | nport);
break;
if (rx_data[nport].tx_port == 1)
fwd_ctl |= BIT(nport); /* forward to TX1 */
else
fwd_ctl &= ~BIT(nport); /* forward to TX0 */
ret = ub960_update_bits(priv, UB960_SR_FWD_CTL1, priv->rx_mask, fwd_ctl);
return ret;
static void ub960_update_streaming_status(struct ub960_data *priv)
unsigned int i;
for (i = 0; i < UB960_MAX_NPORTS; i++) {
if (priv->stream_enable_mask[i])
break;
priv->streaming = i < UB960_MAX_NPORTS;
static int ub960_enable_streams(struct v4l2_subdev *sd,
struct v4l2_subdev_state *state, u32 source_pad,
u64 source_streams_mask)
struct ub960_data *priv = sd_to_ub960(sd);
u64 sink_streams[UB960_MAX_RX_NPORTS] = {};
unsigned int failed_port;
unsigned int nport;
int ret;
if (!priv->streaming) {
dev_dbg(dev, "Prepare for streaming\n");
ret = ub960_configure_ports_for_streaming(priv, state);
if (ret)
return ret;
/* Enable TX port if not yet enabled */
if (!priv->stream_enable_mask[source_pad]) {
ret = ub960_enable_tx_port(priv,
ub960_pad_to_port(priv, source_pad));
if (ret)
return ret;
priv->stream_enable_mask[source_pad] |= source_streams_mask;
/* Collect sink streams per pad which we need to enable */
if (route->source_pad != source_pad)
continue;
if (!(source_streams_mask & BIT_ULL(route->source_stream)))
continue;
sink_streams[nport] |= BIT_ULL(route->sink_stream);
if (!sink_streams[nport])
continue;
/* Enable the RX port if not yet enabled */
if (!priv->stream_enable_mask[nport]) {
ret = ub960_enable_rx_port(priv, nport);
if (ret) {
failed_port = nport;
goto err;
priv->stream_enable_mask[nport] |= sink_streams[nport];
dev_dbg(dev, "enable RX port %u streams %#llx\n", nport,
sink_streams[nport]);
ret = v4l2_subdev_enable_streams(
if (ret) {
priv->stream_enable_mask[nport] &= ~sink_streams[nport];
ub960_disable_rx_port(priv, nport);
goto err;
priv->streaming = true;
return 0;
err:
for (nport = 0; nport < failed_port; nport++) {
continue;
dev_dbg(dev, "disable RX port %u streams %#llx\n", nport,
ret = v4l2_subdev_disable_streams(
if (ret)
dev_err(dev, "Failed to disable streams: %d\n", ret);
/* Disable RX port if no active streams */
priv->stream_enable_mask[source_pad] &= ~source_streams_mask;
ub960_disable_tx_port(priv,
ub960_update_streaming_status(priv);
return ret;
static int ub960_disable_streams(struct v4l2_subdev *sd,
u32 source_pad, u64 source_streams_mask)
unsigned int nport;
int ret;
/* Collect sink streams per pad which we need to disable */
continue;
continue;
continue;
if (ret)
/* Disable TX port if no active streams */
return 0;
static int _ub960_set_routing(struct v4l2_subdev *sd,
struct v4l2_subdev_krouting *routing)
static const struct v4l2_mbus_framefmt format = {
.width = 640,
.height = 480,
.field = V4L2_FIELD_NONE,
.colorspace = V4L2_COLORSPACE_SRGB,
.ycbcr_enc = V4L2_YCBCR_ENC_601,
.quantization = V4L2_QUANTIZATION_LIM_RANGE,
.xfer_func = V4L2_XFER_FUNC_SRGB,
int ret;
* Note: we can only support up to V4L2_FRAME_DESC_ENTRY_MAX, until
* frame desc is made dynamically allocated.
if (routing->num_routes > V4L2_FRAME_DESC_ENTRY_MAX)
return -E2BIG;
ret = v4l2_subdev_routing_validate(sd, routing,
V4L2_SUBDEV_ROUTING_ONLY_1_TO_1 |
V4L2_SUBDEV_ROUTING_NO_SINK_STREAM_MIX);
if (ret)
return ret;
ret = v4l2_subdev_set_routing_with_fmt(sd, state, routing, &format);
if (ret)
return ret;
return 0;
static int ub960_set_routing(struct v4l2_subdev *sd,
enum v4l2_subdev_format_whence which,
if (which == V4L2_SUBDEV_FORMAT_ACTIVE && priv->streaming)
return -EBUSY;
return _ub960_set_routing(sd, state, routing);
static inline u8 ub960_get_output_vc(u8 map, u8 input_vc)
return (map >> (2 * input_vc)) & 0x03;
static int ub960_get_frame_desc(struct v4l2_subdev *sd, unsigned int pad,
struct v4l2_mbus_frame_desc *fd)
struct v4l2_subdev_state *state;
int ret = 0;
if (!ub960_pad_is_source(priv, pad))
return -EINVAL;
fd->type = V4L2_MBUS_FRAME_DESC_TYPE_CSI2;
state = v4l2_subdev_lock_and_get_active_state(&priv->sd);
struct v4l2_mbus_frame_desc_entry *source_entry = NULL;
unsigned int nport;
unsigned int i;
if (route->source_pad != pad)
continue;
get_frame_desc,
&source_fd);
if (ret) {
dev_err(dev,
"Failed to get source frame desc for pad %u\n",
route->sink_pad);
goto out_unlock;
for (i = 0; i < source_fd.num_entries; i++) {
if (source_fd.entry[i].stream == route->sink_stream) {
source_entry = &source_fd.entry[i];
break;
if (!source_entry) {
dev_err(dev,
"Failed to find stream from source frame desc\n");
ret = -EPIPE;
goto out_unlock;
fd->entry[fd->num_entries].stream = route->source_stream;
fd->entry[fd->num_entries].flags = source_entry->flags;
fd->entry[fd->num_entries].length = source_entry->length;
fd->entry[fd->num_entries].pixelcode = source_entry->pixelcode;
fd->entry[fd->num_entries].bus.csi2.vc =
ub960_get_output_vc(vc_map[nport],
source_entry->bus.csi2.vc);
dev_dbg(dev, "Mapping sink %d/%d to output VC %d",
route->sink_pad, route->sink_stream,
fd->entry[fd->num_entries].bus.csi2.vc);
if (source_fd.type == V4L2_MBUS_FRAME_DESC_TYPE_CSI2) {
fd->entry[fd->num_entries].bus.csi2.dt =
source_entry->bus.csi2.dt;
} else {
fmt = v4l2_subdev_state_get_format(state, pad,
route->source_stream);
if (!fmt) {
ret = -EINVAL;
goto out_unlock;
if (!ub960_fmt) {
dev_err(dev, "Unable to find format\n");
ret = -EINVAL;
goto out_unlock;
fd->num_entries++;
out_unlock:
v4l2_subdev_unlock_state(state);
return ret;
static int ub960_set_fmt(struct v4l2_subdev *sd,
struct v4l2_subdev_format *format)
if (format->which == V4L2_SUBDEV_FORMAT_ACTIVE && priv->streaming)
return -EBUSY;
/* No transcoding, source and sink formats must match. */
if (ub960_pad_is_source(priv, format->pad))
return v4l2_subdev_get_fmt(sd, state, format);
* Default to the first format if the requested media bus code isn't
* supported.
if (!ub960_find_format(format->format.code))
format->format.code = ub960_formats[0].code;
fmt = v4l2_subdev_state_get_format(state, format->pad, format->stream);
if (!fmt)
return -EINVAL;
*fmt = format->format;
fmt = v4l2_subdev_state_get_opposite_stream_format(state, format->pad,
format->stream);
if (!fmt)
return -EINVAL;
return 0;
static int ub960_init_state(struct v4l2_subdev *sd,
struct v4l2_subdev_route routes[] = {
.sink_pad = 0,
.sink_stream = 0,
.source_pad = priv->hw_data->num_rxports,
.source_stream = 0,
.flags = V4L2_SUBDEV_ROUTE_FL_ACTIVE,
struct v4l2_subdev_krouting routing = {
.num_routes = ARRAY_SIZE(routes),
.routes = routes,
return _ub960_set_routing(sd, state, &routing);
static const struct v4l2_subdev_pad_ops ub960_pad_ops = {
.enable_streams = ub960_enable_streams,
.disable_streams = ub960_disable_streams,
.set_routing = ub960_set_routing,
.get_frame_desc = ub960_get_frame_desc,
.get_fmt = v4l2_subdev_get_fmt,
.set_fmt = ub960_set_fmt,
static void ub960_log_status_ub960_sp_eq(struct ub960_data *priv,
unsigned int nport)
u8 eq_level;
s8 strobe_pos;
u8 v = 0;
/* Strobe */
ub960_read(priv, UB960_XR_AEQ_CTL1, &v);
dev_info(dev, "\t%s strobe\n",
(v & UB960_XR_AEQ_CTL1_AEQ_SFILTER_EN) ? "Adaptive" :
"Manual");
if (v & UB960_XR_AEQ_CTL1_AEQ_SFILTER_EN) {
ub960_read(priv, UB960_XR_SFILTER_CFG, &v);
dev_info(dev, "\tStrobe range [%d, %d]\n",
((v >> UB960_XR_SFILTER_CFG_SFILTER_MIN_SHIFT) & 0xf) - 7,
((v >> UB960_XR_SFILTER_CFG_SFILTER_MAX_SHIFT) & 0xf) - 7);
ub960_rxport_get_strobe_pos(priv, nport, &strobe_pos);
dev_info(dev, "\tStrobe pos %d\n", strobe_pos);
/* EQ */
dev_info(dev, "\t%s EQ\n",
(v & UB960_RR_AEQ_BYPASS_ENABLE) ? "Manual" :
"Adaptive");
if (!(v & UB960_RR_AEQ_BYPASS_ENABLE)) {
ub960_rxport_read(priv, nport, UB960_RR_AEQ_MIN_MAX, &v);
dev_info(dev, "\tEQ range [%u, %u]\n",
(v >> UB960_RR_AEQ_MIN_MAX_AEQ_FLOOR_SHIFT) & 0xf,
(v >> UB960_RR_AEQ_MIN_MAX_AEQ_MAX_SHIFT) & 0xf);
if (ub960_rxport_get_eq_level(priv, nport, &eq_level) == 0)
dev_info(dev, "\tEQ level %u\n", eq_level);
static int ub960_log_status(struct v4l2_subdev *sd)
unsigned int nport;
unsigned int i;
u16 v16 = 0;
u8 v = 0;
u8 id[UB960_SR_FPD3_RX_ID_LEN];
state = v4l2_subdev_lock_and_get_active_state(sd);
for (i = 0; i < sizeof(id); i++)
ub960_read(priv, UB960_SR_FPD3_RX_ID(i), &id[i]);
dev_info(dev, "ID '%.*s'\n", (int)sizeof(id), id);
dev_info(dev, "TX %u\n", nport);
if (!txport) {
dev_info(dev, "\tNot initialized\n");
continue;
ub960_txport_read(priv, nport, UB960_TR_CSI_STS, &v);
dev_info(dev, "\tsync %u, pass %u\n", v & (u8)BIT(1),
v & (u8)BIT(0));
ub960_read16(priv, UB960_SR_CSI_FRAME_COUNT_HI(nport), &v16);
dev_info(dev, "\tframe counter %u\n", v16);
ub960_read16(priv, UB960_SR_CSI_FRAME_ERR_COUNT_HI(nport), &v16);
dev_info(dev, "\tframe error counter %u\n", v16);
ub960_read16(priv, UB960_SR_CSI_LINE_COUNT_HI(nport), &v16);
dev_info(dev, "\tline counter %u\n", v16);
ub960_read16(priv, UB960_SR_CSI_LINE_ERR_COUNT_HI(nport), &v16);
dev_info(dev, "\tline error counter %u\n", v16);
unsigned int i;
dev_info(dev, "RX %u\n", nport);
if (!rxport) {
continue;
if (v & UB960_RR_RX_PORT_STS1_LOCK_STS)
dev_info(dev, "\tLocked\n");
else
dev_info(dev, "\tNot locked\n");
dev_info(dev, "\trx_port_sts1 %#02x\n", v);
dev_info(dev, "\trx_port_sts2 %#02x\n", v);
ub960_rxport_read16(priv, nport, UB960_RR_RX_FREQ_HIGH, &v16);
dev_info(dev, "\tlink freq %llu Hz\n", (v16 * 1000000ULL) >> 8);
ub960_rxport_read16(priv, nport, UB960_RR_RX_PAR_ERR_HI, &v16);
dev_info(dev, "\tparity errors %u\n", v16);
ub960_rxport_read16(priv, nport, UB960_RR_LINE_COUNT_HI, &v16);
dev_info(dev, "\tlines per frame %u\n", v16);
ub960_rxport_read16(priv, nport, UB960_RR_LINE_LEN_1, &v16);
dev_info(dev, "\tbytes per line %u\n", v16);
dev_info(dev, "\tcsi_err_counter %u\n", v);
ub960_log_status_ub960_sp_eq(priv, nport);
/* GPIOs */
for (i = 0; i < UB960_NUM_BC_GPIOS; i++) {
u8 ctl_reg;
u8 ctl_shift;
ctl_reg = UB960_RR_BC_GPIO_CTL(i / 2);
ctl_shift = (i % 2) * 4;
ub960_rxport_read(priv, nport, ctl_reg, &v);
dev_info(dev, "\tGPIO%u: mode %u\n", i,
(v >> ctl_shift) & 0xf);
return 0;
static const struct v4l2_subdev_core_ops ub960_subdev_core_ops = {
.log_status = ub960_log_status,
.subscribe_event = v4l2_ctrl_subdev_subscribe_event,
.unsubscribe_event = v4l2_event_subdev_unsubscribe,
static const struct v4l2_subdev_internal_ops ub960_internal_ops = {
.init_state = ub960_init_state,
static const struct v4l2_subdev_ops ub960_subdev_ops = {
.core = &ub960_subdev_core_ops,
.pad = &ub960_pad_ops,
static const struct media_entity_operations ub960_entity_ops = {
.get_fwnode_pad = v4l2_subdev_get_fwnode_pad_1_to_1,
.link_validate = v4l2_subdev_link_validate,
.has_pad_interdep = v4l2_subdev_has_pad_interdep,
* Core
static irqreturn_t ub960_handle_events(int irq, void *arg)
struct ub960_data *priv = arg;
unsigned int i;
u8 int_sts;
u8 fwd_sts;
int ret;
ret = ub960_read(priv, UB960_SR_INTERRUPT_STS, &int_sts);
if (ret || !int_sts)
return IRQ_NONE;
dev_dbg(&priv->client->dev, "INTERRUPT_STS %x\n", int_sts);
ret = ub960_read(priv, UB960_SR_FWD_STS, &fwd_sts);
if (ret)
return IRQ_NONE;
dev_dbg(&priv->client->dev, "FWD_STS %#02x\n", fwd_sts);
for (i = 0; i < priv->hw_data->num_txports; i++) {
if (int_sts & UB960_SR_INTERRUPT_STS_IS_CSI_TX(i))
ub960_csi_handle_events(priv, i);
for (i = 0; i < priv->hw_data->num_rxports; i++) {
if (!priv->rxports[i])
continue;
if (int_sts & UB960_SR_INTERRUPT_STS_IS_RX(i))
ub960_rxport_handle_events(priv, i);
return IRQ_HANDLED;
static void ub960_handler_work(struct work_struct *work)
struct delayed_work *dwork = to_delayed_work(work);
container_of(dwork, struct ub960_data, poll_work);
ub960_handle_events(0, priv);
schedule_delayed_work(&priv->poll_work,
msecs_to_jiffies(UB960_POLL_TIME_MS));
static void ub960_txport_free_ports(struct ub960_data *priv)
unsigned int nport;
if (!txport)
continue;
kfree(txport);
priv->txports[nport] = NULL;
static void ub960_rxport_free_ports(struct ub960_data *priv)
unsigned int nport;
if (!rxport)
continue;
fwnode_handle_put(rxport->source.ep_fwnode);
fwnode_handle_put(rxport->ser.fwnode);
kfree(rxport);
priv->rxports[nport] = NULL;
static int
ub960_parse_dt_rxport_link_properties(struct ub960_data *priv,
struct fwnode_handle *link_fwnode,
u32 rx_mode;
u32 cdr_mode;
s32 strobe_pos;
u32 eq_level;
u32 ser_i2c_alias;
int ret;
cdr_mode = RXPORT_CDR_FPD3;
ret = fwnode_property_read_u32(link_fwnode, "ti,cdr-mode", &cdr_mode);
if (ret < 0 && ret != -EINVAL) {
dev_err(dev, "rx%u: failed to read '%s': %d\n", nport,
"ti,cdr-mode", ret);
return ret;
if (cdr_mode > RXPORT_CDR_LAST) {
dev_err(dev, "rx%u: bad 'ti,cdr-mode' %u\n", nport, cdr_mode);
return -EINVAL;
if (!priv->hw_data->is_fpdlink4 && cdr_mode == RXPORT_CDR_FPD4) {
dev_err(dev, "rx%u: FPD-Link 4 CDR not supported\n", nport);
return -EINVAL;
rxport->cdr_mode = cdr_mode;
ret = fwnode_property_read_u32(link_fwnode, "ti,rx-mode", &rx_mode);
if (ret < 0) {
"ti,rx-mode", ret);
return ret;
if (rx_mode > RXPORT_MODE_LAST) {
dev_err(dev, "rx%u: bad 'ti,rx-mode' %u\n", nport, rx_mode);
return -EINVAL;
switch (rx_mode) {
dev_err(dev, "rx%u: unsupported 'ti,rx-mode' %u\n", nport,
rx_mode);
return -EINVAL;
default:
break;
rxport->rx_mode = rx_mode;
/* EQ & Strobe related */
/* Defaults */
rxport->eq.manual_eq = false;
rxport->eq.aeq.eq_level_min = UB960_MIN_EQ_LEVEL;
rxport->eq.aeq.eq_level_max = UB960_MAX_EQ_LEVEL;
ret = fwnode_property_read_u32(link_fwnode, "ti,strobe-pos",
&strobe_pos);
if (ret) {
if (ret != -EINVAL) {
"ti,strobe-pos", ret);
return ret;
} else {
if (strobe_pos < UB960_MIN_MANUAL_STROBE_POS ||
strobe_pos > UB960_MAX_MANUAL_STROBE_POS) {
dev_err(dev, "rx%u: illegal 'strobe-pos' value: %d\n",
nport, strobe_pos);
return -EINVAL;
/* NOTE: ignored unless global manual strobe pos is also set */
rxport->eq.strobe_pos = strobe_pos;
if (!priv->strobe.manual)
dev_warn(dev,
"rx%u: 'ti,strobe-pos' ignored as 'ti,manual-strobe' not set\n",
nport);
ret = fwnode_property_read_u32(link_fwnode, "ti,eq-level", &eq_level);
if (ret) {
"ti,eq-level", ret);
return ret;
} else {
if (eq_level > UB960_MAX_EQ_LEVEL) {
dev_err(dev, "rx%u: illegal 'ti,eq-level' value: %d\n",
nport, eq_level);
return -EINVAL;
rxport->eq.manual_eq = true;
rxport->eq.manual.eq_level = eq_level;
ret = fwnode_property_read_u32(link_fwnode, "i2c-alias",
&ser_i2c_alias);
if (ret) {
"i2c-alias", ret);
return ret;
rxport->ser.alias = ser_i2c_alias;
rxport->ser.fwnode = fwnode_get_named_child_node(link_fwnode, "serializer");
if (!rxport->ser.fwnode) {
dev_err(dev, "rx%u: missing 'serializer' node\n", nport);
return -EINVAL;
return 0;
static int ub960_parse_dt_rxport_ep_properties(struct ub960_data *priv,
bool hsync_hi;
bool vsync_hi;
int ret;
rxport->source.ep_fwnode = fwnode_graph_get_remote_endpoint(ep_fwnode);
if (!rxport->source.ep_fwnode) {
dev_err(dev, "rx%u: no remote endpoint\n", nport);
return -ENODEV;
/* We currently have properties only for RAW modes */
break;
default:
return 0;
vep.bus_type = V4L2_MBUS_PARALLEL;
ret = v4l2_fwnode_endpoint_parse(ep_fwnode, &vep);
if (ret) {
dev_err(dev, "rx%u: failed to parse endpoint data\n", nport);
goto err_put_source_ep_fwnode;
hsync_hi = !!(vep.bus.parallel.flags & V4L2_MBUS_HSYNC_ACTIVE_HIGH);
vsync_hi = !!(vep.bus.parallel.flags & V4L2_MBUS_VSYNC_ACTIVE_HIGH);
/* LineValid and FrameValid are inverse to the h/vsync active */
rxport->lv_fv_pol = (hsync_hi ? UB960_RR_PORT_CONFIG2_LV_POL_LOW : 0) |
(vsync_hi ? UB960_RR_PORT_CONFIG2_FV_POL_LOW : 0);
return 0;
err_put_source_ep_fwnode:
return ret;
static int ub960_parse_dt_rxport(struct ub960_data *priv, unsigned int nport,
struct fwnode_handle *ep_fwnode)
static const char *vpoc_names[UB960_MAX_RX_NPORTS] = {
"vpoc0", "vpoc1", "vpoc2", "vpoc3"
int ret;
rxport = kzalloc(sizeof(*rxport), GFP_KERNEL);
if (!rxport)
return -ENOMEM;
priv->rxports[nport] = rxport;
rxport->nport = nport;
rxport->priv = priv;
ret = ub960_parse_dt_rxport_link_properties(priv, link_fwnode, rxport);
if (ret)
goto err_free_rxport;
rxport->vpoc = devm_regulator_get_optional(dev, vpoc_names[nport]);
if (IS_ERR(rxport->vpoc)) {
ret = PTR_ERR(rxport->vpoc);
if (ret == -ENODEV) {
rxport->vpoc = NULL;
} else {
dev_err(dev, "rx%u: failed to get VPOC supply: %d\n",
nport, ret);
goto err_put_remote_fwnode;
ret = ub960_parse_dt_rxport_ep_properties(priv, ep_fwnode, rxport);
if (ret)
return 0;
err_put_remote_fwnode:
err_free_rxport:
kfree(rxport);
return ret;
static struct fwnode_handle *
ub960_fwnode_get_link_by_regs(struct fwnode_handle *links_fwnode,
unsigned int nport)
struct fwnode_handle *link_fwnode;
int ret;
fwnode_for_each_child_node(links_fwnode, link_fwnode) {
u32 link_num;
if (!str_has_prefix(fwnode_get_name(link_fwnode), "link@"))
continue;
ret = fwnode_property_read_u32(link_fwnode, "reg", &link_num);
if (ret) {
fwnode_handle_put(link_fwnode);
return NULL;
if (nport == link_num)
return link_fwnode;
return NULL;
static int ub960_parse_dt_rxports(struct ub960_data *priv)
struct fwnode_handle *links_fwnode;
unsigned int nport;
int ret;
links_fwnode = fwnode_get_named_child_node(dev_fwnode(dev), "links");
if (!links_fwnode) {
dev_err(dev, "'links' node missing\n");
return -ENODEV;
/* Defaults, recommended by TI */
priv->strobe.min = 2;
priv->strobe.max = 3;
priv->strobe.manual = fwnode_property_read_bool(links_fwnode, "ti,manual-strobe");
struct fwnode_handle *ep_fwnode;
link_fwnode = ub960_fwnode_get_link_by_regs(links_fwnode, nport);
if (!link_fwnode)
continue;
ep_fwnode = fwnode_graph_get_endpoint_by_id(dev_fwnode(dev),
nport, 0, 0);
if (!ep_fwnode) {
continue;
ret = ub960_parse_dt_rxport(priv, nport, link_fwnode,
ep_fwnode);
fwnode_handle_put(ep_fwnode);
if (ret) {
dev_err(dev, "rx%u: failed to parse RX port\n", nport);
goto err_put_links;
fwnode_handle_put(links_fwnode);
return 0;
err_put_links:
return ret;
static int ub960_parse_dt_txports(struct ub960_data *priv)
u32 nport;
int ret;
unsigned int port = nport + priv->hw_data->num_rxports;
port, 0, 0);
if (!ep_fwnode)
continue;
ret = ub960_parse_dt_txport(priv, ep_fwnode, nport);
if (ret)
break;
return 0;
static void ub960_parse_active_ports(struct ub960_data *priv)
int nport;
priv->rx_mask = 0;
priv->tx_mask = 0;
for (nport = 0; nport < priv->hw_data->num_rxports + priv->hw_data->num_txports; nport++) {
ep_fwnode = fwnode_graph_get_endpoint_by_id(dev_fwnode(dev), nport, 0, 0);
if (!ep_fwnode)
continue;
if (nport < priv->hw_data->num_rxports)
priv->rx_mask |= BIT(nport);
else
priv->tx_mask |= BIT(nport);
static int ub960_parse_dt(struct ub960_data *priv)
int ret;
ret = ub960_parse_dt_rxports(priv);
if (ret)
return ret;
ret = ub960_parse_dt_txports(priv);
if (ret)
goto err_free_rxports;
return 0;
err_free_rxports:
ub960_rxport_free_ports(priv);
return ret;
static int ub960_notify_bound(struct v4l2_async_notifier *notifier,
struct v4l2_subdev *subdev,
struct ub960_data *priv = sd_to_ub960(notifier->sd);
struct ub960_rxport *rxport = to_ub960_asd(asd)->rxport;
u8 nport = rxport->nport;
unsigned int i;
int ret;
ret = media_entity_get_fwnode_pad(&subdev->entity,
rxport->source.ep_fwnode,
MEDIA_PAD_FL_SOURCE);
if (ret < 0) {
dev_err(dev, "Failed to find pad for %s\n", subdev->name);
return ret;
rxport->source.sd = subdev;
rxport->source.pad = ret;
ret = media_create_pad_link(&rxport->source.sd->entity,
rxport->source.pad, &priv->sd.entity, nport,
MEDIA_LNK_FL_ENABLED |
MEDIA_LNK_FL_IMMUTABLE);
if (ret) {
dev_err(dev, "Unable to link %s:%u -> %s:%u\n",
rxport->source.sd->name, rxport->source.pad,
priv->sd.name, nport);
return ret;
if (priv->rxports[i] && !priv->rxports[i]->source.sd) {
dev_dbg(dev, "Waiting for more subdevs to be bound\n");
return 0;
return 0;
static void ub960_notify_unbind(struct v4l2_async_notifier *notifier,
rxport->source.sd = NULL;
static const struct v4l2_async_notifier_operations ub960_notify_ops = {
.bound = ub960_notify_bound,
.unbind = ub960_notify_unbind,
static int ub960_v4l2_notifier_register(struct ub960_data *priv)
unsigned int i;
int ret;
v4l2_async_subdev_nf_init(&priv->notifier, &priv->sd);
struct ub960_rxport *rxport = priv->rxports[i];
struct ub960_asd *asd;
if (!rxport)
continue;
asd = v4l2_async_nf_add_fwnode(&priv->notifier,
struct ub960_asd);
if (IS_ERR(asd)) {
dev_err(dev, "Failed to add subdev for source %u: %pe",
i, asd);
v4l2_async_nf_cleanup(&priv->notifier);
return PTR_ERR(asd);
asd->rxport = rxport;
priv->notifier.ops = &ub960_notify_ops;
ret = v4l2_async_nf_register(&priv->notifier);
if (ret) {
dev_err(dev, "Failed to register subdev_notifier");
return ret;
return 0;
static void ub960_v4l2_notifier_unregister(struct ub960_data *priv)
v4l2_async_nf_unregister(&priv->notifier);
static int ub960_create_subdev(struct ub960_data *priv)
unsigned int i;
int ret;
v4l2_i2c_subdev_init(&priv->sd, priv->client, &ub960_subdev_ops);
priv->sd.internal_ops = &ub960_internal_ops;
v4l2_ctrl_handler_init(&priv->ctrl_handler, 1);
priv->sd.ctrl_handler = &priv->ctrl_handler;
v4l2_ctrl_new_int_menu(&priv->ctrl_handler, NULL, V4L2_CID_LINK_FREQ,
ARRAY_SIZE(priv->tx_link_freq) - 1, 0,
priv->tx_link_freq);
if (priv->ctrl_handler.error) {
ret = priv->ctrl_handler.error;
goto err_free_ctrl;
priv->sd.flags |= V4L2_SUBDEV_FL_HAS_DEVNODE |
V4L2_SUBDEV_FL_HAS_EVENTS | V4L2_SUBDEV_FL_STREAMS;
priv->sd.entity.function = MEDIA_ENT_F_VID_IF_BRIDGE;
priv->sd.entity.ops = &ub960_entity_ops;
for (i = 0; i < priv->hw_data->num_rxports + priv->hw_data->num_txports; i++) {
priv->pads[i].flags = ub960_pad_is_sink(priv, i) ?
MEDIA_PAD_FL_SINK :
MEDIA_PAD_FL_SOURCE;
ret = media_entity_pads_init(&priv->sd.entity,
priv->hw_data->num_txports,
priv->pads);
if (ret)
goto err_free_ctrl;
priv->sd.state_lock = priv->sd.ctrl_handler->lock;
ret = v4l2_subdev_init_finalize(&priv->sd);
if (ret)
goto err_entity_cleanup;
ret = ub960_v4l2_notifier_register(priv);
if (ret) {
dev_err(dev, "v4l2 subdev notifier register failed: %d\n", ret);
goto err_subdev_cleanup;
ret = v4l2_async_register_subdev(&priv->sd);
if (ret) {
dev_err(dev, "v4l2_async_register_subdev error: %d\n", ret);
goto err_unreg_notif;
return 0;
err_unreg_notif:
ub960_v4l2_notifier_unregister(priv);
err_subdev_cleanup:
v4l2_subdev_cleanup(&priv->sd);
err_entity_cleanup:
media_entity_cleanup(&priv->sd.entity);
err_free_ctrl:
v4l2_ctrl_handler_free(&priv->ctrl_handler);
return ret;
static void ub960_destroy_subdev(struct ub960_data *priv)
v4l2_async_unregister_subdev(&priv->sd);
static const struct regmap_config ub960_regmap_config = {
.name = "ds90ub960",
.reg_bits = 8,
.val_bits = 8,
.max_register = 0xff,
* We do locking in the driver to cover the TX/RX port selection and the
* indirect register access.
.disable_locking = true,
static void ub960_reset(struct ub960_data *priv, bool reset_regs)
unsigned int v;
int ret;
u8 bit;
bit = reset_regs ? UB960_SR_RESET_DIGITAL_RESET1 :
UB960_SR_RESET_DIGITAL_RESET0;
ub960_write(priv, UB960_SR_RESET, bit);
mutex_lock(&priv->reg_lock);
ret = regmap_read_poll_timeout(priv->regmap, UB960_SR_RESET, v,
(v & bit) == 0, 2000, 100000);
mutex_unlock(&priv->reg_lock);
if (ret)
dev_err(dev, "reset failed: %d\n", ret);
static int ub960_get_hw_resources(struct ub960_data *priv)
priv->regmap = devm_regmap_init_i2c(priv->client, &ub960_regmap_config);
if (IS_ERR(priv->regmap))
return PTR_ERR(priv->regmap);
priv->vddio = devm_regulator_get(dev, "vddio");
if (IS_ERR(priv->vddio))
return dev_err_probe(dev, PTR_ERR(priv->vddio),
"cannot get VDDIO regulator\n");
/* get power-down pin from DT */
priv->pd_gpio =
devm_gpiod_get_optional(dev, "powerdown", GPIOD_OUT_HIGH);
if (IS_ERR(priv->pd_gpio))
return dev_err_probe(dev, PTR_ERR(priv->pd_gpio),
"Cannot get powerdown GPIO\n");
priv->refclk = devm_clk_get(dev, "refclk");
if (IS_ERR(priv->refclk))
return dev_err_probe(dev, PTR_ERR(priv->refclk),
"Cannot get REFCLK\n");
return 0;
static int ub960_enable_core_hw(struct ub960_data *priv)
u8 rev_mask;
int ret;
u8 dev_sts;
u8 refclk_freq;
ret = regulator_enable(priv->vddio);
if (ret)
return dev_err_probe(dev, ret,
"failed to enable VDDIO regulator\n");
ret = clk_prepare_enable(priv->refclk);
if (ret) {
dev_err_probe(dev, ret, "Failed to enable refclk\n");
goto err_disable_vddio;
if (priv->pd_gpio) {
gpiod_set_value_cansleep(priv->pd_gpio, 1);
/* wait min 2 ms for reset to complete */
fsleep(2000);
gpiod_set_value_cansleep(priv->pd_gpio, 0);
/* wait min 2 ms for power up to finish */
fsleep(2000);
ub960_reset(priv, true);
/* Runtime check register accessibility */
ret = ub960_read(priv, UB960_SR_REV_MASK, &rev_mask);
if (ret) {
dev_err_probe(dev, ret, "Cannot read first register, abort\n");
goto err_pd_gpio;
dev_dbg(dev, "Found %s (rev/mask %#04x)\n", priv->hw_data->model,
rev_mask);
ret = ub960_read(priv, UB960_SR_DEVICE_STS, &dev_sts);
if (ret)
goto err_pd_gpio;
ret = ub960_read(priv, UB9702_SR_REFCLK_FREQ, &refclk_freq);
else
ret = ub960_read(priv, UB960_XR_REFCLK_FREQ, &refclk_freq);
if (ret)
goto err_pd_gpio;
dev_dbg(dev, "refclk valid %u freq %u MHz (clk fw freq %lu MHz)\n",
!!(dev_sts & BIT(4)), refclk_freq,
clk_get_rate(priv->refclk) / 1000000);
/* release GPIO lock */
ret = ub960_update_bits(priv, UB960_SR_RESET,
UB960_SR_RESET_GPIO_LOCK_RELEASE,
UB960_SR_RESET_GPIO_LOCK_RELEASE);
if (ret)
goto err_pd_gpio;
return 0;
err_pd_gpio:
clk_disable_unprepare(priv->refclk);
err_disable_vddio:
regulator_disable(priv->vddio);
return ret;
static void ub960_disable_core_hw(struct ub960_data *priv)
static int ub960_probe(struct i2c_client *client)
struct device *dev = &client->dev;
struct ub960_data *priv;
unsigned int port_lock_mask;
unsigned int port_mask;
unsigned int nport;
int ret;
priv = devm_kzalloc(dev, sizeof(*priv), GFP_KERNEL);
if (!priv)
return -ENOMEM;
priv->client = client;
priv->hw_data = device_get_match_data(dev);
mutex_init(&priv->reg_lock);
INIT_DELAYED_WORK(&priv->poll_work, ub960_handler_work);
* Initialize these to invalid values so that the first reg writes will
* configure the target.
priv->reg_current.indirect_target = 0xff;
priv->reg_current.rxport = 0xff;
priv->reg_current.txport = 0xff;
ret = ub960_get_hw_resources(priv);
if (ret)
goto err_mutex_destroy;
ret = ub960_enable_core_hw(priv);
if (ret)
ub960_parse_active_ports(priv);
ret = ub960_parse_dt(priv);
if (ret)
goto err_disable_core_hw;
ret = ub960_init_tx_ports(priv);
if (ret)
goto err_free_ports;
ret = ub960_rxport_enable_vpocs(priv);
if (ret)
ret = ub960_init_rx_ports(priv);
if (ret)
ub960_reset(priv, false);
port_mask = 0;
if (!rxport)
continue;
port_mask |= BIT(nport);
ret = ub960_rxport_wait_locks(priv, port_mask, &port_lock_mask);
if (ret)
if (port_mask != port_lock_mask) {
ret = -EIO;
dev_err_probe(dev, ret, "Failed to lock all RX ports\n");
* Clear any errors caused by switching the RX port settings while
* probing.
ub960_clear_rx_errors(priv);
ret = ub960_init_atr(priv);
if (ret)
ret = ub960_rxport_add_serializers(priv);
if (ret)
goto err_uninit_atr;
ret = ub960_create_subdev(priv);
if (ret)
goto err_free_sers;
if (client->irq)
dev_warn(dev, "irq support not implemented, using polling\n");
return 0;
err_free_sers:
ub960_rxport_remove_serializers(priv);
err_uninit_atr:
ub960_uninit_atr(priv);
err_disable_vpocs:
ub960_rxport_disable_vpocs(priv);
err_free_ports:
ub960_txport_free_ports(priv);
err_disable_core_hw:
ub960_disable_core_hw(priv);
err_mutex_destroy:
mutex_destroy(&priv->reg_lock);
return ret;
static void ub960_remove(struct i2c_client *client)
struct v4l2_subdev *sd = i2c_get_clientdata(client);
cancel_delayed_work_sync(&priv->poll_work);
ub960_destroy_subdev(priv);
static const struct ub960_hw_data ds90ub954_hw = {
.model = "ub954",
.num_rxports = 2,
.num_txports = 1,
.ignore_strobe_pos = true,
static const struct ub960_hw_data ds90ub960_hw = {
.model = "ub960",
.num_rxports = 4,
.num_txports = 2,
static const struct ub960_hw_data ds90ub9702_hw = {
.model = "ub9702",
.num_rxports = 4,
.num_txports = 2,
.is_ub9702 = true,
.is_fpdlink4 = true,
static const struct i2c_device_id ub960_id[] = {
{ "ds90ub954-q1", (kernel_ulong_t)&ds90ub954_hw },
{ "ds90ub960-q1", (kernel_ulong_t)&ds90ub960_hw },
{ "ds90ub9702-q1", (kernel_ulong_t)&ds90ub9702_hw },
MODULE_DEVICE_TABLE(i2c, ub960_id);
static const struct of_device_id ub960_dt_ids[] = {
{ .compatible = "ti,ds90ub954-q1", .data = &ds90ub954_hw },
{ .compatible = "ti,ds90ub960-q1", .data = &ds90ub960_hw },
{ .compatible = "ti,ds90ub9702-q1", .data = &ds90ub9702_hw },
MODULE_DEVICE_TABLE(of, ub960_dt_ids);
static struct i2c_driver ds90ub960_driver = {
.probe = ub960_probe,
.remove = ub960_remove,
.id_table = ub960_id,
.driver = {
.of_match_table = ub960_dt_ids,
module_i2c_driver(ds90ub960_driver);
MODULE_LICENSE("GPL");
MODULE_DESCRIPTION("Texas Instruments FPD-Link III/IV Deserializers Driver");
MODULE_AUTHOR("Luca Ceresoli <luca@lucaceresoli.net>");
MODULE_AUTHOR("Tomi Valkeinen <tomi.valkeinen@ideasonboard.com>");
MODULE_IMPORT_NS(I2C_ATR);
Hi Jeyaprakash,
Thank you for sharing your source code files. I'll need some additional time to review and modify, I'll get back to you once I've finished.
Lucas
Hi Jeyaprakash,
I've written code snippets which can be added to your source files to implement temp ramp initialization code. Unfortunately I don't see the sequence in which initialization occurs contained in these 2 files. Can you share your code in which initialization occurs? This should be a sequence of function calls from the 960 and 953 source files which initialize each device according to your system parameters. Once I see this sequence I can add function calls for temp ramp initialization.
Add to ds90ub960.c:
static int ub960_rxport_get_temp_code_95x(struct ub960_data *priv,
unsigned int nport, u8 *temp_code_95x)
int ret;
u8 v;
ret = ub960_rxport_read(priv, nport, UB960_RR_SENSOR_STS_2, &v);
if (ret)
return ret;
*temp_code_95x = v;
return 0;
Add to ds90ub953.c:
#define UB953_IND_TX_TEMP_RAMP_DYNAMIC_CFG 0x4b
#define UB953_IND_TX_TEMP_RAMP_STATIC_CFG 0x4c
static int ub953_temp_ramp_ext(struct ub953_data *priv,
u8 temp_code_95x)
int ret;
u8 vdac;
u8 vco_tweak;
int vdac_offset[8] = {-1, -1, 0, 0, 1, 1, 1, 3};
ret = ub953_read_ind(priv, UB953_IND_TARGET_FPD3_TX, UB953_IND_TX_TEMP_RAMP_DYNAMIC_CFG, &vdac);
if (ret)
return ret;
vdac = vdac | 0x20;
ret = ub953_read_ind(priv, UB953_IND_TARGET_FPD3_TX, UB953_IND_TX_TEMP_RAMP_STATIC_CFG, &vco_tweak);
if (ret)
return ret;
vco_tweak = (vco_tweak & 0x8f) | 0x70
ret = ub953_write_ind(priv, UB953_IND_TARGET_FPD3_TX, UB953_IND_TX_TEMP_RAMP_STATIC_CFG, vco_tweak);
if (ret)
return ret;
ret = ub953_write_ind(priv, UB953_IND_TARGET_FPD3_TX, UB953_IND_TX_TEMP_RAMP_DYNAMIC_CFG, vdac + vdac_offset[temp_code_95x]);
if (ret)
return ret;
ret = ub953_write(priv, UB953_REG_RESET_CTL, UB953_REG_RESET_CTL_DIGITAL_RESET_0);
if (ret)
return ret;
// add 20ms delay
return 0;
Lucas
Hi Lucas,
Thanks for your information.
Currently we don't have separate initialisation code. We do only use ds90ub960.c and ds90ub953.c sources for serailizer and deserializer.
The probe of these two driver will called from below device tree.
k3-j784s4-evm-fpdlink-iv-fusion.dtso:
// SPDX-License-Identifier: GPL-2.0-only OR MIT
* DT Overlay for FPDLink IV UB9702 Deserializer on J784S4 EVM
* https://www.ti.com/tool/J7EXPA01EVM
* Copyright (C) 2025 Texas Instruments Incorporated - https://www.ti.com/
/dts-v1/;
/plugin/;
#include <dt-bindings/gpio/gpio.h>
clk_fusion_25M_fixed: fixed-clock-25M {
compatible = "fixed-clock";
#clock-cells = <0>;
clock-frequency = <25000000>;
&exp5 {
p0-hog{
gpio-hog;
gpios = <0 GPIO_ACTIVE_HIGH>;
output-high;
line-name = "CSI2_EXP_RSTZ";
&main_i2c5 {
#address-cells = <1>;
#size-cells = <0>;
status = "okay";
deser@3d {
compatible = "ti,ds90ub9702-q1";
reg = <0x3d>;
clocks = <&clk_fusion_25M_fixed>;
clock-names = "refclk";
i2c-alias-pool = <0x48 0x49 0x4a 0x4b 0x4c 0x4d 0x4e 0x4f>;
deserializer_0_ports: ports {
#size-cells = <0>;
/* CSI-2 TX */
port@4 {
reg = <4>;
ds90ub970_0_csi_out: endpoint {
clock-lanes = <0>;
data-lanes = <1 2 3 4>;
link-frequencies = /bits/ 64 <800000000>;
remote-endpoint = <&csi2_phy0>;
deserializer_0_links: links {
#size-cells = <0>;
deser@30 {
reg = <0x30>;
i2c-alias-pool = <0x58 0x59 0x5a 0x5b 0x5c 0x5d 0x5e 0x5f>;
deserializer_1_ports: ports {
#size-cells = <0>;
/* CSI-2 TX */
port@4 {
reg = <4>;
ds90ub970_1_csi_out: endpoint {
clock-lanes = <0>;
remote-endpoint = <&csi2_phy1>;
deserializer_1_links: links {
#size-cells = <0>;
deser@32 {
reg = <0x32>;
i2c-alias-pool = <0x68 0x69 0x6a 0x6b 0x6c 0x6d 0x6e 0x6f>;
deserializer_2_ports: ports {
#size-cells = <0>;
/* CSI-2 TX */
port@4 {
reg = <4>;
ds90ub970_2_csi_out: endpoint {
clock-lanes = <0>;
remote-endpoint = <&csi2_phy2>;
deserializer_2_links: links {
#size-cells = <0>;
&cdns_csi2rx0 {
ports {
#size-cells = <0>;
csi0_port0: port@0 {
reg = <0>;
status = "okay";
csi2_phy0: endpoint {
remote-endpoint = <&ds90ub970_0_csi_out>;
clock-lanes = <0>;
&cdns_csi2rx1 {
ports {
#size-cells = <0>;
csi1_port0: port@0 {
reg = <0>;
status = "okay";
csi2_phy1: endpoint {
remote-endpoint = <&ds90ub970_1_csi_out>;
bus-type = <4>; /* CSI2 DPHY */
clock-lanes = <0>;
&cdns_csi2rx2 {
ports {
#size-cells = <0>;
csi2_port0: port@0 {
reg = <0>;
status = "okay";
csi2_phy2: endpoint {
remote-endpoint = <&ds90ub970_2_csi_out>;
clock-lanes = <0>;
&ti_csi2rx0 {
status = "okay";
&ti_csi2rx1 {
status = "okay";
&ti_csi2rx2 {
status = "okay";
&dphy0 {
status = "okay";
&dphy1 {
status = "okay";
&dphy2 {
status = "okay";
k3-fpdlink-iv-fusion-ox08b40-cam-0-0.dtso:
* OX08B40 E-con FPD-Link 4 Camera
/dts-v1/;
/plugin/;
#define MCU_FW_FILE "ox08b40_cam_fw.hex"
&deserializer_0_ports {
#size-cells = <0>;
/* FPDLink RX 0 */
port@0 {
reg = <0>;
ub9702_fpd4_1_in: endpoint {
remote-endpoint = <&ub971_1_out>;
&deserializer_0_links {
#size-cells = <0>;
link@0 {
reg = <0>;
i2c-alias = <0x44>;
ti,cdr-mode = <1>;
ti,rx-mode = <3>;
serializer: serializer {
compatible = "ti,ds90ub971-q1";
gpio-controller;
#gpio-cells = <2>;
#clock-cells = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
ub971_1_in: endpoint {
remote-endpoint = <&sensor_1_out>;
port@1 {
reg = <1>;
ub971_1_out: endpoint {
remote-endpoint = <&ub9702_fpd4_1_in>;
i2c {
#size-cells = <0>;
gpio_exp: expander-chip0@74 {
compatible = "ti,tca9539";
reg = <0x74>;
gpio-controller;
#gpio-cells = <2>;
ox08b40@43 {
compatible = "ti,ox08b40";
reg = <0x43>;
clocks = <&serializer>;
clock-names = "xvclk";
assigned-clocks = <&serializer>;
assigned-clock-rates = <24000000>;
mcu_fw_name = MCU_FW_FILE;
pwdn-gpios = <&gpio_exp 0 GPIO_ACTIVE_HIGH>;
reset-gpios = <&gpio_exp 1 GPIO_ACTIVE_HIGH>;
camstrobe-gpios = <&serializer 0 GPIO_ACTIVE_HIGH>; // Need during FSYNC case
port {
sensor_1_out: endpoint {
remote-endpoint = <&ub971_1_in>;
Adding one more point here. Once deserializer is failed lock on all RX ports serializer, probe of ds90ub953.c will not be called, hence we could not perform ub953_temp_ramp_ext.
Thanks in advance.
Jeyaprakash C K.
Hi Jeyaprakash,
Thank you for sharing your device tree files. Let me review and get back to you.
Lucas
Hi Jeyaprakash,
It's still a bit unclear to me how the link is initialized in your system. Although the dtso files share some information about configuration parameters, it's still unclear to me how functions are called from the C source files to initialize the link. Additionally it's unclear to me which FPD-Link devices are being used here. Can you help me gain a better understanding?
Lucas
Hi Lucas,
Thanks for noting, I have added latest version of files, let me give you a correct version of device tree which match the context of the post.
k3-j721e-sk-fpdlink-fusion.dtso:
* DT Overlay for Fusion (FPD-Link III) board on J721E SK,
* AM68 SK or AM69 SK.
* https://svtronics.com/portfolio/evm577pfusion-v1-0-fusion/
* Copyright (C) 2023 Texas Instruments Incorporated - http://www.ti.com/
/dts-v1/;
/plugin/;
#clock-cells = <0>;
&cam0_i2c {
#size-cells = <0>;
deser@30 {
compatible = "ti,ds90ub960-q1";
reg = <0x30>;
i2c-alias-pool = <0x33 0x34 0x35 0x36 0x37 0x48 0x49 0x4a 0x4b 0x4c 0x4d 0x4e 0x4f>;
#size-cells = <0>;
/* CSI-2 TX*/
port@4 {
reg = <4>;
ds90ub960_0_csi_out: endpoint {
clock-lanes = <0>;
#size-cells = <0>;
deser@36 {
reg = <0x36>;
status = "disabled";
i2c-alias-pool = <0x5a 0x5b 0x5c 0x5d 0x5e 0x5f>;
#size-cells = <0>;
/* CSI-2 TX*/
port@4 {
reg = <4>;
ds90ub960_1_csi_out: endpoint {
clock-lanes = <0>;
#size-cells = <0>;
&cdns_csi2rx0 {
ports {
#size-cells = <0>;
reg = <0>;
status = "okay";
remote-endpoint = <&ds90ub960_0_csi_out>;
clock-lanes = <0>;
&cdns_csi2rx1 {
ports {
#size-cells = <0>;
reg = <0>;
status = "okay";
remote-endpoint = <&ds90ub960_1_csi_out>;
clock-lanes = <0>;
&ti_csi2rx0 {
status = "okay";
&dphy0 {
status = "okay";
&ti_csi2rx1 {
status = "okay";
&dphy1 {
status = "okay";
camera-support-device-tree
* ISX031 FPD-Link 3 Camera Module
* Copyright (c) 2023 Texas Instruments Incorporated - http://www.ti.com/
/dts-v1/;
/plugin/;
#define SPI_BOOT_DATA_FILE "ISX031_STURDeCAM31_0.1.1.3.bin"
#define MCU_FW_FILE "isx031_cam_fw_boowan_narrow.bin"
#define CAM_LANES 4
#size-cells = <0>;
/* FPDLink RX 0 */
port@0 {
reg = <0>;
ub960_fpd3_1_in: endpoint {
remote-endpoint = <&ub953_1_out>;
#size-cells = <0>;
link@0 {
reg = <0>;
i2c-alias = <0x44>;
ti,rx-mode = <3>;
compatible = "ti,ds90ub953-q1";
gpio-controller;
#gpio-cells = <2>;
#clock-cells = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
ub953_1_in: endpoint {
port@1 {
reg = <1>;
ub953_1_out: endpoint {
remote-endpoint = <&ub960_fpd3_1_in>;
i2c {
#size-cells = <0>;
reg = <0x74>;
gpio-controller;
#gpio-cells = <2>;
thermal_sensor: thermal0@48 {
compatible = "ti,tmp112";
reg = <0x48>;
isx031@42 {
compatible = "aptina,isx031";
reg = <0x42>;
clock-names = "xclk";
deserializer = <0x7>;
led-gpios = <&gpio_exp 5 GPIO_ACTIVE_HIGH>;
temp-gpios = <&gpio_exp 6 GPIO_ACTIVE_HIGH>;
camera-mipi-clk = <300>;
camera_mipi_lanes = <CAM_LANES>;
spi_mcu_fw_name = SPI_BOOT_DATA_FILE;
default_framerate = <30>;
port {
remote-endpoint = <&ub953_1_in>;
link-frequencies = /bits/ 64 <462000000>;
clock-lanes = <0>;
Hi Jeyaprakash,
Thank you for sharing updated dtso files. I see you are using ds90ub960 and ds90ub953 and various configuration settings, however it's still unclear to me how functions are called from the source c files to initialize the devices.
Can you capture an I2C log during initialization so I can review the sequence of register reads/writes that occur?
Lucas
Hello Lucas,
I am attaching I2C transactions during initialisation of ds90ub960 and ds90ub953.
[ 10.381876] ds90ub960 6-0030: UB960 regmap_write : reg=0x01 val=0x02
[ 10.390060] ds90ub960 6-0030: UB960 regmap_write : reg=0x0C val=0x00
[ 10.390397] ds90ub960 6-0030: UB960 regmap_write : reg=0x1F val=0x00
[ 10.392126] ds90ub960 6-0030: UB960 regmap_write : reg=0x32 val=0x01
[ 10.392715] ds90ub960 6-0030: UB960 regmap_write : reg=0x33 val=0x42
[ 10.392830] ds90ub960 6-0030: UB960 regmap_write : reg=0x4C val=0x01
[ 10.392930] ds90ub960 6-0030: UB960 regmap_update : reg=0x58 mask=0x07 val=0x06
[ 10.393166] ds90ub960 6-0030: UB960 regmap_update : reg=0x6D mask=0x03 val=0x00
[ 10.393306] ds90ub960 6-0030: UB960 regmap_update : reg=0x7C mask=0x03 val=0x00
[ 10.393447] ds90ub960 6-0030: UB960 regmap_write : reg=0xD8 val=0x07
[ 10.459005] ds90ub960 6-0030: UB960 regmap_write : reg=0xD9 val=0x7F
[ 10.470257] ds90ub960 6-0030: UB960 regmap_update : reg=0x58 mask=0x40 val=0x40
[ 10.494347] ds90ub960 6-0030: UB960 regmap_write : reg=0x5C val=0x88
[ 10.582385] ds90ub960 6-0030: UB960 regmap_write : reg=0x42 val=0x71
[ 10.600572] ds90ub960 6-0030: UB960 regmap_write : reg=0x41 val=0xA9
[ 10.619520] ds90ub960 6-0030: UB960 regmap_write : reg=0xB0 val=0x04
[ 10.642135] ds90ub960 6-0030: UB960 regmap_write : reg=0xB1 val=0x08
[ 10.671407] ds90ub960 6-0030: UB960 regmap_write : reg=0xB2 val=0x08
[ 10.695782] ds90ub960 6-0030: UB960 regmap_write : reg=0xB1 val=0x09
[ 10.706346] ds90ub960 6-0030: UB960 regmap_write : reg=0xB2 val=0x08
[ 10.713728] ds90ub960 6-0030: UB960 regmap_write : reg=0xD5 val=0xE0
[ 10.777060] ds90ub960 6-0030: UB960 regmap_update : reg=0xD2 mask=0x04 val=0x04
[ 10.805319] ds90ub960 6-0030: UB960 regmap_update : reg=0xD4 mask=0x01 val=0x00
[ 10.850896] ds90ub960 6-0030: UB960 regmap_update : reg=0x0C mask=0x01 val=0x01
[ 10.862010] ds90ub960 6-0030: UB960 regmap_write : reg=0x01 val=0x01
[ 11.157115] ds90ub960 6-0030: UB960 regmap_write : reg=0xB1 val=0x08
[ 11.278683] ds90ub960 6-0030: UB960 regmap_write : reg=0xB1 val=0x09
[ 11.288249] ds90ub960 6-0030: UB960 regmap_write : reg=0x4C val=0x12
[ 11.408107] ds90ub960 6-0030: UB960 regmap_write : reg=0x4C val=0x24
[ 11.461581] ds90ub960 6-0030: UB960 regmap_write : reg=0x4C val=0x38
[ 12.301800] ds90ub953 6-0044: UB953 regmap_write : reg=0x0B val=0x13
[ 12.310013] ds90ub953 6-0044: UB953 regmap_write : reg=0x0C val=0x26
[ 12.333225] ds90ub953 6-0044: UB953 regmap_write : reg=0x02 val=0x72
[ 12.343415] ds90ub953 6-0044: UB953 regmap_write : reg=0x0D val=0x00
[ 12.351150] ds90ub953 6-0044: UB953 regmap_write : reg=0x0E val=0x0F
[ 12.359737] ds90ub953 6-0044: UB953 regmap_write : reg=0x06 val=0x41
[ 12.369257] ds90ub953 6-0044: UB953 regmap_write : reg=0x07 val=0x28
[ 12.384041] ds90ub960 6-0030: UB960 regmap_write : reg=0x4C val=0x01
[ 12.391155] ds90ub960 6-0030: UB960 regmap_write : reg=0x5D val=0x84
[ 12.403604] ds90ub960 6-0030: UB960 regmap_write : reg=0x65 val=0x66
[ 12.458824] ds90ub960 6-0030: UB960 regmap_write : reg=0x5E val=0xE8
[ 12.475322] ds90ub960 6-0030: UB960 regmap_write : reg=0x66 val=0x68
[ 12.595583] ds90ub953 6-0044: UB953 regmap_write : reg=0x06 val=0x43
[ 12.608792] ds90ub953 6-0044: UB953 regmap_write : reg=0x07 val=0x7D
Hi Jeyaprakash,
Thank you for sharing the I2C log. I will review and share feedback in early January.
Lucas
Hi Jeyaprakash,
Thank you for your patience. I have reviewed your I2C log and don't see any clear issue with the initialization sequence. I ran this sequence with 960 and 953 EVMs and the devices consistently lock.
I have a few questions to better understand this issue.
Lucas
