Part Number: DS160PR410
The datasheet says this pin should be pulled high for normal operation when EN_SMB = L3, but if this is an active low reset, shouldn't the signal be pulled low as power comes up so that the IC is in a known state at power up? Is the data sheet assuming a master reset signal drives this input at power-up, then releases it?
Keith
