Part Number: AM62L
Hello Team,
While running OP-TEE validation using xtest, most tests passed successfully, but one regression case failed.
Test summary:
regression_8103 OK
35382 subtests of which 1 failed
111 test cases of which 1 failed
0 test cases were skipped
TEE test application done!
The failing case is:
regression_1041 FAILED first error at
/usr/src/debug/optee-test/4.7.0+git/host/xtest/regression_1000.c:3413
Could you please help me understand the root cause of this failure, and whether this is expected ?
Any guidance on required OP-TEE build flags needed for regression_1041 to pass would be helpful.
Thank you,
J S Ninad
