DS125DF1610: ds125df1610 Layout Guidelines
Part Number: DS125DF1610
Hi TI team
Regarding the layout guidelines for ds125df1610, we only found recommendations stating that the high-speed inputs and outputs should use 100-ohm impedance control, along with the routing guidelines.
Currently, the clock pins are also designed with 100-ohm impedance control. For the non–high-speed input/output pins, we are using 50-ohm impedance-controlled traces.
We would like to ask whether there are any recommended rules for these I/O pins. Below is our current high-speed routing layout. Could you please help to review it and advise if there are any suggested adjustments?
thanks
JL
  • Hi JL,
    I apologize for the delayed response.
    The high speed differential pair looks good.
    There are no particular recommendations for non-high speed data lanes. 50 ohm impedance controlled traces are good.
    J
