Part Number: SN65HVD233-EP
Other Parts Discussed in Thread: SN65HVD233
My name is Ono, and I am responsible for the design of aircraft Electronic Control Units (ECUs) at Honda R&D.
We are currently conducting reliability evaluations for our ECU design and would like to request information regarding the failure rate data for your components. Specifically, we are interested in the following part:
- SN65HVD233MDREP
- SN74LVC1G14MDBVREP
- TMP117NAIDRVR
- ADS8686SIPZAR
-THS4032MDGNREP
-TLV1811QDBVRQ1
-SN74LVC1G08MDCKREP
Could you kindly provide details on the following points:
- Component failure rate (e.g., FIT values, MTBF)
- Conditions under which the failure rate was calculated (temperature, voltage, environmental factors) - Availability of data based on standards such as MIL-HDBK-217 or SN29500
- Any recommendations or considerations for use in aircraft applications
Our application involves
aircraft-mounted ECUs, which require high reliability. If possible, we would greatly appreciate receiving part-specific information and any reliability-related documentation not included in the standard datasheet. Thank you very much for your time and assistance. We look forward to your response. Best regards, Teruhiko Ono
