Part Number: TLK1501
Hi all,
We would like to use TLK1501 in 50 ohm environment. Could you please answer the questions given below?
- RREF is given as 200 ohm in the datasheet. However, 100 ohm resistor is used in the EVM circuitry. (Please see attached.) Which one is correct?
- We will use two TLK1501 ICs on seperate PCBS, one of them will be transmitter and the other one will be receiver. We'll use 50 ohm cables for connection. Which one is the best choice for our application, AC coupled or DC coupled circuitry? What is the difference between them?
- Could you please share min/max values for VOD(p) for AC coupled circuitry? (It is given as DC coupled version in the datasheet page 18.)
