Part Number: SN65HVD1040
I have a question regarding SN65HVD1040DR.
According to the datasheet, the maximum supported CAN bit rate is specified as 1 Mbps.
However, I could not find a clear specification for the minimum supported bit rate.
Could you please confirm whether there is no defined minimum bit rate limitation for this device, meaning it can operate at arbitrarily low CAN bit rates depending on system conditions?
If there are any practical lower limits or design considerations from the transceiver perspective, I would appreciate your guidance.
Thank you very much for your support.
Conor
