Part Number: DP83867IS
Dear TI Support Team,
We would like to request your guidance on configuring the DP83867IS so that the PHY’s transmit and receive activity can be output on its LED pins via firmware (MDIO register settings).
Our intent
- Output TX activity on LED0
- Output RX activity on LED1
Current firmware implementation (for reference)
Questions
- Which registers and bit fields should be configured to map
- LED0 = TX activity, and
- LED1 = RX activity
on the DP83867IS?
- Is our current write to LEDCR1 with the value
0x00006132appropriate for the above mapping?- If not, could you provide the correct register address(es) and the exact bit settings?
- If there are any application notes or a recommended sequence (including any extended pages or indirect registers) for configuring LED functions for activity indication, could you please share them?
Any additional considerations (e.g., strap pin interactions, default LED modes, timing/latency, or mode differences among RGMII/SGMII) would also be appreciated.
Thank you very much for your support.
Yuuichi Asano
