TS3DV642: The LVDS display is blinking
Part Number: TS3DV642
Hello Expert,
Could you help to check the the schematic of TS3DV642 done by my customer?
There is an issue that the network interface goes from down to up state, the network interface initializes, and then links up. LVDS flashes when ip is acquired.
software in uboot first to pull the EN pin low, then control SEL2 switch pin, finally kernel to pull the EN pin high, SEL1 is high by default. (Switch to SWITH-B side)
Wenting
