AM26LV32E: Differential End to single END
Part Number: AM26LV32E
Hi team,
   Can i use the AM26LV32EMDREP following IC for differential end to single end conversion.Signal Type - Analog
Thanks and Regards
Jayakeerthana  P
  • Hi Jayakeerthana,
    Thanks for reaching out on E2E.
    Yes, this receiver takes any valid RS-422 (or RS-485) differential signal and converts it to a "single ended" output, which are the "Y" pins on this transceiver. You can review Table 8-1 for how it translates the differential voltage into a single ended signal to the Y output.
    If you have any other RS-422 or RS-485 general questions, I recommend looking into our FAQ guide which has lots of resources to better understand/improve your RS-4xx system.
     [FAQ] RS-485 / RS-422 Transceiver Resources
    Ethan
