Part Number: TUSB4041I
Is it possible to receive the necessary information to program the OTP memory of TUSB4041I devices through the USB interface?
Thank you,
Timoty
Thank you,
Timoty
Hi Timoty:
We do have tool to program the OTP memory , but it is only for debug, not for production.
Brian
What information you are interested? how to use the tool? or the OTP information?
TUSB4041 was already OTPed during TI production test with default setting.
Best
Brian
Hello Brian,
Specifically if non-volatile data be put into the TUSB4041I outside of TI production.
And if writing non-volatile data is possible outside of TI production
Timoty
basically , OTP is to update hub internal register to configure the hub.
We have a list of register you can change , but other than register, you can not write any other data though OTP.
Since the communication is between USB, so anyone can develop similar tool to read/write OTP.
Best
Brian
Hello Brian,
Going back to my first question then, is it possible to receive the information to program (and read back) the OTP registers?
Timoty
what information you are interested to program OTP register?
this is register for OTP
Brian
Hello Brian,
That information is available in the datasheet, but the vendor-defined USB device requests needed to set or read them is not.
Is is possible to get all the information regarding the vendor-defined USB device requests?
Timoty
Vendor definded information can only done by external EEPROM. like VID/PID/Serial number.
Best
Brian
