Part Number: DS92LV2412
Other Parts Discussed in Thread: DS92LV2411, DS90C124, DS90C241
Hello, the DS92LV241x ser/deser devices are 24 bit payload + 3 control bits for 27 bit total at up to 50Mhz which is 1.35Gbs. I need to shift 24 bits at 50Mhz clock (1.2Gbs) through a 1.25Gbs sfp.
The DS90c devices are 24 bit but only accept a clock up to 35Mhz.
The DS92LV241x datasheet does not go into detail about the compatibility modes. If I run the DS92LV241x devices in compatability mode for the DS90C devices (24 bit, no control bits), does this mean that the DS92LV241x devices ignore the 3 control bits and only send the 24 bit payload?
Can i run a DS92LV2412/DS92LV2411 pair in DS90C compatability mode to form a 24 bit stream at 50Mhz for 1.2Gbs?
Thank you,
Eric
