Part Number: TSB81BA3E
Other Parts Discussed in Thread: TUSB7340
Hello
Please I want a drop-in replacement (cross reference) for this TI part (TSB81BA3IPFP) as it's obsolete now.
Alshaimaa
Hi Alshaimaa:
Let me check if there is replacement .
Best
Brian
Hello Alshaimaa,
Thank you for your query and for providing the detailed documents. The part TSB81BA3IPFP is a Texas Instruments (TI) IEEE 1394a (FireWire) 3-port cable transceiver/arbiter (OHCI-compliant PHY/Link Layer Controller), in an 80-pin TQFP package. It's indeed obsolete (EOL since ~2009–2010), with no new production.
There is no 100% pin-to-pin, drop-in replacement due to the specialized IEEE 1394a protocol and aging technology. FireWire is largely discontinued, so alternatives focus on functional equivalents or migrations to USB/Thunderbolt. Here's a prioritized list:
| Priority | Recommended Replacement | Manufacturer | Key Specs / Compatibility | Pin-Compatible? | Availability (2026) | Price (USD, est.) | Notes |
| 1 | TSB81BA3E or TSB81BA3D | TI | IEEE 1394a 3-port PHY/Link, same function | Yes (drop-in for most apps) | Low (gray market) | $10–20 | TI's revised version, minor bug fixes; if available, best match. |
| 2 | LGS 1394A PHY (e.g., LGS-3P) | LGS/Generic | 3-port FireWire PHY/Link | Partial | Medium (China suppliers) | $5–15 | Low-cost clone, functional equivalent; test for reliability. |
| 3 | Migrate to USB 3.0/Thunderbolt (e.g., TI TUSB7340) | TI | USB 3.0 4-port hub controller | No (redesign needed) | High | $8–12 | Modern upgrade; FireWire is obsolete—switch to USB for future-proofing. |
| 4 | NEC uPD720200 | Renesas | IEEE 1394a 2-port host controller | No | Low | $12–25 | Similar protocol, but fewer ports; requires adapter. |
| 5 | Custom FPGA Solution (e.g., Xilinx Artix-7) | AMD/Xilinx | Programmable IEEE 1394 IP core | No (full redesign) | High | $50+ (dev board) | For long-term; implement FireWire in FPGA if volume justifies. |
Best Option: TSB81BA3E (if you can find stock) — closest to original, minor improvements. Check Rochester Electronics for EOL stock.
