AM62P: [AM62P] Support on wiring up Apple Authentication Chip over i2c
Part Number: AM62P
Hi TI Team,
We are trying to interface Apple Authentication Co-Processor Chip via i2c lines on to the AM62P Sitara EVK. While going through the documentations, we understood that the User Expansion Slot (J4) can be used for the purpose, and found out below pins can be used for our requirement.
Pin No. Net Name
1 VCC3V3_EXP
3 EXP_I2C2_SDA
5 EXP_I2C2_SCL
6 DGND
We had tried wiring the i2c lines and when performed the i2cdetect operation, it is not listing as detected. Is there anything we are missing here?
We have even tried plugging to below pin outs for using i2c-0, that also was behaving the same.
Pin No. Net Name
1 VCC3V3_EXP
27 EXP_I2C0_SDA
28 EXP_I2C0_SCL
6 DGND
Am I wrong with any of the pins which I have selected? Do let us know whether anything special has to be done to make the i2c connection work in this setup.
Thanks in Advance,
Mohammed Shakir
  • Hello Mohammed,
    Please share your Linux devicetree file updates, as well as the Linux boot log, including any commands you are trying to use to test or interact with the I2C peripheral.
    Nick
  • Hi Nick,
    Thanks for your prompt reply.
    We are using the prebuilt 'tisdk-default-image' in our setup. We don't have a TI build setup yet.
    Please find the requested details attached.
    Logs:
    - no i2c connected: am62p_no_i2c_bootup.log
    U-Boot SPL 2025.01-00766-g7493977a537f (Dec 03 2025 - 15:20:36 +0000)
    SYSFW ABI: 4.0 (firmware rev 0x000b '11.2.5--v11.02.05 (Fancy Rat)')
    Set clock rates for '/a53@0', CPU: 1250MHz at Speed Grade 'V'
    SPL initial stack usage: 17104 bytes
    Trying to boot from MMC2
    Authentication passed
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.13.0(release):v2.13.0-259-ge0c4d3903b-dirty
    NOTICE:  BL31: Built : 07:01:36, Jul  1 2025
    DM ABI: 3.0 (firmware ver 0x000b 'MSDK.11.02.00.11--v11.02.05' patch_ver: 5)
    SPL initial stack usage: 1984 bytes
    U-Boot 2025.01-00766-g7493977a537f (Dec 03 2025 - 15:20:36 +0000)
    SoC:   AM62PX SR1.2 HS-FS
    Model: Texas Instruments AM62P5 SK
    DRAM:  2 GiB (total 8 GiB)
    Core:  102 devices, 33 uclasses, devicetree: separate
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1
    Loading Environment from nowhere... OK
    In:    serial
    Out:   serial
    Err:   serial
    Net:   eth0: ethernet@8000000port@1
    Warning: ethernet@8000000port@2 (eth1) using random MAC address - 8a:7e:a9:89:a8:17
    , eth1: ethernet@8000000port@2
    Hit any key to stop autoboot:  2  1  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    575 bytes read in 0 ms
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    22391296 bytes read in 228 ms (93.7 MiB/s)
    66565 bytes read in 2 ms (31.7 MiB/s)
    Working FDT set to 88000000
       Loading Device Tree to 000000008feec000, end 000000008fffffff ... OK
    Working FDT set to 8feec000
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 6.12.57-ti-g31b07ab8dfbc (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.4.0, GNU ld (GNU Binutils) 2.42.0.20240723) #1 SMP PREEMPT Thu Dec  4 13:07:37 UTC 2025
    [    0.000000] KASLR disabled due to lack of seed
    [    0.000000] Machine model: Texas Instruments AM62P5 SK
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: legacy bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created CMA memory pool at 0x00000009dc000000, size 576 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000009dc000000..0x00000009ffffffff (589824 KiB) map reusable linux,cma
    [    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
    [    0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000
    [    0.000000] OF: reserved mem: 0x00000000ff700000..0x00000000ffffffff (9216 KiB) nomap non-reusable framebuffer@ff700000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009b500000, size 3 MiB
    [    0.000000] OF: reserved mem: initialized node rtos-ipc-memory@9b500000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009b500000..0x000000009b7fffff (3072 KiB) nomap non-reusable rtos-ipc-memory@9b500000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009b800000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node mcu-r5fss-dma-memory-region@9b800000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009b800000..0x000000009b8fffff (1024 KiB) nomap non-reusable mcu-r5fss-dma-memory-region@9b800000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009b900000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node mcu-r5fss-memory-region@9b900000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009b900000..0x000000009c7fffff (15360 KiB) nomap non-reusable mcu-r5fss-memory-region@9b900000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c800000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009c800000..0x000000009c8fffff (1024 KiB) nomap non-reusable r5f-dma-memory@9c800000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009c900000, size 30 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@9c900000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009c900000..0x000000009e6fffff (30720 KiB) nomap non-reusable r5f-memory@9c900000
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000009ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000008007ffff]
    [    0.000000]   node   0: [mem 0x0000000080080000-0x000000009b4fffff]
    [    0.000000]   node   0: [mem 0x000000009b500000-0x000000009e6fffff]
    [    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x000000009fffffff]
    [    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000ff6fffff]
    [    0.000000]   node   0: [mem 0x00000000ff700000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000009ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009ffffffff]
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.5
    [    0.000000] percpu: Embedded 22 pages/cpu s51736 r8192 d30184 u90112
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=076c4a2a-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2097152
    [    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
    [    0.000000] software IO TLB: area num 4.
    [    0.000000] software IO TLB: mapped [mem 0x00000000fb700000-0x00000000ff700000] (64MB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU event tracing is enabled.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
    [    0.000000] 	Trampoline variant of Tasks RCU enabled.
    [    0.000000] 	Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
    [    0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000880050000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880060000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008695] Console: colour dummy device 80x25
    [    0.013294] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023966] pid_max: default: 32768 minimum: 301
    [    0.028774] LSM: initializing lsm=capability,selinux
    [    0.033900] SELinux:  Initializing.
    [    0.037932] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.045693] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.056124] rcu: Hierarchical SRCU implementation.
    [    0.061069] rcu: 	Max phase no-delay instances is 1000.
    [    0.066586] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
    [    0.075350] EFI services will not be available.
    [    0.080239] smp: Bringing up secondary CPUs ...
    [    0.085486] Detected VIPT I-cache on CPU1
    [    0.085570] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.085588] GICv3: CPU1: using allocated LPI pending table @0x0000000880070000
    [    0.085635] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.086360] Detected VIPT I-cache on CPU2
    [    0.086423] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
    [    0.086438] GICv3: CPU2: using allocated LPI pending table @0x0000000880080000
    [    0.086472] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.087126] Detected VIPT I-cache on CPU3
    [    0.087189] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
    [    0.087204] GICv3: CPU3: using allocated LPI pending table @0x0000000880090000
    [    0.087232] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.087354] smp: Brought up 1 node, 4 CPUs
    [    0.167006] SMP: Total of 4 processors activated.
    [    0.171814] CPU: All CPU(s) started at EL2
    [    0.176015] CPU features: detected: 32-bit EL0 Support
    [    0.181271] CPU features: detected: CRC32 instructions
    [    0.186564] alternatives: applying system-wide alternatives
    [    0.192847] Memory: 7454932K/8388608K available (13056K kernel code, 1258K rwdata, 4676K rodata, 2752K init, 643K bss, 334804K reserved, 589824K cma-reserved)
    [    0.208430] devtmpfs: initialized
    [    0.222920] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.232923] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.255034] 27120 pages in range for non-PLT usage
    [    0.255058] 518640 pages in range for PLT usage
    [    0.260269] pinctrl core: initialized pinctrl subsystem
    [    0.270861] DMI not present or invalid.
    [    0.276968] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.284253] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
    [    0.291702] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.299818] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.308058] audit: initializing netlink subsys (disabled)
    [    0.313812] audit: type=2000 audit(0.196:1): state=initialized audit_enabled=0 res=1
    [    0.314279] thermal_sys: Registered thermal governor 'step_wise'
    [    0.321738] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.327924] cpuidle: using governor menu
    [    0.338768] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.345793] ASID allocator initialised with 65536 entries
    [    0.357315] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000
    [    0.368819] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    0.381462] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.391381] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    0.404110] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.419320] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    0.432094] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.442823] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    0.457484] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.467430] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.478910] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    0.488153] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.498093] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.505066] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.511474] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.518407] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.524812] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.531743] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.538147] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.545083] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.553164] debugfs: Directory '43000014.chipid' with parent 'regmap' already present!
    [    0.561350] k3-chipinfo 43000014.chipid: Family:AM62PX rev:SR1.2 JTAGID[0x0bb9d02f] Detected
    [    0.571413] iommu: Default domain type: Translated
    [    0.576351] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.583090] SCSI subsystem initialized
    [    0.587308] usbcore: registered new interface driver usbfs
    [    0.592954] usbcore: registered new interface driver hub
    [    0.598409] usbcore: registered new device driver usb
    [    0.604101] pps_core: LinuxPPS API ver. 1 registered
    [    0.609179] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.618519] PTP clock support registered
    [    0.622556] EDAC MC: Ver: 3.0.0
    [    0.626090] scmi_core: SCMI protocol bus registered
    [    0.631379] FPGA manager framework
    [    0.634942] Advanced Linux Sound Architecture Driver Initialized.
    [    0.642194] vgaarb: loaded
    [    0.645348] clocksource: Switched to clocksource arch_sys_counter
    [    0.651867] VFS: Disk quotas dquot_6.6.0
    [    0.655901] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.670210] NET: Registered PF_INET protocol family
    [    0.675519] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.688518] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
    [    0.697379] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.705315] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.713805] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
    [    0.723075] TCP: Hash tables configured (established 65536 bind 65536)
    [    0.729963] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    0.737068] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    0.744733] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.751043] RPC: Registered named UNIX socket transport module.
    [    0.757121] RPC: Registered udp transport module.
    [    0.761927] RPC: Registered tcp transport module.
    [    0.766732] RPC: Registered tcp-with-tls transport module.
    [    0.772342] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.778927] NET: Registered PF_XDP protocol family
    [    0.783838] PCI: CLS 0 bytes, default 64
    [    0.789278] Initialise system trusted keyrings
    [    0.794080] workingset: timestamp_bits=46 max_order=21 bucket_order=0
    [    0.800993] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.807256] NFS: Registering the id_resolver key type
    [    0.812453] Key type id_resolver registered
    [    0.816728] Key type id_legacy registered
    [    0.820841] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.827691] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.889100] Key type asymmetric registered
    [    0.893303] Asymmetric key parser 'x509' registered
    [    0.898371] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.906122] io scheduler mq-deadline registered
    [    0.910758] io scheduler kyber registered
    [    0.914885] io scheduler bfq registered
    [    0.922041] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.928527] pinctrl-single f4000.pinctrl: 172 pins, size 688
    [    0.936230] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.948473] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.966081] loop: module loaded
    [    0.970394] megasas: 07.727.03.00-rc1
    [    0.978313] tun: Universal TUN/TAP device driver, 1.6
    [    0.984543] VFIO - User Level meta-driver version: 0.3
    [    0.991136] usbcore: registered new interface driver usb-storage
    [    0.998023] i2c_dev: i2c /dev entries driver
    [    1.004088] sdhci: Secure Digital Host Controller Interface driver
    [    1.010460] sdhci: Copyright(c) Pierre Ossman
    [    1.015153] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.021659] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    1.029157] usbcore: registered new interface driver usbhid
    [    1.034874] usbhid: USB HID core driver
    [    1.040239] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 (0,8000003f) counters available
    [    1.050524] optee: probing for conduit method.
    [    1.055096] optee: revision 4.7 (a9690ae39995af36)
    [    1.055482] optee: dynamic shared memory is enabled
    [    1.066081] optee: initialized driver
    [    1.066191] random: crng init done
    [    1.071536] Initializing XFRM netlink socket
    [    1.077736] NET: Registered PF_PACKET protocol family
    [    1.082983] Key type dns_resolver registered
    [    1.096119] registered taskstats version 1
    [    1.100602] Loading compiled-in X.509 certificates
    [    1.118202] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.2.5--v11.02.05 (Fancy Rat)')
    [    1.176129] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    1.188922] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.196391] pca953x 1-0023: supply vcc not found, using dummy regulator
    [    1.203293] pca953x 1-0023: using AI
    [    1.223652] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    1.232902] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    1.242833] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    1.252046] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    1.262136] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
    [    1.269028] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
    [    1.274985] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    1.284232] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.293225] ti-sci-inta 4e400000.interrupt-controller: Interrupt Aggregator domain 200 created
    [    1.303316] simple-framebuffer ff700000.framebuffer: framebuffer at 0xff700000, 0x8ca000 bytes
    [    1.312168] simple-framebuffer ff700000.framebuffer: format=a8r8g8b8, mode=1920x1200x32, linelength=7680
    [    1.332831] Console: switching to colour frame buffer device 240x75
    [    1.349302] simple-framebuffer ff700000.framebuffer: fb0: simplefb registered!
    [    1.357059] ti-udma 485c0100.dma-controller: Number of rings: 82
    [    1.365780] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    1.376788] ti-udma 485c0000.dma-controller: Number of rings: 150
    [    1.387725] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    1.397246] ti-udma 4e230000.dma-controller: Number of rings: 6
    [    1.403935] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6)
    [    1.413529] printk: legacy console [ttyS2] disabled
    [    1.418950] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 250, base_baud = 3000000) is a 8250
    [    1.427835] printk: legacy console [ttyS2] enabled
    [    1.437587] printk: legacy bootconsole [ns16550a0] disabled
    [    1.456896] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
    [    1.463893] Creating 7 MTD partitions on "fc40000.spi.0":
    [    1.469292] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.476062] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.482533] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.489066] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    1.495381] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [    1.502261] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.508763] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.515754] cadence-qspi fc40000.spi: Pattern not found. Skipping calibration.
    [    1.523738] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006
    [    1.573361] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000
    [    1.587823] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    1.595925] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
    [    1.604143] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    1.611275] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512, Policers 32
    [    1.619044] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:500000000, add_val:1 pps:0
    [    1.639212] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    1.650237] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    1.662735] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    1.679744] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    1.685303] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    1.693075] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
    [    1.699081] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000808020000010
    [    1.708517] xhci-hcd xhci-hcd.0.auto: irq 264, io mem 0x31100000
    [    1.715346] hub 1-0:1.0: USB hub found
    [    1.719149] hub 1-0:1.0: 1 port detected
    [    1.726206] mmc0: CQHCI version 5.10
    [    1.731881] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    1.738662] pca953x 1-0022: using AI
    [    1.747053] clk: Disabling unused clocks
    [    1.755927] PM: genpd: Disabling unused power domains
    [    1.761161] ALSA device list:
    [    1.761327] mmc1: CQHCI version 5.10
    [    1.764211]   No soundcards found.
    [    1.769191] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.805370] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    1.813329] Waiting for root device PARTUUID=076c4a2a-02...
    [    1.863370] mmc1: new ultra high speed SDR104 SDXC card at address 59b4
    [    1.870623] mmcblk1: mmc1:59b4 EC1S5 59.7 GiB
    [    1.877583]  mmcblk1: p1 p2
    [    1.881556] mmc0: Command Queue Engine enabled
    [    1.886025] mmc0: new HS400 MMC card at address 0001
    [    1.892097] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    1.898319]  mmcblk0: p1 p2
    [    1.901692] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
    [    1.907551] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
    [    1.913621] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
    [    2.195767] EXT4-fs (mmcblk1p2): recovery complete
    [    2.235381] EXT4-fs (mmcblk1p2): mounted filesystem 1b403827-cacd-4230-a707-d8e467ff6764 r/w with ordered data mode. Quota mode: none.
    [    2.247551] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    2.254444] devtmpfs: mounted
    [    2.258154] Freeing unused kernel memory: 2752K
    [    2.262776] Run /sbin/init as init process
    [    2.432445] systemd[1]: System time before build time, advancing clock.
    [    2.477920] NET: Registered PF_INET6 protocol family
    [    2.483915] Segment Routing with IPv6
    [    2.487668] In-situ OAM (IOAM) with IPv6
    [    2.519725] systemd[1]: systemd 255.21^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    2.551650] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2025.01!
    [    2.571486] systemd[1]: Hostname set to <am62pxx-evm>.
    [    2.787479] systemd[1]: Configuration file /usr/lib/systemd/system/ti-apps-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    2.834088] systemd[1]: Configuration file /usr/lib/systemd/system/seva-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    3.051120] systemd[1]: Queued start job for default target Graphical Interface.
    [    3.107109] systemd[1]: Created slice Slice /system/getty.
    [  OK  ] Created slice Slice /system/getty.
    [    3.127856] systemd[1]: Created slice Slice /system/modprobe.
    [  OK  ] Created slice Slice /system/modprobe.
    [    3.147768] systemd[1]: Created slice Slice /system/serial-getty.
    [  OK  ] Created slice Slice /system/serial-getty.
    [    3.167190] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    3.185814] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
    [    3.205709] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password Requests to Wall Directory Watch.
    [    3.225559] systemd[1]: Expecting device /dev/ttyS2...
    [    3.237640] systemd[1]: Reached target Path Units.
    [  OK  ] Reached target Path Units.
    [    3.249485] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    3.265486] systemd[1]: Reached target Slice Units.
    [  OK  ] Reached target Slice Units.
    [    3.277496] systemd[1]: Reached target Swaps.
    [  OK  ] Reached target Swaps.
    [    3.342794] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    3.361692] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    3.384311] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    3.401959] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    3.422678] systemd[1]: Listening on Journal Audit Socket.
    [  OK  ] Listening on Journal Audit Socket.
    [    3.442203] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    3.462228] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    3.474371] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    3.494927] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    3.514063] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    3.530148] systemd[1]: Listening on User Database Manager Socket.
    [  OK  ] Listening on User Database Manager Socket.
    [    3.585727] systemd[1]: Mounting Huge Pages File System...
    [    3.601670] systemd[1]: Mounting POSIX Message Queue File System...
    [    3.625932] systemd[1]: Mounting Kernel Debug File System...
    [    3.638095] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
    [    3.656191] systemd[1]: Mounting Temporary Directory /tmp...
    [    3.675264] systemd[1]: Starting Create List of Static Device Nodes...
    [    3.698197] systemd[1]: Starting Load Kernel Module configfs...
    [    3.722342] systemd[1]: Starting Load Kernel Module drm...
    [    3.738443] systemd[1]: Starting Load Kernel Module fuse...
    [    3.762760] systemd[1]: Starting Start psplash boot splash screen...
    [    3.775780] fuse: init (API version 7.41)
    [    3.787256] systemd[1]: Starting RPC Bind...
    [    3.798061] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
    [    3.830030] systemd[1]: Starting Journal Service...
    [    3.850450] systemd[1]: Starting Load Kernel Modules...
    [    3.871124] systemd[1]: Starting Generate network units from Kernel command line...
    [    3.896967] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    3.898252] cryptodev: loading out-of-tree module taints kernel.
             Starting Remount Root and Kernel File Systems   3.911179] systemd-journald[128]: Collecting audit messages is enabled.
    [0m...
    [    3.911486] sysctl table check failed: ioctl/(null) procname is null
    [    3.929472] sysctl table check failed: ioctl/(null) No proc_handler
    [    3.929489] cryptodev: driver 1.14 loaded.
    [    3.945868] systemd[1]: Starting Coldplug All udev Devices...
    [    3.978304] systemd[1]: Started Start psplash boot splash screen.
    [  OK  ] Started Start psplash boot splash screen.
    [    3.999786] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.[    4.005888] EXT4-fs (mmcblk1p2): re-mounted 1b403827-cacd-4230-a707-d8e467ff6764.
    [    4.023803] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory /tmp.
    [  OK  ] Finished Create List of Static Device Nodes.
    [  OK  ] Finished Load Kernel Module configfs.
    [  OK  ] Finished Load Kernel Module drm.
    [  OK  ] Finished Load Kernel Module fuse.
    [  OK  ] Finished Load Kernel Modules.
    [  OK  ] Finished Generate network units from Kernel command line.
    [  OK  ] Finished Remount Root and Kernel File Systems.
             Mounting FUSE Control File System...
             Mounting Kernel Configuration File System...
    [  OK  ] Started Start psplash-systemd progress communication helper.
             Starting Flush Journal to Persistent Storage...
             Starting Apply Kernel Variables...
             Starting Create Static Device Nodes in /dev gracefully...
    [    4.348952] systemd-journald[128]: Received client request to flush runtime journal.
    [  OK  ] Mounted FUSE Control File System.
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Finished Flush Journal to Persistent Storage.
    [  OK  ] Finished Apply Kernel Variables.
    [  OK  ] Finished Create Static Device Nodes in /dev gracefully.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Finished Create Static Device Nodes in /dev.
    [  OK  ] Reached target Preparation for Local File Systems.
             Mounting /var/volatile...
    [    4.588164] audit: type=1334 audit(1748544504.152:2): prog-id=6 op=LOAD
    [    4.594921] audit: type=1334 audit(1748544504.160:3): prog-id=7 op=LOAD
             Starting Rule-based Manager for Device Events and Files...
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save OS Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create System Files and Directories...
    [  OK  ] Finished Coldplug All udev Devices.
             Starting Wait for udev To Complete Device Initialization...
    [  OK  ] Finished Load/Save OS Random Seed.
    [  OK  ] Finished Create System Files and Directories.
    [    4.820902] audit: type=1334 audit(1748544504.384:4): prog-id=8 op=LOAD
             Starting Network Name Resolution...
    [    4.857439] audit: type=1334 audit(1748544504.420:5): prog-id=9 op=LOAD
             Starting Network Time Synchronization...
             Starting Record System Boot/Shutdown in UTMP...
    [    4.901244] audit: type=1334 audit(1748544504.464:6): prog-id=10 op=LOAD
    [    4.908096] audit: type=1334 audit(1748544504.472:7): prog-id=11 op=LOAD
    [    4.914921] audit: type=1334 audit(1748544504.480:8): prog-id=12 op=LOAD
             Starting User Database Manager...
    [  OK  ] Finished Record System Boot/Shutdown in UTMP.
    [  OK  ] Started User Database Manager.
    [  OK  ] Started Rule-based Manager for Device Events and Files.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Host and Network Name Lookups.
    [  OK  ] Found device /dev/ttyS2.
    [    6.170329] tlv320aic3x 1-001b: supply IOVDD not found, using dummy regulator
    [    6.179566] snd_soc_davinci_mcasp: unknown parameter 'index' ignored
    [    6.202752] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
    [    6.217845] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
    [    6.223010] tlv320aic3x 1-001b: supply DVDD not found, using dummy regulator
    [    6.250758] tlv320aic3x 1-001b: supply AVDD not found, using dummy regulator
    [    6.264736] mc: Linux media interface: v0.10
    [    6.265194] tlv320aic3x 1-001b: supply DRVDD not found, using dummy regulator
    [    6.298394] tlv320aic3x 1-001b: Invalid supply voltage(s) AVDD: -22, DVDD: -22
    [    6.312670] videodev: Linux video capture interface: v2.00
    [    6.484784] platform 79000000.r5f: configured R5F for remoteproc mode
    [    6.498075] platform 79000000.r5f: assigned reserved memory node mcu-r5fss-dma-memory-region@9b800000
    [  OK  ] Reached target Hardware activated USB gadget.
    [    6.529269] remoteproc remoteproc0: 79000000.r5f is available
    [    6.550685] remoteproc remoteproc0: powering up 79000000.r5f
    [    6.557298] remoteproc remoteproc0: Booting fw image am62p-mcu-r5f0_0-fw, size 59336
    [    6.566413] sii902x 1-003b: supply iovcc not found, using dummy regulator
    [    6.578365] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
    [    6.578547] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
    [    6.590854] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node mcu-r5fss-dma-memory-region@9b800000
    [    6.602087] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    6.614919] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    6.620595] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0xd
    [    6.621025] platform 78000000.r5f: configured R5F for IPC-only mode
    [    6.629513] PVR_K:  192: Read BVNC 36.53.104.796 from HW device registers
    [    6.634835] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9c800000
    [    6.650923] remoteproc remoteproc1: 78000000.r5f is available
    [    6.650975] PVR_K:  192: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
    [    6.653241] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    6.653484] rproc-virtio rproc-virtio.2.auto: registered virtio0 (type 7)
    [    6.653495] remoteproc remoteproc0: remote processor 79000000.r5f is now up
    [    6.656836] remoteproc remoteproc1: attaching to 78000000.r5f
    [    6.692115] i2c i2c-1: Added multiplexed i2c bus 3
    [    6.692364] [drm] Initialized pvr 25.2.6850647 for fd80000.gpu on minor 0
    [    6.692679] rproc-virtio rproc-virtio.4.auto: assigned reserved memory node r5f-dma-memory@9c800000
    [    6.693140] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    6.693167] rproc-virtio rproc-virtio.4.auto: registered virtio1 (type 7)
    [    6.693174] remoteproc remoteproc1: remote processor 78000000.r5f is now attached
    [    6.693801] virtio_rpmsg_bus virtio1: creating channel rpmsg-client-sample addr 0xd
    [    6.693968] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    6.789056] [drm] Initialized tidss 1.0.0 for 30200000.dss on minor 1
    [    6.796702] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [    6.803916] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [  OK  ] Created slice Slice /system/tee-supplicant.
    [    6.859895] vdec 30210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
    [    6.867979] vdec 30210000.video-codec: Product Code:      0x521c
    [    6.876067] vdec 30210000.video-codec: Firmware Revision: 363254
             Starting Virtual Console Setup...
    [  OK  ] Finished Virtual Console Setup.
    [  OK  ] Created slice Slice /system/systemd-fsck.
             Expecting device /dev/mmcblk0p1...
             Expecting device /dev/mmcblk1p1...
    [  OK  ] Found device /dev/mmcblk0p1.
             Starting File System Check on /dev/mmcblk0p1...
    [  OK  ] Finished Wait for udev To Complete Device Initialization.
    [  OK  ] Found device /dev/mmcblk1p1.
    [  OK  ] Finished File System Check on /dev/mmcblk0p1.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timer Units.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API...
    [  OK  ] Listening on dropbear.socket.
    [  OK  ] Listening on PC/SC Smart Card Daemon Activation Socket.
             Mounting /run/media/mmcblk0p1...
    [    7.585810] audit: type=1334 audit(1748937112.378:9): prog-id=13 op=LOAD
             Starting D-Bus System Message Bus...
             Starting Reboot and dump vmcore via kexec...
             Starting File System Check on /dev/mmcblk1p1...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Mounted /run/media/mmcblk0p1.
    [  OK  ] Finished Reboot and dump vmcore via kexec.
    [  OK  ] Started D-Bus System Message Bus.
    [  OK  ] Reached target Socket Units.
    [  OK  ] Reached target Basic System.
             Starting Save/Restore Sound Card State...
    [  OK  ] Started Job spooling tools.
             Starting Avahi mDNS/DNS-SD Stack...
    [  OK  ] Started Periodic Command Scheduler.
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
    [  OK  ] Started Multiple Spanning Tree Protocol Daemon.
             Starting Telephony service...
             Starting Expand the rootfs partiti�to full size of the boot device....
    [  OK  ] Started Seva Launcher Service.
    [  OK  ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
    [    7.885546] audit: type=1334 audit(1748937112.674:10): prog-id=14 op=LOAD
    [    7.892928] audit: type=1334 audit(1748937112.674:11): prog-id=15 op=LOAD
    [    7.892955] audit: type=1334 audit(1748937112.674:12): prog-id=16 op=LOAD
             Starting User Login Management...
    [  OK  ] Started TEE Supplicant on teepriv0.
             Starting Telnet Server...
             Starting Touch Input Service (touch_sender)...
    [  OK  ] Finished File System Check on /dev/mmcblk1p1.
    [  OK  ] Finished Save/Restore Sound Card State.
    [  OK  ] Finished IPv6 Packet Filtering Framework.
    [  OK  ] Finished IPv4 Packet Filtering Framework.
    [  OK  ] Finished Telnet Server.
    [    8.055849] Bluetooth: Core ver 2.22
    [    8.059786] NET: Registered PF_BLUETOOTH protocol family
    [    8.065931] Bluetooth: HCI device and connection manager initialized
    [    8.072718] Bluetooth: HCI socket layer initialized
    [    8.077941] Bluetooth: L2CAP socket layer initialized
    [    8.077993] Bluetooth: SCO socket layer initialized
    [  OK  ] Reached target Preparation for Network.
    [  OK  ] Reached target Sound Card.
    [  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
             Mounting /run/media/boot-mmcblk1p1...
             Starting PulseAudio Sound System...
    [    8.134887] audit: type=1334 audit(1748937112.926:13): prog-id=17 op=LOAD
             Starting Network Configuration...
    [  OK  ] Started Telephony service.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Finished Expand the rootfs partition to full size of the boot device..
    [  OK  ] Started User Login Management.
    [  OK  ] Created slice User Slice of UID 1000.
             Starting User Runtime Directory /run/user/1000...
    [  OK  ] Finished User Runtime Directory /run/user/1000.
    [    8.476886] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    8.506159] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [  OK  ] Mounted /run/media/boot-mmcblk1p1    8.513437] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    0m.
    [  OK  ] Started Network Configuration.[    8.668296] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    8.678471] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [  OK  ] Reached target Network.
             Starting containerd container runtime...
    [    8.708506] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL)
    [    8.717946] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
             Starting LLDP daemon...
    [  OK  ] Started Netperf Benchmark Server.
             Starting Simple Network Management Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Finished Permit User Sessions.
    [  OK  ] Started emptty display manager.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
             Starting ti-apps-launcher service...
             Starting User Manager for UID 1000...
    [  OK  ] Started LLDP daemon.
    [    9.225618] audit: type=1006 audit(1748937114.018:14): pid=674 uid=0 subj=kernel old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
    [    9.239484] audit: type=1300 audit(1748937114.018:14): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffe3d25758 a2=4 a3=1 items=0 ppid=1 pid=674 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" subj=kernel key=(null)
    [    9.267342] audit: type=1327 audit(1748937114.018:14): proctitle="(systemd)"
    [  OK  ] Started PulseAudio Sound System.
    [  OK  ] Started Simple Network Management Protocol (SNMP) Daemon..
    [  OK  ] Started User Manager for UID 1000.
    [  OK  ] Started containerd container runtime.
    NOTICE: This file system contains the following GPL-3.0 packages:
    	adwaita-icon-theme-symbolic
    	autoconf
    	bash-dev
    	bash
    	bc
    	binutils
    	cifs-utils
    	coreutils-stdbuf
    	coreutils
    	cpio
    	cpp-symlinks
    	cpp
    	dosfstools
    	elfutils-dev
    	elfutils
    	findutils
    	g++-symlinks
    	g++
    	gawk
    	gcc-symlinks
    	gcc
    	gdb
    	gdbserver
    	gettext
    	glmark2
    	gnu-config
    	grub-common
    	grub-editenv
    	grub-efi
    	gzip
    	hidapi
    	kbd-dev
    	kbd-keymaps-pine
    	less
    	libasm1
    	libatomic-dev
    	libatomic1
    	libbfd
    	libdebuginfod1
    	libdw1
    	libelf1
    	libgcc-s-dev
    	libgcc1
    	libgdbm-compat4
    	libgdbm-dev
    	libgdbm6
    	libgettextlib
    	libgettextsrc
    	libgmp-dev
    	libgmp10
    	libgmpxx4
    	libgnutls-dev
    	libgnutls-openssl27
    	libgomp1
    	libidn2-0
    	libidn2-dev
    	libmpc3
    	libmpfr6
    	libopcodes
    	libqt6core5compat-plugins
    	libqt6core5compat-qmlplugins
    	libqt6core5compat6
    	libqt6shadertools-dev
    	libqt6shadertools-plugins
    	libqt6shadertools-qmlplugins
    	libqt6shadertools6
    	libreadline-dev
    	libreadline8
    	libstdc++-dev
    	libstdc++6
    	libtasn1-dev
    	libunistring-dev
    	libunistring5
    	m4
    	make
    	nettle-dev
    	nettle
    	parted
    	piglit
    	qt3d-plugins
    	qt3d-qmlplugins
    	qt3d
    	qtbase-dev
    	qtbase-examples
    	qtbase-plugins
    	qtbase-qmlplugins
    	qtbase-staticdev
    	qtbase
    	qtdeclarative-dev
    	qtdeclarative-plugins
    	qtdeclarative-qmlplugins
    	qtdeclarative-staticdev
    	qtdeclarative-tools
    	qtdeclarative
    	qtlanguageserver-dev
    	qtlanguageserver-plugins
    	qtlanguageserver-qmlplugins
    	qtlanguageserver-staticdev
    	qtlanguageserver
    	qtmultimedia-plugins
    	qtmultimedia-qmlplugins
    	qtmultimedia
    	qtquick3d-plugins
    	qtquick3d-qmlplugins
    	qtquick3d
    	qtquicktimeline-plugins
    	qtquicktimeline-qmlplugins
    	qtquicktimeline
    	qtsvg-dev
    	qtsvg-plugins
    	qtsvg-qmlplugins
    	qtsvg
    	qttools-plugins
    	qttools-qmlplugins
    	qttools
    	qtwayland-dev
    	qtwayland-plugins
    	qtwayland-qmlplugins
    	qtwayland
    	tar
    	which
    If you do not wish to distribute GPL-3.0 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Finished Print notice about GPLv3 packages.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project am62pxx-evm ttyS2
    Arago 2025.01 am62pxx-evm ttyS2
    am62pxx-evm login: [   15.298067] PVR_K:  1113: RGX Firmware image 'rgx.fw.36.53.104.796' loaded
    [   15.310774] PVR_K:  1113: Shader binary image 'rgx.sh.36.53.104.796' loaded
    [   15.319642] PVR_K:  1113: SLCSize:   262144
    am62pxx-evm login:
    am62pxx-evm login: root
    [   20.096721] audit: type=1006 audit(1748937124.886:15): pid=1150 uid=0 subj=kernel old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=2 res=1
    [   20.110329] audit: type=1300 audit(1748937124.886:15): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffcab7bc68 a2=1 a3=1 items=0 ppid=1 pid=1150 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" subj=kernel key=(null)
    [   20.137983] audit: type=1327 audit(1748937124.886:15): proctitle="(systemd)"
    [   20.166054] audit: type=1334 audit(1748937124.958:16): prog-id=18 op=LOAD
    [   20.172889] audit: type=1300 audit(1748937124.958:16): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffc7d3a708 a2=90 a3=0 items=0 ppid=1 pid=1150 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" subj=kernel key=(null)
    [   20.199768] audit: type=1327 audit(1748937124.958:16): proctitle="(systemd)"
    [   20.206862] audit: type=1334 audit(1748937124.958:17): prog-id=18 op=UNLOAD
    [   20.213902] audit: type=1300 audit(1748937124.958:17): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffffb93af3c0 items=0 ppid=1 pid=1150 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" subj=kernel key=(null)
    [   20.240596] audit: type=1327 audit(1748937124.958:17): proctitle="(systemd)"
    [   20.247707] audit: type=1334 audit(1748937124.958:18): prog-id=19 op=LOAD
    root@am62pxx-evm:~#
    root@am62pxx-evm:~#
    root@am62pxx-evm:~#
    root@am62pxx-evm:~# i2cdetect-0   -a 0
    Warning: Can't use SMBus Quick Write command, will skip some addresses
    WARNING! This program can confuse your I2C bus, cause data loss and worse!
    I will probe file /dev/i2c-0.
    I will probe address range 0x00-0x7f.
    Continue? [Y/n] y
         0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
    00:
    10:
    20:
    30: -- -- -- -- -- -- -- --
    40:
    50: -- 51 -- -- -- -- -- -- -- -- -- -- -- -- -- --
    60:
    70:
    root@am62pxx-evm:~# i2cdetect -a 0 1
    I will probe file /dev/i2c-1.
    Continue? [Y/n] y
    00:
    10:
    20:
    40:
    50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    60:
    70:
    root@am62pxx-evm:~# i2cdetect -a 1 2
    I will probe file /dev/i2c-2.
    Continue? [Y/n] y
    00:
    10:
    20:
    40:
    60:
    70:
    root@am62pxx-evm:~# ls  i2d cdetect
    Error: No i2c-bus specified!
    Usage: i2cdetect [-y] [-a] [-q|-r] I2CBUS [FIRST LAST]
           i2cdetect -F I2CBUS
           i2cdetect -l
      I2CBUS is an integer or an I2C bus name
      If provided, FIRST and LAST limit the probing range.
    root@am62pxx-evm:~# i2cdetect --            ls -al /dev/i2c-*
    crw------- 1 root root 89, 0 Jun  3 07:51 /dev/i2c-0
    crw------- 1 root root 89, 1 Jun  3 07:51 /dev/i2c-1
    crw------- 1 root root 89, 2 Jun  3 07:51 /dev/i2c-2
    crw------- 1 root root 89, 3 Jun  3 07:51 /dev/i2c-3
    root@am62pxx-evm:~# sync
    - chip connected over i2c-2: am62p_i2c2_boot.log
    In:    serial
    Out:   serial
    Err:   serial
    Warning: ethernet@8000000port@2 (eth1) using random MAC address - b2:4d:31:7a:d8:eb
    575 bytes read in 1 ms (561.5 KiB/s)
    22391296 bytes read in 226 ms (94.5 MiB/s)
    66565 bytes read in 3 ms (21.2 MiB/s)
    Starting kernel ...
    [    0.008693] Console: colour dummy device 80x25
    [    0.013291] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023963] pid_max: default: 32768 minimum: 301
    [    0.028771] LSM: initializing lsm=capability,selinux
    [    0.033895] SELinux:  Initializing.
    [    0.037922] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.045684] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.056109] rcu: Hierarchical SRCU implementation.
    [    0.061059] rcu: 	Max phase no-delay instances is 1000.
    [    0.066584] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
    [    0.075336] EFI services will not be available.
    [    0.080223] smp: Bringing up secondary CPUs ...
    [    0.085454] Detected VIPT I-cache on CPU1
    [    0.085535] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.085553] GICv3: CPU1: using allocated LPI pending table @0x0000000880070000
    [    0.085601] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.086325] Detected VIPT I-cache on CPU2
    [    0.086387] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
    [    0.086403] GICv3: CPU2: using allocated LPI pending table @0x0000000880080000
    [    0.086434] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.087086] Detected VIPT I-cache on CPU3
    [    0.087147] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
    [    0.087162] GICv3: CPU3: using allocated LPI pending table @0x0000000880090000
    [    0.087192] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.087316] smp: Brought up 1 node, 4 CPUs
    [    0.166957] SMP: Total of 4 processors activated.
    [    0.171763] CPU: All CPU(s) started at EL2
    [    0.175965] CPU features: detected: 32-bit EL0 Support
    [    0.181219] CPU features: detected: CRC32 instructions
    [    0.186512] alternatives: applying system-wide alternatives
    [    0.192789] Memory: 7454932K/8388608K available (13056K kernel code, 1258K rwdata, 4676K rodata, 2752K init, 643K bss, 334804K reserved, 589824K cma-reserved)
    [    0.208367] devtmpfs: initialized
    [    0.222830] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.232832] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.254936] 27120 pages in range for non-PLT usage
    [    0.254963] 518640 pages in range for PLT usage
    [    0.260169] pinctrl core: initialized pinctrl subsystem
    [    0.270757] DMI not present or invalid.
    [    0.276873] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.284149] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
    [    0.291600] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.299717] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.307961] audit: initializing netlink subsys (disabled)
    [    0.313719] audit: type=2000 audit(0.196:1): state=initialized audit_enabled=0 res=1
    [    0.314188] thermal_sys: Registered thermal governor 'step_wise'
    [    0.321646] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.327830] cpuidle: using governor menu
    [    0.338674] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.345704] ASID allocator initialised with 65536 entries
    [    0.357236] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000
    [    0.368745] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    0.381388] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.391306] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    0.404034] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.419235] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    0.432009] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.442729] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    0.457399] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.467344] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.478821] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    0.488062] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.498022] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.504985] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.511395] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.518334] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.524738] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.531671] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.538074] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.545010] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.553071] debugfs: Directory '43000014.chipid' with parent 'regmap' already present!
    [    0.561249] k3-chipinfo 43000014.chipid: Family:AM62PX rev:SR1.2 JTAGID[0x0bb9d02f] Detected
    [    0.570548] iommu: Default domain type: Translated
    [    0.575468] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.582319] SCSI subsystem initialized
    [    0.586554] usbcore: registered new interface driver usbfs
    [    0.592196] usbcore: registered new interface driver hub
    [    0.597648] usbcore: registered new device driver usb
    [    0.603342] pps_core: LinuxPPS API ver. 1 registered
    [    0.608419] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.617758] PTP clock support registered
    [    0.621795] EDAC MC: Ver: 3.0.0
    [    0.625330] scmi_core: SCMI protocol bus registered
    [    0.630619] FPGA manager framework
    [    0.634174] Advanced Linux Sound Architecture Driver Initialized.
    [    0.641404] vgaarb: loaded
    [    0.644545] clocksource: Switched to clocksource arch_sys_counter
    [    0.651060] VFS: Disk quotas dquot_6.6.0
    [    0.655097] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.669365] NET: Registered PF_INET protocol family
    [    0.674659] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.687652] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
    [    0.696500] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.704440] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.712939] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
    [    0.722230] TCP: Hash tables configured (established 65536 bind 65536)
    [    0.729117] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    0.736214] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    0.743891] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.750185] RPC: Registered named UNIX socket transport module.
    [    0.756262] RPC: Registered udp transport module.
    [    0.761069] RPC: Registered tcp transport module.
    [    0.765875] RPC: Registered tcp-with-tls transport module.
    [    0.771478] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.778063] NET: Registered PF_XDP protocol family
    [    0.782974] PCI: CLS 0 bytes, default 64
    [    0.788404] Initialise system trusted keyrings
    [    0.793198] workingset: timestamp_bits=46 max_order=21 bucket_order=0
    [    0.800119] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.806361] NFS: Registering the id_resolver key type
    [    0.811567] Key type id_resolver registered
    [    0.815843] Key type id_legacy registered
    [    0.819955] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.826806] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.888129] Key type asymmetric registered
    [    0.892331] Asymmetric key parser 'x509' registered
    [    0.897395] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.905134] io scheduler mq-deadline registered
    [    0.909772] io scheduler kyber registered
    [    0.913901] io scheduler bfq registered
    [    0.921057] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.927579] pinctrl-single f4000.pinctrl: 172 pins, size 688
    [    0.935267] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.947550] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.965038] loop: module loaded
    [    0.969348] megasas: 07.727.03.00-rc1
    [    0.977281] tun: Universal TUN/TAP device driver, 1.6
    [    0.983521] VFIO - User Level meta-driver version: 0.3
    [    0.990170] usbcore: registered new interface driver usb-storage
    [    0.996944] i2c_dev: i2c /dev entries driver
    [    1.002965] sdhci: Secure Digital Host Controller Interface driver
    [    1.009304] sdhci: Copyright(c) Pierre Ossman
    [    1.013994] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.020491] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    1.028002] usbcore: registered new interface driver usbhid
    [    1.033719] usbhid: USB HID core driver
    [    1.039062] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 (0,8000003f) counters available
    [    1.049360] optee: probing for conduit method.
    [    1.053931] optee: revision 4.7 (a9690ae39995af36)
    [    1.054312] optee: dynamic shared memory is enabled
    [    1.064926] optee: initialized driver
    [    1.065038] random: crng init done
    [    1.070369] Initializing XFRM netlink socket
    [    1.076595] NET: Registered PF_PACKET protocol family
    [    1.081845] Key type dns_resolver registered
    [    1.095108] registered taskstats version 1
    [    1.099581] Loading compiled-in X.509 certificates
    [    1.116823] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.2.5--v11.02.05 (Fancy Rat)')
    [    1.174314] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    1.187107] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.194627] pca953x 1-0023: supply vcc not found, using dummy regulator
    [    1.201553] pca953x 1-0023: using AI
    [    1.222810] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    1.232063] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    1.241993] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    1.251209] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    1.261295] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
    [    1.268208] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
    [    1.274168] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    1.283412] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.292417] ti-sci-inta 4e400000.interrupt-controller: Interrupt Aggregator domain 200 created
    [    1.302538] simple-framebuffer ff700000.framebuffer: framebuffer at 0xff700000, 0x8ca000 bytes
    [    1.311392] simple-framebuffer ff700000.framebuffer: format=a8r8g8b8, mode=1920x1200x32, linelength=7680
    [    1.332055] Console: switching to colour frame buffer device 240x75
    [    1.348541] simple-framebuffer ff700000.framebuffer: fb0: simplefb registered!
    [    1.356288] ti-udma 485c0100.dma-controller: Number of rings: 82
    [    1.364982] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    1.375998] ti-udma 485c0000.dma-controller: Number of rings: 150
    [    1.386931] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    1.396447] ti-udma 4e230000.dma-controller: Number of rings: 6
    [    1.403108] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6)
    [    1.412718] printk: legacy console [ttyS2] disabled
    [    1.418069] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 250, base_baud = 3000000) is a 8250
    [    1.427026] printk: legacy console [ttyS2] enabled
    [    1.436717] printk: legacy bootconsole [ns16550a0] disabled
    [    1.452080] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
    [    1.459083] Creating 7 MTD partitions on "fc40000.spi.0":
    [    1.464483] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.471218] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.477650] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.484177] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    1.490515] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [    1.497384] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.503856] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.510855] cadence-qspi fc40000.spi: Pattern not found. Skipping calibration.
    [    1.518826] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006
    [    1.568551] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000
    [    1.583037] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    1.591140] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
    [    1.599364] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    1.606496] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512, Policers 32
    [    1.614238] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:500000000, add_val:1 pps:0
    [    1.634561] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    1.645456] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    1.657966] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    1.675084] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    1.680631] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    1.688399] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
    [    1.694403] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000808020000010
    [    1.703837] xhci-hcd xhci-hcd.0.auto: irq 264, io mem 0x31100000
    [    1.710623] hub 1-0:1.0: USB hub found
    [    1.714406] hub 1-0:1.0: 1 port detected
    [    1.721428] mmc0: CQHCI version 5.10
    [    1.727098] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    1.733900] pca953x 1-0022: using AI
    [    1.742146] clk: Disabling unused clocks
    [    1.744561] mmc1: CQHCI version 5.10
    [    1.750756] PM: genpd: Disabling unused power domains
    [    1.755922] ALSA device list:
    [    1.758960]   No soundcards found.
    [    1.760585] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.785113] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    1.792925] Waiting for root device PARTUUID=076c4a2a-02...
    [    1.842627] mmc1: new ultra high speed SDR104 SDXC card at address 59b4
    [    1.849857] mmcblk1: mmc1:59b4 EC1S5 59.7 GiB
    [    1.856316]  mmcblk1: p1 p2
    [    1.869593] mmc0: Command Queue Engine enabled
    [    1.874085] mmc0: new HS400 MMC card at address 0001
    [    1.880559] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    1.886292]  mmcblk0: p1 p2
    [    1.889675] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
    [    1.895655] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
    [    1.901479] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
    [    2.045525] EXT4-fs (mmcblk1p2): recovery complete
    [    2.053161] EXT4-fs (mmcblk1p2): mounted filesystem 1b403827-cacd-4230-a707-d8e467ff6764 r/w with ordered data mode. Quota mode: none.
    [    2.065356] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    2.072255] devtmpfs: mounted
    [    2.075971] Freeing unused kernel memory: 2752K
    [    2.080625] Run /sbin/init as init process
    [    2.262474] systemd[1]: System time before build time, advancing clock.
    [    2.308164] NET: Registered PF_INET6 protocol family
    [    2.314213] Segment Routing with IPv6
    [    2.317937] In-situ OAM (IOAM) with IPv6
    [    2.349325] systemd[1]: systemd 255.21^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    2.381213] systemd[1]: Detected architecture arm64.
    [    2.398579] systemd[1]: Hostname set to <am62pxx-evm>.
    [    2.610395] systemd[1]: Configuration file /usr/lib/systemd/system/ti-apps-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    2.656701] systemd[1]: Configuration file /usr/lib/systemd/system/seva-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    2.871418] systemd[1]: Queued start job for default target Graphical Interface.
    [    2.926367] systemd[1]: Created slice Slice /system/getty.
    [    2.946975] systemd[1]: Created slice Slice /system/modprobe.
    [    2.966909] systemd[1]: Created slice Slice /system/serial-getty.
    [    2.986354] systemd[1]: Created slice User and Session Slice.
    [    3.005012] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    3.024902] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    3.044778] systemd[1]: Expecting device /dev/ttyS2...
    [    3.056810] systemd[1]: Reached target Path Units.
    [    3.068720] systemd[1]: Reached target Remote File Systems.
    [    3.084675] systemd[1]: Reached target Slice Units.
    [    3.096676] systemd[1]: Reached target Swaps.
    [    3.161959] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    3.180837] systemd[1]: Reached target RPC Port Mapper.
    [    3.203615] systemd[1]: Listening on Process Core Dump Socket.
    [    3.221168] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    3.241870] systemd[1]: Listening on Journal Audit Socket.
    [    3.265403] systemd[1]: Listening on Journal Socket (/dev/log).
    [    3.285397] systemd[1]: Listening on Journal Socket.
    [    3.301547] systemd[1]: Listening on Network Service Netlink Socket.
    [    3.324361] systemd[1]: Listening on udev Control Socket.
    [    3.341270] systemd[1]: Listening on udev Kernel Socket.
    [    3.357325] systemd[1]: Listening on User Database Manager Socket.
    [    3.420925] systemd[1]: Mounting Huge Pages File System...
    [    3.436906] systemd[1]: Mounting POSIX Message Queue File System...
    [    3.461125] systemd[1]: Mounting Kernel Debug File System...
    [    3.473287] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
    [    3.491394] systemd[1]: Mounting Temporary Directory /tmp...
    [    3.510435] systemd[1]: Starting Create List of Static Device Nodes...
    [    3.533498] systemd[1]: Starting Load Kernel Module configfs...
    [    3.557590] systemd[1]: Starting Load Kernel Module drm...
    [    3.581564] systemd[1]: Starting Load Kernel Module fuse...
    [    3.648078] systemd[1]: Starting Start psplash boot splash screen...
             Starting Start psplash boot splash screen.[    3.659329] fuse: init (API version 7.41)
    [    3.674452] systemd[1]: Starting RPC Bind...
    [    3.685256] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
    [    3.694571] systemd[1]: Starting Journal Service...
    [    3.721439] systemd[1]: Starting Load Kernel Modules...
    [    3.745723] systemd[1]: Starting Generate network units from Kernel command line...
    [    3.773420] cryptodev: loading out-of-tree module taints kernel.
    [    3.774165] systemd[1]: Starting Remount Root and Kernel File Systems...
             Starting Remount Root and Kernel File Systems   3.787386] sysctl table check failed: ioctl/(null) procname is null
    [0m...
    [    3.797424] systemd-journald[128]: Collecting audit messages is enabled.
    [    3.799017] sysctl table check failed: ioctl/(null) No proc_handler
    [    3.812497] cryptodev: driver 1.14 loaded.
    [    3.841357] systemd[1]: Starting Coldplug All udev Devices...
    [    3.865108] systemd[1]: Started Start psplash boot splash screen.
    [    3.883209] systemd[1]: Started RPC Bind.
    [    3.902765] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.[    3.909057] EXT4-fs (mmcblk1p2): re-mounted 1b403827-cacd-4230-a707-d8e467ff6764.
             Starting Create Static Device Nodes in /dev gr[    4.246885] systemd-journald[128]: Received client request to flush runtime journal.
    acefully...
    [    4.483493] audit: type=1334 audit(1748544504.216:2): prog-id=6 op=LOAD
    [    4.490233] audit: type=1334 audit(1748544504.224:3): prog-id=7 op=LOAD
    [    4.689899] audit: type=1334 audit(1748544504.424:4): prog-id=8 op=LOAD
    [    4.696622] audit: type=1334 audit(1748544504.432:5): prog-id=9 op=LOAD
    [    4.703723] audit: type=1334 audit(1748544504.436:6): prog-id=10 op=LOAD
    [    4.764224] audit: type=1334 audit(1748544504.496:7): prog-id=11 op=LOAD
    [    4.800950] audit: type=1334 audit(1748544504.536:8): prog-id=12 op=LOAD
    [    6.001714] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
    [    6.038555] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
    [    6.074144] tlv320aic3x 1-001b: supply IOVDD not found, using dummy regulator
    [    6.096104] tlv320aic3x 1-001b: supply DVDD not found, using dummy regulator
    [    6.107888] mc: Linux media interface: v0.10
    [    6.108768] tlv320aic3x 1-001b: supply AVDD not found, using dummy regulator
    [    6.123741] tlv320aic3x 1-001b: supply DRVDD not found, using dummy regulator
    [    6.132813] videodev: Linux video capture interface: v2.00
    [    6.132814] tlv320aic3x 1-001b: Invalid supply voltage(s) AVDD: -22, DVDD: -22
    [    6.152905] platform 79000000.r5f: configured R5F for remoteproc mode
    [    6.153022] snd_soc_davinci_mcasp: unknown parameter 'index' ignored
    [    6.159779] platform 79000000.r5f: assigned reserved memory node mcu-r5fss-dma-memory-region@9b800000
    [    6.183280] remoteproc remoteproc0: 79000000.r5f is available
    [    6.201075] remoteproc remoteproc0: powering up 79000000.r5f
    [    6.202478] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    6.206981] remoteproc remoteproc0: Booting fw image am62p-mcu-r5f0_0-fw, size 59336
    [    6.223305] platform 78000000.r5f: configured R5F for IPC-only mode
    [    6.234863] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9c800000
    [    6.235436] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node mcu-r5fss-dma-memory-region@9b800000
    [    6.247092] remoteproc remoteproc1: 78000000.r5f is available
    [    6.259112] remoteproc remoteproc1: attaching to 78000000.r5f
    [    6.266329] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    6.267019] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0xd
    [    6.273313] rproc-virtio rproc-virtio.1.auto: registered virtio0 (type 7)
    [    6.279830] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    6.282195] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node r5f-dma-memory@9c800000
    [    6.286462] remoteproc remoteproc0: remote processor 79000000.r5f is now up
    [    6.321153] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    6.321658] virtio_rpmsg_bus virtio1: creating channel rpmsg-client-sample addr 0xd
    [    6.331263] rproc-virtio rproc-virtio.2.auto: registered virtio1 (type 7)
    [    6.341338] remoteproc remoteproc1: remote processor 78000000.r5f is now attached
    [    6.352679] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    6.353306] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
    [    6.369720] vdec 30210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
    [    6.377808] vdec 30210000.video-codec: Product Code:      0x521c
    [    6.384095] vdec 30210000.video-codec: Firmware Revision: 363254
    [    6.565550] sii902x 1-003b: supply iovcc not found, using dummy regulator
    [    6.591158] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
    [    6.706937] i2c i2c-1: Added multiplexed i2c bus 3
    [    6.873174] PVR_K:  196: Read BVNC 36.53.104.796 from HW device registers
    [    6.876948] [drm] Initialized tidss 1.0.0 for 30200000.dss on minor 1
    [    6.887383] PVR_K:  196: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
    [    6.896402] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [    6.903867] [drm] Initialized pvr 25.2.6850647 for fd80000.gpu on minor 0
    [    6.911222] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [    7.481032] audit: type=1334 audit(1748937293.546:9): prog-id=13 op=LOAD
    [    7.800831] audit: type=1334 audit(1748937293.862:10): prog-id=14 op=LOAD
    [    7.810408] audit: type=1334 audit(1748937293.870:11): prog-id=15 op=LOAD
    [    7.818908] audit: type=1334 audit(1748937293.870:12): prog-id=16 op=LOAD
    [    7.960702] audit: type=1334 audit(1748937294.022:13): prog-id=17 op=LOAD
    [    8.138921] Bluetooth: Core ver 2.22
    [    8.144182] NET: Registered PF_BLUETOOTH protocol family
    [    8.150917] Bluetooth: HCI device and connection manager initialized
    [    8.158619] Bluetooth: HCI socket layer initialized
    [    8.158639] Bluetooth: L2CAP socket layer initialized
    [    8.158696] Bluetooth: SCO socket layer initialized
    [    8.331669] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    8.373505] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [  OK  ] Mounted /run/media/boot-mmcblk1p1    8.381351] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    0m.
             Starting containerd container runtime...[    8.546034] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    8.560967] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [    8.592090] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL)
    [    8.604844] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
    [    9.101592] audit: type=1006 audit(1748937295.166:14): pid=673 uid=0 subj=kernel old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
    [    9.115722] audit: type=1300 audit(1748937295.166:14): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffdb7a2c08 a2=4 a3=1 items=0 ppid=1 pid=673 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" subj=kernel key=(null)
    [    9.143710] audit: type=1327 audit(1748937295.166:14): proctitle="(systemd)"
    	autoconf
    	bash-dev
    	bash
    	bc
    	binutils
    	cifs-utils
    	coreutils-stdbuf
    	coreutils
    	cpio
    	cpp-symlinks
    	cpp
    	dosfstools
    	elfutils-dev
    	elfutils
    	findutils
    	g++-symlinks
    	g++
    	gawk
    	gcc-symlinks
    	gcc
    	gdb
    	gdbserver
    	gettext
    	glmark2
    	gnu-config
    	grub-common
    	grub-editenv
    	grub-efi
    	gzip
    	hidapi
    	kbd-dev
    	kbd-keymaps-pine
    	less
    	libasm1
    	libatomic-dev
    	libatomic1
    	libbfd
    	libdebuginfod1
    	libdw1
    	libelf1
    	libgcc-s-dev
    	libgcc1
    	libgdbm-compat4
    	libgdbm-dev
    	libgdbm6
    	libgettextlib
    	libgettextsrc
    	libgmp-dev
    	libgmp10
    	libgmpxx4
    	libgnutls-dev
    	libgnutls-openssl27
    	libgomp1
    	libidn2-0
    	libidn2-dev
    	libmpc3
    	libmpfr6
    	libopcodes
    	libqt6core5compat6
    	libqt6shadertools6
    	libreadline-dev
    	libreadline8
    	libstdc++-dev
    	libstdc++6
    	libtasn1-dev
    	libunistring-dev
    	libunistring5
    	m4
    	make
    	nettle-dev
    	nettle
    	parted
    	piglit
    	qt3d-plugins
    	qt3d-qmlplugins
    	qt3d
    	qtbase-dev
    	qtbase-examples
    	qtbase-plugins
    	qtbase-qmlplugins
    	qtbase-staticdev
    	qtbase
    	qtdeclarative-dev
    	qtdeclarative-tools
    	qtdeclarative
    	qtlanguageserver
    	qtmultimedia
    	qtquick3d-plugins
    	qtquick3d
    	qtquicktimeline
    	qtsvg-dev
    	qtsvg-plugins
    	qtsvg-qmlplugins
    	qtsvg
    	qttools-plugins
    	qttools-qmlplugins
    	qttools
    	qtwayland-dev
    	qtwayland-plugins
    	qtwayland
    	tar
    	which
     _____                    _____           _         _
                  |___|                    |___|
    am62pxx-evm login: [   15.114294] PVR_K:  1113: RGX Firmware image 'rgx.fw.36.53.104.796' loaded
    [   15.126743] PVR_K:  1113: Shader binary image 'rgx.sh.36.53.104.796' loaded
    [   15.135572] PVR_K:  1113: SLCSize:   262144
    [   21.819490] audit: type=1006 audit(1748937307.882:15): pid=1152 uid=0 subj=kernel old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=2 res=1
    [   21.833259] audit: type=1300 audit(1748937307.882:15): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=fffff436b908 a2=1 a3=1 items=0 ppid=1 pid=1152 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" subj=kernel key=(null)
    [   21.860934] audit: type=1327 audit(1748937307.882:15): proctitle="(systemd)"
    [   21.877514] audit: type=1334 audit(1748937307.942:16): prog-id=18 op=LOAD
    [   21.884345] audit: type=1300 audit(1748937307.942:16): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffc235c7f8 a2=90 a3=0 items=0 ppid=1 pid=1152 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" subj=kernel key=(null)
    [   21.911224] audit: type=1327 audit(1748937307.942:16): proctitle="(systemd)"
    [   21.918388] audit: type=1334 audit(1748937307.942:17): prog-id=18 op=UNLOAD
    [   21.925415] audit: type=1300 audit(1748937307.942:17): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffff81fb23c0 items=0 ppid=1 pid=1152 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" subj=kernel key=(null)
    [   21.952108] audit: type=1327 audit(1748937307.942:17): proctitle="(systemd)"
    [   21.959240] audit: type=1334 audit(1748937307.942:18): prog-id=19 op=LOAD
    root@am62pxx-evm:~#
    root@am62pxx-evm:~#
    root@am62pxx-evm:~# i2cdls -al /dev/i2c-*
    crw------- 1 root root 89, 0 Jun  3 07:54 /dev/i2c-0
    crw------- 1 root root 89, 1 Jun  3 07:54 /dev/i2c-1
    crw------- 1 root root 89, 2 Jun  3 07:54 /dev/i2c-2
    crw------- 1 root root 89, 3 Jun  3 07:54 /dev/i2c-3
    root@am62pxx-evm:~# ie 2cdetect -a - 0
    Continue? [Y/n] y
    00:
    10:
    20:
    40:
    60:
    70:
    Continue? [Y/n] y
    00:
    10:
    20:
    40:
    60:
    70:
    Continue? [Y/n] y
    00:
    10:
    20:
    40:
    60:
    70:
    root@am62pxx-evm:~#
    - chip connected over i2c-0: am62p_i2c0_boot.log
    U-Boot SPL 2025.01-00766-g7493977a537f (Dec 03 2025 - 15:20:36 +0000)
    SYSFW ABI: 4.0 (firmware rev 0x000b '11.2.5--v11.02.05 (Fancy Rat)')
    Set clock rates for '/a53@0', CPU: 1250MHz at Speed Grade 'V'
    SPL initial stack usage: 17104 bytes
    Trying to boot from MMC2
    Authentication passed
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.13.0(release):v2.13.0-259-ge0c4d3903b-dirty
    NOTICE:  BL31: Built : 07:01:36, Jul  1 2025
    DM ABI: 3.0 (firmware ver 0x000b 'MSDK.11.02.00.11--v11.02.05' patch_ver: 5)
    SPL initial stack usage: 1984 bytes
    U-Boot 2025.01-00766-g7493977a537f (Dec 03 2025 - 15:20:36 +0000)
    SoC:   AM62PX SR1.2 HS-FS
    Model: Texas Instruments AM62P5 SK
    DRAM:  2 GiB (total 8 GiB)
    Core:  102 devices, 33 uclasses, devicetree: separate
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1
    Loading Environment from nowhere... OK
    In:    serial
    Out:   serial
    Err:   serial
    Net:   eth0: ethernet@8000000port@1
    Warning: ethernet@8000000port@2 (eth1) using random MAC address - 6a:49:a6:97:2e:72
    , eth1: ethernet@8000000port@2
    Hit any key to stop autoboot:  2  1  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    575 bytes read in 0 ms
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    22391296 bytes read in 227 ms (94.1 MiB/s)
    Working FDT set to 88000000
       Loading Device Tree to 000000008feec000, end 000000008fffffff ... OK
    Working FDT set to 8feec000
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 6.12.57-ti-g31b07ab8dfbc (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.4.0, GNU ld (GNU Binutils) 2.42.0.20240723) #1 SMP PREEMPT Thu Dec  4 13:07:37 UTC 2025
    [    0.000000] KASLR disabled due to lack of seed
    [    0.000000] Machine model: Texas Instruments AM62P5 SK
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: legacy bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created CMA memory pool at 0x00000009dc000000, size 576 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000009dc000000..0x00000009ffffffff (589824 KiB) map reusable linux,cma
    [    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
    [    0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000
    [    0.000000] OF: reserved mem: 0x00000000ff700000..0x00000000ffffffff (9216 KiB) nomap non-reusable framebuffer@ff700000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009b500000, size 3 MiB
    [    0.000000] OF: reserved mem: initialized node rtos-ipc-memory@9b500000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009b500000..0x000000009b7fffff (3072 KiB) nomap non-reusable rtos-ipc-memory@9b500000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009b800000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node mcu-r5fss-dma-memory-region@9b800000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009b800000..0x000000009b8fffff (1024 KiB) nomap non-reusable mcu-r5fss-dma-memory-region@9b800000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009b900000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node mcu-r5fss-memory-region@9b900000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009b900000..0x000000009c7fffff (15360 KiB) nomap non-reusable mcu-r5fss-memory-region@9b900000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c800000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009c800000..0x000000009c8fffff (1024 KiB) nomap non-reusable r5f-dma-memory@9c800000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009c900000, size 30 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@9c900000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009c900000..0x000000009e6fffff (30720 KiB) nomap non-reusable r5f-memory@9c900000
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000009ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000008007ffff]
    [    0.000000]   node   0: [mem 0x0000000080080000-0x000000009b4fffff]
    [    0.000000]   node   0: [mem 0x000000009b500000-0x000000009e6fffff]
    [    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x000000009fffffff]
    [    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000ff6fffff]
    [    0.000000]   node   0: [mem 0x00000000ff700000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000009ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009ffffffff]
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.5
    [    0.000000] percpu: Embedded 22 pages/cpu s51736 r8192 d30184 u90112
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=076c4a2a-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2097152
    [    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
    [    0.000000] software IO TLB: area num 4.
    [    0.000000] software IO TLB: mapped [mem 0x00000000fb700000-0x00000000ff700000] (64MB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU event tracing is enabled.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
    [    0.000000] 	Trampoline variant of Tasks RCU enabled.
    [    0.000000] 	Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
    [    0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000880050000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880060000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008694] Console: colour dummy device 80x25
    [    0.013295] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023966] pid_max: default: 32768 minimum: 301
    [    0.033898] SELinux:  Initializing.
    [    0.037917] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.045676] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.056092] rcu: Hierarchical SRCU implementation.
    [    0.061038] rcu: 	Max phase no-delay instances is 1000.
    [    0.066565] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
    [    0.075311] EFI services will not be available.
    [    0.080196] smp: Bringing up secondary CPUs ...
    [    0.085422] Detected VIPT I-cache on CPU1
    [    0.085503] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.085520] GICv3: CPU1: using allocated LPI pending table @0x0000000880070000
    [    0.085567] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.086297] Detected VIPT I-cache on CPU2
    [    0.086364] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
    [    0.086379] GICv3: CPU2: using allocated LPI pending table @0x0000000880080000
    [    0.086412] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.087063] Detected VIPT I-cache on CPU3
    [    0.087126] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
    [    0.087140] GICv3: CPU3: using allocated LPI pending table @0x0000000880090000
    [    0.087172] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.087295] smp: Brought up 1 node, 4 CPUs
    [    0.166927] SMP: Total of 4 processors activated.
    [    0.171734] CPU: All CPU(s) started at EL2
    [    0.175937] CPU features: detected: 32-bit EL0 Support
    [    0.181190] CPU features: detected: CRC32 instructions
    [    0.186485] alternatives: applying system-wide alternatives
    [    0.192765] Memory: 7454932K/8388608K available (13056K kernel code, 1258K rwdata, 4676K rodata, 2752K init, 643K bss, 334804K reserved, 589824K cma-reserved)
    [    0.208350] devtmpfs: initialized
    [    0.222827] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.232830] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.254924] 27120 pages in range for non-PLT usage
    [    0.254947] 518640 pages in range for PLT usage
    [    0.260153] pinctrl core: initialized pinctrl subsystem
    [    0.270740] DMI not present or invalid.
    [    0.276864] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.284165] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
    [    0.291616] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.299733] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.307972] audit: initializing netlink subsys (disabled)
    [    0.313725] audit: type=2000 audit(0.196:1): state=initialized audit_enabled=0 res=1
    [    0.314195] thermal_sys: Registered thermal governor 'step_wise'
    [    0.321652] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.327836] cpuidle: using governor menu
    [    0.338677] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.345705] ASID allocator initialised with 65536 entries
    [    0.357232] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000
    [    0.368739] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    0.381383] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.391295] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    0.404023] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.419245] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    0.432013] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.442738] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    0.457406] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.467352] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.478822] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    0.488063] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.498100] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.505068] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.511474] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.518407] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.524809] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.531740] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.538144] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.545077] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.553152] debugfs: Directory '43000014.chipid' with parent 'regmap' already present!
    [    0.561339] k3-chipinfo 43000014.chipid: Family:AM62PX rev:SR1.2 JTAGID[0x0bb9d02f] Detected
    [    0.570754] iommu: Default domain type: Translated
    [    0.575677] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.582812] SCSI subsystem initialized
    [    0.587074] usbcore: registered new interface driver usbfs
    [    0.592722] usbcore: registered new interface driver hub
    [    0.598180] usbcore: registered new device driver usb
    [    0.603865] pps_core: LinuxPPS API ver. 1 registered
    [    0.608944] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.618281] PTP clock support registered
    [    0.622316] EDAC MC: Ver: 3.0.0
    [    0.625850] scmi_core: SCMI protocol bus registered
    [    0.631133] FPGA manager framework
    [    0.634686] Advanced Linux Sound Architecture Driver Initialized.
    [    0.641938] vgaarb: loaded
    [    0.645106] clocksource: Switched to clocksource arch_sys_counter
    [    0.651617] VFS: Disk quotas dquot_6.6.0
    [    0.655654] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.669943] NET: Registered PF_INET protocol family
    [    0.675239] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.688203] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
    [    0.697045] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.704988] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.713494] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
    [    0.722769] TCP: Hash tables configured (established 65536 bind 65536)
    [    0.729660] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    0.736757] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    0.744441] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.750726] RPC: Registered named UNIX socket transport module.
    [    0.756802] RPC: Registered udp transport module.
    [    0.761609] RPC: Registered tcp transport module.
    [    0.766413] RPC: Registered tcp-with-tls transport module.
    [    0.772016] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.778596] NET: Registered PF_XDP protocol family
    [    0.783506] PCI: CLS 0 bytes, default 64
    [    0.788848] Initialise system trusted keyrings
    [    0.793641] workingset: timestamp_bits=46 max_order=21 bucket_order=0
    [    0.800544] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.806802] NFS: Registering the id_resolver key type
    [    0.811997] Key type id_resolver registered
    [    0.816271] Key type id_legacy registered
    [    0.820387] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.827236] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.888695] Key type asymmetric registered
    [    0.892897] Asymmetric key parser 'x509' registered
    [    0.897962] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.905680] io scheduler mq-deadline registered
    [    0.910319] io scheduler kyber registered
    [    0.914447] io scheduler bfq registered
    [    0.921571] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.928102] pinctrl-single f4000.pinctrl: 172 pins, size 688
    [    0.935824] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.948073] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.965484] loop: module loaded
    [    0.969818] megasas: 07.727.03.00-rc1
    [    0.977702] tun: Universal TUN/TAP device driver, 1.6
    [    0.984014] VFIO - User Level meta-driver version: 0.3
    [    0.990609] usbcore: registered new interface driver usb-storage
    [    0.997392] i2c_dev: i2c /dev entries driver
    [    1.003461] sdhci: Secure Digital Host Controller Interface driver
    [    1.009843] sdhci: Copyright(c) Pierre Ossman
    [    1.014529] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.021028] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    1.028524] usbcore: registered new interface driver usbhid
    [    1.034241] usbhid: USB HID core driver
    [    1.039565] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 (0,8000003f) counters available
    [    1.049850] optee: probing for conduit method.
    [    1.054437] optee: revision 4.7 (a9690ae39995af36)
    [    1.054820] optee: dynamic shared memory is enabled
    [    1.065459] optee: initialized driver
    [    1.065569] random: crng init done
    [    1.070923] Initializing XFRM netlink socket
    [    1.077113] NET: Registered PF_PACKET protocol family
    [    1.082364] Key type dns_resolver registered
    [    1.095540] registered taskstats version 1
    [    1.099929] Loading compiled-in X.509 certificates
    [    1.117030] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.2.5--v11.02.05 (Fancy Rat)')
    [    1.174249] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    1.187030] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.194202] pca953x 1-0023: supply vcc not found, using dummy regulator
    [    1.201104] pca953x 1-0023: using AI
    [    1.219371] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    1.228620] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    1.238549] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    1.247761] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    1.257853] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
    [    1.264768] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
    [    1.271218] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    1.280504] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.289503] ti-sci-inta 4e400000.interrupt-controller: Interrupt Aggregator domain 200 created
    [    1.299550] simple-framebuffer ff700000.framebuffer: framebuffer at 0xff700000, 0x8ca000 bytes
    [    1.308399] simple-framebuffer ff700000.framebuffer: format=a8r8g8b8, mode=1920x1200x32, linelength=7680
    [    1.329069] Console: switching to colour frame buffer device 240x75
    [    1.345552] simple-framebuffer ff700000.framebuffer: fb0: simplefb registered!
    [    1.353323] ti-udma 485c0100.dma-controller: Number of rings: 82
    [    1.362017] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    1.373040] ti-udma 485c0000.dma-controller: Number of rings: 150
    [    1.383993] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    1.393578] ti-udma 4e230000.dma-controller: Number of rings: 6
    [    1.400242] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6)
    [    1.409887] printk: legacy console [ttyS2] disabled
    [    1.415237] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 250, base_baud = 3000000) is a 8250
    [    1.424119] printk: legacy console [ttyS2] enabled
    [    1.433891] printk: legacy bootconsole [ns16550a0] disabled
    [    1.452651] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
    [    1.459642] Creating 7 MTD partitions on "fc40000.spi.0":
    [    1.465039] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.471816] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.478275] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.484771] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    1.491053] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [    1.497969] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.504479] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.511492] cadence-qspi fc40000.spi: Pattern not found. Skipping calibration.
    [    1.519464] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006
    [    1.569119] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000
    [    1.583578] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    1.591684] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
    [    1.599919] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    1.607053] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512, Policers 32
    [    1.614898] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:500000000, add_val:1 pps:0
    [    1.633852] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    1.644766] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    1.657246] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    1.674476] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    1.680020] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    1.687795] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
    [    1.693801] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000808020000010
    [    1.703234] xhci-hcd xhci-hcd.0.auto: irq 264, io mem 0x31100000
    [    1.710040] hub 1-0:1.0: USB hub found
    [    1.713828] hub 1-0:1.0: 1 port detected
    [    1.721036] mmc0: CQHCI version 5.10
    [    1.726134] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    1.732911] pca953x 1-0022: using AI
    [    1.741364] clk: Disabling unused clocks
    [    1.743136] mmc1: CQHCI version 5.10
    [    1.750210] PM: genpd: Disabling unused power domains
    [    1.755432] ALSA device list:
    [    1.758406]   No soundcards found.
    [    1.763699] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.785130] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    1.792888] Waiting for root device PARTUUID=076c4a2a-02...
    [    1.851871] mmc1: new ultra high speed SDR104 SDXC card at address 59b4
    [    1.858618] mmc0: Command Queue Engine enabled
    [    1.859337] mmcblk1: mmc1:59b4 EC1S5 59.7 GiB
    [    1.863102] mmc0: new HS400 MMC card at address 0001
    [    1.869678]  mmcblk1: p1 p2
    [    1.873372] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    1.881228]  mmcblk0: p1 p2
    [    1.884505] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
    [    1.890389] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
    [    1.896188] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
    [    2.073079] EXT4-fs (mmcblk1p2): recovery complete
    [    2.080303] EXT4-fs (mmcblk1p2): mounted filesystem 1b403827-cacd-4230-a707-d8e467ff6764 r/w with ordered data mode. Quota mode: none.
    [    2.092487] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    2.099395] devtmpfs: mounted
    [    2.103180] Freeing unused kernel memory: 2752K
    [    2.107831] Run /sbin/init as init process
    [    2.288892] systemd[1]: System time before build time, advancing clock.
    [    2.334579] NET: Registered PF_INET6 protocol family
    [    2.340625] Segment Routing with IPv6
    [    2.344358] In-situ OAM (IOAM) with IPv6
    [    2.375593] systemd[1]: systemd 255.21^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    2.407481] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2025.01!
    [    2.423169] systemd[1]: Hostname set to <am62pxx-evm>.
    [    2.626888] systemd[1]: Configuration file /usr/lib/systemd/system/ti-apps-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    2.673225] systemd[1]: Configuration file /usr/lib/systemd/system/seva-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    2.887720] systemd[1]: Queued start job for default target Graphical Interface.
    [    2.931086] systemd[1]: Created slice Slice /system/getty.
    [  OK  ] Created slice Slice /system/getty.
    [    2.951527] systemd[1]: Created slice Slice /system/modprobe.
    [  OK  ] Created slice Slice /system/modprobe.
    [    2.971493] systemd[1]: Created slice Slice /system/serial-getty.
    [  OK  ] Created slice Slice /system/serial-getty.
    [    2.990933] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    3.009558] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
    [    3.029484] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password Requests to Wall Directory Watch.
    [    3.049322] systemd[1]: Expecting device /dev/ttyS2...
    [    3.065362] systemd[1]: Reached target Path Units.
    [  OK  ] Reached target Path Units.
    [    3.077247] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    3.093278] systemd[1]: Reached target Slice Units.
    [  OK  ] Reached target Slice Units.
    [    3.105246] systemd[1]: Reached target Swaps.
    [  OK  ] Reached target Swaps.
    [    3.162493] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    3.181400] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    3.204019] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    3.221729] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    3.242462] systemd[1]: Listening on Journal Audit Socket.
    [  OK  ] Listening on Journal Audit Socket.
    [    3.261937] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    3.281979] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    3.298119] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    3.320994] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    3.337843] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    3.353909] systemd[1]: Listening on User Database Manager Socket.
    [  OK  ] Listening on User Database Manager Socket.
    [    3.413497] systemd[1]: Mounting Huge Pages File System...
    [    3.429525] systemd[1]: Mounting POSIX Message Queue File System...
    [    3.453634] systemd[1]: Mounting Kernel Debug File System...
    [    3.465860] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
    [    3.483896] systemd[1]: Mounting Temporary Directory /tmp...
    [    3.502983] systemd[1]: Starting Create List of Static Device Nodes...
    [    3.526091] systemd[1]: Starting Load Kernel Module configfs...
    [    3.550103] systemd[1]: Starting Load Kernel Module drm...
    [    3.566223] systemd[1]: Starting Load Kernel Module fuse...
    [    3.596705] systemd[1]: Starting Start psplash boot splash screen...
             Starting Start psplash boot splash screen.[    3.608206] fuse: init (API version 7.41)
    [    3.623495] systemd[1]: Starting RPC Bind...
    [    3.633811] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
    [    3.643242] systemd[1]: Starting Journal Service...
    [    3.671499] systemd[1]: Starting Load Kernel Modules...
    [    3.694219] systemd[1]: Starting Generate network units from Kernel command line...
    [    3.720093] cryptodev: loading out-of-tree module taints kernel.
    [    3.721783] systemd[1]: Starting Remount Root and Kernel File Systems...
             Starting Remount Root and Kernel File Systems   3.737409] sysctl table check failed: ioctl/(null) procname is null
    [0m...
    [    3.745943] sysctl table check failed: ioctl/(null) No proc_handler
    [    3.752934] cryptodev: driver 1.14 loaded.
    [    3.758589] systemd-journald[127]: Collecting audit messages is enabled.
    [    3.762933] systemd[1]: Starting Coldplug All udev Devices...
    [    3.793470] systemd[1]: Started Start psplash boot splash screen.
    [  OK  ] Started Start psplash boot splash screen.
    [    3.815455] systemd[1]: Started RPC Bind.
    [    3.820133] EXT4-fs (mmcblk1p2): re-mounted 1b403827-cacd-4230-a707-d8e467ff6764.
    [  OK  ] Started RPC Bind.
    [    3.835738] systemd[1]: Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory /tmp.
    [  OK  ] Finished Create List of Static Device Nodes.
    [  OK  ] Finished Load Kernel Module configfs.
    [  OK  ] Finished Load Kernel Module drm.
    [  OK  ] Finished Load Kernel Module fuse.
    [  OK  ] Finished Load Kernel Modules.
    [  OK  ] Finished Generate network units from Kernel command line.
    [  OK  ] Finished Remount Root and Kernel File Systems.
             Mounting FUSE Control File System...
             Mounting Kernel Configuration File System...
    [  OK  ] Started Start psplash-systemd progress communication helper.
             Starting Flush Journal to Persistent Storage...
             Starting Apply Kernel Variables...
             Starting Create Static Device Nodes in /dev gr[    4.141537] systemd-journald[127]: Received client request to flush runtime journal.
    acefully...
    [  OK  ] Mounted FUSE Control File System.
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Finished Flush Journal to Persistent Storage.
    [  OK  ] Finished Apply Kernel Variables.
    [  OK  ] Finished Create Static Device Nodes in /dev gracefully.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Finished Create Static Device Nodes in /dev.
    [  OK  ] Reached target Preparation for Local File Systems.
             Mounting /var/volatile...
    [    4.360116] audit: type=1334 audit(1748544504.068:2): prog-id=6 op=LOAD
    [    4.366866] audit: type=1334 audit(1748544504.076:3): prog-id=7 op=LOAD
             Starting Rule-based Manager for Device Events and Files...
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save OS Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create System Files and Directories...
    [  OK  ] Finished Coldplug All udev Devices.
    [  OK  ] Finished Load/Save OS Random Seed.
             Starting Wait for udev To Complete Device Initialization...
    [  OK  ] Finished Create System Files and Directories.
    [    4.599661] audit: type=1334 audit(1748544504.308:4): prog-id=8 op=LOAD
             Starting Network Name Resolution...
    [    4.645067] audit: type=1334 audit(1748544504.352:5): prog-id=9 op=LOAD
             Starting Network Time Synchronization...
             Starting Record System Boot/Shutdown in UTMP...
    [    4.692967] audit: type=1334 audit(1748544504.400:6): prog-id=10 op=LOAD
    [    4.700121] audit: type=1334 audit(1748544504.408:7): prog-id=11 op=LOAD
    [    4.707062] audit: type=1334 audit(1748544504.416:8): prog-id=12 op=LOAD
             Starting User Database Manager...
    [  OK  ] Finished Record System Boot/Shutdown in UTMP.
    [  OK  ] Started User Database Manager.
    [  OK  ] Started Rule-based Manager for Device Events and Files.
    [  OK  ] Found device /dev/ttyS2.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Host and Network Name Lookups.
    [    5.984934] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
    [    5.994335] tlv320aic3x 1-001b: supply IOVDD not found, using dummy regulator
    [    6.001609] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
    [    6.001750] tlv320aic3x 1-001b: supply DVDD not found, using dummy regulator
    [    6.002167] mc: Linux media interface: v0.10
    [    6.019643] tlv320aic3x 1-001b: supply AVDD not found, using dummy regulator
    [    6.026831] tlv320aic3x 1-001b: supply DRVDD not found, using dummy regulator
    [    6.034121] tlv320aic3x 1-001b: Invalid supply voltage(s) AVDD: -22, DVDD: -22
    [    6.043944] videodev: Linux video capture interface: v2.00
    [    6.115231] vdec 30210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
    [    6.123289] vdec 30210000.video-codec: Product Code:      0x521c
    [    6.124370] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
    [    6.129383] vdec 30210000.video-codec: Firmware Revision: 363254
    [    6.143094] snd_soc_davinci_mcasp: unknown parameter 'index' ignored
    [    6.158627] platform 79000000.r5f: configured R5F for remoteproc mode
    [    6.165547] platform 79000000.r5f: assigned reserved memory node mcu-r5fss-dma-memory-region@9b800000
    [    6.284547] remoteproc remoteproc0: 79000000.r5f is available
    [    6.293322] remoteproc remoteproc0: powering up 79000000.r5f
    [    6.300954] remoteproc remoteproc0: Booting fw image am62p-mcu-r5f0_0-fw, size 59336
    [  OK  ] Reached target Hardware activated USB gadget.
    [    6.389686] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node mcu-r5fss-dma-memory-region@9b800000
    [    6.394702] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    6.402899] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    6.403289] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0xd
    [    6.418655] platform 78000000.r5f: configured R5F for IPC-only mode
    [    6.431350] rproc-virtio rproc-virtio.2.auto: registered virtio0 (type 7)
    [    6.432549] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9c800000
    [    6.438920] remoteproc remoteproc0: remote processor 79000000.r5f is now up
    [    6.474150] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    6.476685] remoteproc remoteproc1: 78000000.r5f is available
    [    6.487304] remoteproc remoteproc1: attaching to 78000000.r5f
    [    6.516137] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node r5f-dma-memory@9c800000
    [    6.521628] sii902x 1-003b: supply iovcc not found, using dummy regulator
    [    6.526204] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    6.532139] virtio_rpmsg_bus virtio1: creating channel rpmsg-client-sample addr 0xd
    [    6.537853] rproc-virtio rproc-virtio.3.auto: registered virtio1 (type 7)
    [    6.537905] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
    [    6.545569] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    6.554826] remoteproc remoteproc1: remote processor 78000000.r5f is now attached
    [    6.561287] PVR_K:  188: Read BVNC 36.53.104.796 from HW device registers
    [    6.583389] PVR_K:  188: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
    [    6.584404] i2c i2c-1: Added multiplexed i2c bus 3
    [    6.598907] [drm] Initialized pvr 25.2.6850647 for fd80000.gpu on minor 0
    [    6.615983] [drm] Initialized tidss 1.0.0 for 30200000.dss on minor 1
    [    6.623602] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [    6.631849] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [  OK  ] Created slice Slice /system/tee-supplicant.
             Starting Virtual Console Setup...
    [  OK  ] Created slice Slice /system/systemd-fsck.
             Expecting device /dev/mmcblk0p1...
    [  OK  ] Finished Virtual Console Setup.
    [  OK  ] Found device /dev/mmcblk0p1.
             Expecting device /dev/mmcblk1p1...
             Starting File System Check on /dev/mmcblk0p1...
    [  OK  ] Found device /dev/mmcblk1p1.
    [  OK  ] Finished Wait for udev To Complete Device Initialization.
    [  OK  ] Finished File System Check on /dev/mmcblk0p1.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timer Units.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API...
    [  OK  ] Listening on dropbear.socket.
    [  OK  ] Listening on PC/SC Smart Card Daemon Activation Socket.
             Mounting /run/media/mmcblk0p1...
    [    7.341217] audit: type=1334 audit(1748937353.646:9): prog-id=13 op=LOAD
             Starting D-Bus System Message Bus...
             Starting Reboot and dump vmcore via kexec...
             Starting File System Check on /dev/mmcblk1p1...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Mounted /run/media/mmcblk0p1.
    [  OK  ] Finished Reboot and dump vmcore via kexec.
    [  OK  ] Started D-Bus System Message Bus.
    [  OK  ] Reached target Socket Units.
    [  OK  ] Reached target Basic System.
             Starting Save/Restore Sound Card State...
    [  OK  ] Started Job spooling tools.
             Starting Avahi mDNS/DNS-SD Stack...
    [  OK  ] Started Periodic Command Scheduler.
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
    [  OK  ] Started Multiple Spanning Tree Protocol Daemon.
             Starting Telephony service...
             Starting Expand the rootfs partiti�to full size of the boot device....
    [  OK  ] Started Seva Launcher Service.
    [  OK  ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
    [    7.645413] audit: type=1334 audit(1748937353.946:10): prog-id=14 op=LOAD
             Starting User Login Management...
    [    7.657223] audit: type=1334 audit(1748937353.946:11): prog-id=15 op=LOAD
    [  OK  ] Started TEE Supplicant on teepriv0   7.664733] audit: type=1334 audit(1748937353.946:12): prog-id=16 op=LOAD
    [0m.
             Starting Telnet Server...
             Starting Touch Input Service (touch_sender)...
    [  OK  ] Finished File System Check on /dev/mmcblk1p1.
    [  OK  ] Finished Save/Restore Sound Card State.
    [  OK  ] Finished IPv6 Packet Filtering Framework.
    [  OK  ] Finished IPv4 Packet Filtering Framework.
    [  OK  ] Finished Telnet Server.
    [  OK  ] Reached target Preparation for Network.
    [  OK  ] Reached target Sound Card.
             Mounting /run/media/boot-mmcblk1p1...
             Starting PulseAudio Sound System...
    [    7.815695] audit: type=1334 audit(1748937354.118:13): prog-id=17 op=LOAD
             Starting Network Configuration...
    [  OK  ] Started Telephony service.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [    7.870604] Bluetooth: Core ver 2.22
    [    7.874759] NET: Registered PF_BLUETOOTH protocol family
    [    7.880290] Bluetooth: HCI device and connection manager initialized
    [    7.886861] Bluetooth: HCI socket layer initialized
    [    7.891860] Bluetooth: L2CAP socket layer initialized
    [    7.897068] Bluetooth: SCO socket layer initialized
    [  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
    [  OK  ] Finished Expand the rootfs partition to full size of the boot device..
    [  OK  ] Mounted /run/media/boot-mmcblk1p1.
    [    8.198937] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [  OK  ] Started User Login Management.
    [    8.222174] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [  OK  ] Created slice User Slice of UID 100[    8.228889] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    0.
             Starting User Runtime Directory /run/user/1000...
    [  OK  ] Finished User Runtime Directory /run/user/1000.
    [  OK  ] Started Network Configuration.
    [  OK  ] Reached target Network.
             Starting LLDP daemon...
    [    8.410404] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    8.419992] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [  OK  ] Started Netperf Benchmark Server.
    [    8.454656] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL)
             Starting Simple Network Management Protocol (S[    8.464318] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
    NMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Finished Permit User Sessions.
    [  OK  ] Started emptty display manager.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
             Starting ti-apps-launcher service...
             Starting User Manager for UID 1000...
    [  OK  ] Started LLDP daemon.
    [    8.915255] audit: type=1006 audit(1748937355.218:14): pid=671 uid=0 subj=kernel old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
    [    8.929035] audit: type=1300 audit(1748937355.218:14): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffe7c7cc48 a2=4 a3=1 items=0 ppid=1 pid=671 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" subj=kernel key=(null)
    [    8.956991] audit: type=1327 audit(1748937355.218:14): proctitle="(systemd)"
    [  OK  ] Started PulseAudio Sound System.
    [  OK  ] Started Simple Network Management Protocol (SNMP) Daemon..
    [  OK  ] Started User Manager for UID 1000.
    [  OK  ] Started containerd container runtime.
    NOTICE: This file system contains the following GPL-3.0 packages:
    	adwaita-icon-theme-symbolic
    	autoconf
    	bash-dev
    	bash
    	bc
    	binutils
    	cifs-utils
    	coreutils-stdbuf
    	coreutils
    	cpio
    	cpp-symlinks
    	cpp
    	dosfstools
    	elfutils-dev
    	elfutils
    	findutils
    	g++-symlinks
    	g++
    	gawk
    	gcc-symlinks
    	gcc
    	gdb
    	gdbserver
    	gettext
    	glmark2
    	gnu-config
    	grub-common
    	grub-editenv
    	grub-efi
    	gzip
    	hidapi
    	kbd-dev
    	kbd-keymaps-pine
    	less
    	libasm1
    	libatomic-dev
    	libatomic1
    	libbfd
    	libdebuginfod1
    	libdw1
    	libelf1
    	libgcc-s-dev
    	libgcc1
    	libgdbm-compat4
    	libgdbm-dev
    	libgdbm6
    	libgettextlib
    	libgettextsrc
    	libgmp-dev
    	libgmp10
    	libgmpxx4
    	libgnutls-dev
    	libgnutls-openssl27
    	libgomp1
    	libidn2-0
    	libidn2-dev
    	libmpc3
    	libmpfr6
    	libopcodes
    	libqt6core5compat-plugins
    	libqt6core5compat-qmlplugins
    	libqt6core5compat6
    	libqt6shadertools-dev
    	libqt6shadertools-plugins
    	libqt6shadertools-qmlplugins
    	libqt6shadertools6
    	libreadline-dev
    	libreadline8
    	libstdc++-dev
    	libstdc++6
    	libtasn1-dev
    	libunistring-dev
    	libunistring5
    	m4
    	make
    	nettle-dev
    	nettle
    	parted
    	piglit
    	qt3d-plugins
    	qt3d-qmlplugins
    	qt3d
    	qtbase-dev
    	qtbase-examples
    	qtbase-plugins
    	qtbase-qmlplugins
    	qtbase-staticdev
    	qtbase
    	qtdeclarative-dev
    	qtdeclarative-plugins
    	qtdeclarative-qmlplugins
    	qtdeclarative-staticdev
    	qtdeclarative-tools
    	qtdeclarative
    	qtlanguageserver-dev
    	qtlanguageserver-plugins
    	qtlanguageserver-qmlplugins
    	qtlanguageserver-staticdev
    	qtlanguageserver
    	qtmultimedia-plugins
    	qtmultimedia-qmlplugins
    	qtmultimedia
    	qtquick3d-plugins
    	qtquick3d-qmlplugins
    	qtquick3d
    	qtquicktimeline-plugins
    	qtquicktimeline-qmlplugins
    	qtquicktimeline
    	qtsvg-dev
    	qtsvg-plugins
    	qtsvg-qmlplugins
    	qtsvg
    	qttools-plugins
    	qttools-qmlplugins
    	qttools
    	qtwayland-dev
    	qtwayland-plugins
    	qtwayland-qmlplugins
    	qtwayland
    	tar
    	which
    If you do not wish to distribute GPL-3.0 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Finished Print notice about GPLv3 packages.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project am62pxx-evm ttyS2
    Arago 2025.01 am62pxx-evm ttyS2
    am62pxx-evm login: [   15.015849] PVR_K:  1111: RGX Firmware image 'rgx.fw.36.53.104.796' loaded
    [   15.028385] PVR_K:  1111: Shader binary image 'rgx.sh.36.53.104.796' loaded
    [   15.037230] PVR_K:  1111: SLCSize:   262144
    am62pxx-evm login: root
    [   20.567749] audit: type=1006 audit(1748937366.870:15): pid=1149 uid=0 subj=kernel old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=2 res=1
    [   20.581356] audit: type=1300 audit(1748937366.870:15): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffe697bf48 a2=1 a3=1 items=0 ppid=1 pid=1149 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" subj=kernel key=(null)
    [   20.609177] audit: type=1327 audit(1748937366.870:15): proctitle="(systemd)"
    [   20.637807] audit: type=1334 audit(1748937366.942:16): prog-id=18 op=LOAD
    [   20.644648] audit: type=1300 audit(1748937366.942:16): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffcd28bb78 a2=90 a3=0 items=0 ppid=1 pid=1149 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" subj=kernel key=(null)
    [   20.671517] audit: type=1327 audit(1748937366.942:16): proctitle="(systemd)"
    [   20.678780] audit: type=1334 audit(1748937366.942:17): prog-id=18 op=UNLOAD
    [   20.685831] audit: type=1300 audit(1748937366.942:17): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffffa432d3c0 items=0 ppid=1 pid=1149 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" subj=kernel key=(null)
    [   20.712633] audit: type=1327 audit(1748937366.942:17): proctitle="(systemd)"
    [   20.719765] audit: type=1334 audit(1748937366.942:18): prog-id=19 op=LOAD
    root@am62pxx-evm:~# i3
    root@am62pxx-evm:~#
    root@am62pxx-evm:~#
    root@am62pxx-evm:~# i2cdetect -a 0
    Warning: Can't use SMBus Quick Write command, will skip some addresses
    WARNING! This program can confuse your I2C bus, cause data loss and worse!
    I will probe file /dev/i2c-0.
    I will probe address range 0x00-0x7f.
    Continue? [Y/n] y
         0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
    00:
    10:
    20:
    30: -- -- -- -- -- -- -- --
    40:
    50: -- 51 -- -- -- -- -- -- -- -- -- -- -- -- -- --
    60:
    70:
    root@am62pxx-evm:~# i2cdetect -a 0 1
    I will probe file /dev/i2c-1.
    Continue? [Y/n] y
    00:
    10:
    20:
    40:
    50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    60:
    70:
    root@am62pxx-evm:~# i2cdetect -a 1 2
    I will probe file /dev/i2c-2.
    Continue? [Y/n] y
    00:
    10:
    20:
    40:
    60:
    70:
    root@am62pxx-evm:~#
    Command
    When connected over i2c-2,
    i2cdetect -a 2
    When connected over i2c-0,
    i2cdetect -a 0
    Thanks & Regards,
    Mohammed Shakir
  • Issue was due to the VCC3V3_EXP not giving 3.3v by default, running below command brought it up with i2c-0.
    "gpioset -z -c gpiochip3 5=1"
