TPS386000: Design Review - TPS386000
Part Number: TPS386000
Hi TI Team,
Regarding the TPS386000RGPR design, I would like some clarification on the SENSE4L and SENSE4H pins, which we are currently not using.
From the datasheet (Below Image) it is suggested that the SENSE4H pin can be connected to ground if unused. We have followed the same approach in our design.
However, we do not plan to use the SENSE4L pin. Could you please confirm whether the unused SENSE4L pin can be safely left floating, or if it requires a defined connection ?
Additionally, could you please confirm whether all reset pins are internally connected together, or if they operate independently?
Your guidance on these points would be very helpful.
Thank you for your support.
