Part Number: P82B96
Other Parts Discussed in Thread: TCA9511A, P82B715, TCA9617B
Hi TI Support Team,
I am designing an I2C system that requires both hot-swap protection and long-range bus extension, and I have the following questions regarding using the TCA9511A together with the P82B715:
1. Is it technically feasible to use the TCA9511A and P82B715 together in the same I2C signal chain?
2. What is the recommended placement order — should the TCA9511A be placed before or after the P82B715?
3. Are there any known compatibility issues, timing conflicts, or voltage level concerns when combining these two devices?
Thank you for your time and guidance!
Kittitouch
