Part Number: DP83848Q-Q1
The data sheets recommend the Pulse H1102 transformer, but it is both obsolete and has an insufficient temperature range. Could you recommend suitable alternative transformers instead?
Thanx
Eli.
Thanx
Eli.
Hi Eli,
We do not have a specific transformer recommendation. Any transformer that adheres to the datasheet specs will work. I believe our EVMs use magnetics that would fit these specs so perhaps you can look at the schematics of the following:
Shane
