TCAL9538: Removing RESET Pin Pull-Up Resistor
Part Number: TCAL9538
Hi team,
The customer is considering using the TCAL9538PWR.
Regarding pin 3 #RESET terminal: The datasheet states "Active-low reset input. Connect to VCC through a pull-up resistor if no active connection is used."
They are asking if connecting it directly to pin 16 VCC would cause any problems.
Could you please support?
Kazuki Itoh
