need information
Other Parts Discussed in Thread: LMH6525
Can you please provide the following information for the LMH6525SP/NOPB part?
  1. Junction Temperature Max (Tj Max)
  2. Typical Power, (Pd typ)
  3. Maximum Power (Pd max)T
  4. Thermal Resistance Junction to Ambient (Theta JA)
  5. Thermal Resistance Junction to Board (Theta JB)
  6. Thermal Resistance Junction to Case (Theta JC)
  7. Weight
  • Here is the information you requested about LMH6525:
    1. Junction Temperature Max (Tj Max)                                         150C
    2. Typical Power, (Pd typ)                                                               Quiescent power with no load (Vs=5V)= 5V * 33mA= 165mW. Load related power will add to this!
    3. Maximum Power (Pd max)T                                                      Maximum power can be derived from 150C Tj Max, T_ambient, theta j-A and power dissipation
    4. Thermal Resistance Junction to Ambient (Theta JA)           30.8 deg. C/W as noted in the datasheet Note 10 (4 layer board, 9 thermal vias)
    5. Thermal Resistance Junction to Board (Theta JB)              ~20 deg. C/W (4 layer board, 9 thermal vias)
    6. Thermal Resistance Junction to Case (Theta JC)               ~10 deg. C/W (4 layer board, 9 thermal vias)
    7. Weight        This information is not readily available but can be determined if need be?
    Hooman
  • Hi Hooman,
    Thank you for the inputs provided.
    Smitha
